Question about Philips DVP5990 DVD Player
Distorted color on hdmi output
My DVP5990 dvd player is displaying in an orange distorted picture on my tv. The dvd player worked fine for the first week, but just started displaying in this distorted view. I thought it might be the hdmi cable that I am using, so I connected the hdmi cable that I use for my Dish Network DVR. The distorted view still occurred. I tried multiple hdmi ports on my tv and the distortion still occurred.
If you haven't already stumbled across the fix: I just had the exact same problem after about eights months of casual use. Unplugging the DVD player for about 15 minutes and then plugging it back in "solved" the problem. Until next time it happens, anyway.
Posted on Jun 01, 2009
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Color distortion when playing DVDs
If the player has other outputs try connecting the player to the tv using one of them, ie: use the A/V output instead of HDMI from the player. If the problem goes away there is something wrong with the input on the tv.
Mar 16, 2008 | Televison & Video
When connected via HDMI, get picture filled with wrong colors - oranges, reds, blues; when connected via Component or Composite - works fine
You can ofter setup HDMI on your devices in different modes, for example my old tv had options that i could change RGB and other settings for hdmi. try looking in the settings of the DVD-player and see if you have hdmi options
May 03, 2011 | Philips DVP3982 DVD Player
Picture has color separation and halos. Picture distorted.
Your convergence is bad and you need to replace the convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Apr 27, 2010 | Mitsubishi VS-55601 55" Rear Projection...
Colour distortion
Try a new video cable assembly..
Sounds like the other colors arent getting thru from the DVD player
Apr 20, 2010 | Philips DVP5990 DVD Player
Black & White picture for DVD
When using the Component outputs on the player, make sure they are enabled in the player menu system (or sometimes there is a rear panel switch and sometimes both), as most players default the Component outputs to off. Even when the Component outputs are off, you will often get a color-distorted signal out as many players share circuitry between the various outputs.
May 19, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Dvd plyer picture is distorted and no sound
Just go into the setting on the tv and change the video input,It maybe set to hdmi and you may need it on analog.(you can look at the manual for the settings
Let me know if you still need assistance
Please rate this a fixya
Jan 31, 2009 | Televison & Video
Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Jan 13, 2009 | Marantz DV4001 DVD Player
Can't see picture
Is the onscreen menu just as distorted and are the lines across it or behind it? The pop you heard may have been a capacitor and since the TV is still powering on, it's the probably the video controller board that is on it's way out. If the onscreen menu looks fine, you maybe having a problem with the input board only so try a DVD that uses a different input and if it's poor, I would say the TV needs to have the input/output board service. If the OSD is distorted as well then it's definitely the video controller board and service is likely required.
Oct 15, 2008 | LG 42PX4DR 42 in. Plasma TV
Philips DVP5990 DVD Player Logo
1,209 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
