Question about Samsung 4 Channel Dvr
Wiring diagram for Vivitar CCD -200 Camera
The camera has a computer style PS2 female keyboard connector. Please provide wiring pinout information or better yet a wiring diagram.
  • jennie26 Dec 01, 2007
    I don't know how to insert memory card
  • pangr Dec 05, 2008
    Same here with a samsung SOCA-5M connector. Has a female PS2 type connector.
2 Suggested Answers
  • 3 Answers
SOURCE: Need wiring map for RJ11 conector for Samsung SOD-14C camera
I guess this is an ongoing issue with Samsung cameras. Did anyone EVER figure this one out?
Posted on Mar 31, 2010
What is the pinout for this radio that was in a Hyundai Santa Fe 2005?
Do you need Wiring Diagram for hyundai santa fe.Or you need where the radio fits in hyundai santa.The connector of radio.
Please Check the link mentioned below it has all wiring diagram for hyundai santa fe radio.Also it has details for how to connect radio connector.
If you need anything else,please reply.
May 11, 2016 | Hyundai Cars & Trucks
I purchased a system from Lorex model # LHV08C02
Lorex used standard BNC and provides Siamese cables for all their DVR systems; like this one.. If you want to use your own, use 75 Ohm RG-59 or RG-58 with compatible connectors. If using premade cables, use BNC female to female. Power is separate and is provided by the 'wall wart' style power adapter.
Sep 29, 2014 | Home Security
Vga wiring i want to know what each coler wire represents so i wont burn my pc wiring my stuff into it
Here's some wiring diagrams:
First according to pin:
And in this post you have pinouts according to standard color:
db15 male
6)dark green
7)light green
8)dark blue
10)light blue
11) purple
DB15 Female
7)light green
8)dark blue
10)light blue
that's all oh yes you also have a ground wire from connector base to connector base.
Hope this helps. So from these two, you should be able to figure out witch wire is witch. Let me know if you need more detailed information.
May 03, 2011 | VIA ASUS A8V-E Deluxe K8T890 chipset...
Dvi port specification
The DVI [Digital Visual Interface] is a standard for high-speed, high-resolution digital displays.
Below is a 24 Pin DVI Female connector seen at the Computer. The connector diagram and pin-out table show a DVI-I Digital and Analog [RGB]; 29 pins [modified D style] connector. A DVI-D Digital only connector with 24 pins [modified D style] looks about the same with out the 4 analog 'C' pins.
The DVI interface is found on a number of devices including TVs, Computers, Monitors, and Video cards.
Digital Visual Interface [DVI] was developed by the Digital Display Working Group (DDWG).
Note that the Digital Display Working Group disbanded around 2006, so don't expect an up-grade for DVI.
Digital Video Broadcasting/Digital Audio-Visual Council (DVB/DAVIC),
developed by DAVIC [inactive] and DVB [].
Adopted by European Telecommunication Standards Institute (ETSI) and
International Telecommunication Union (ITU)
DVI has a number of different types connectors:
DVI-D Digital only connector; 24 pins [modified D style];
DVI-A Analog only; [modified D style], I don't think this is part of the standard
DFP Digital Flat Panel, Digital only connector. Pinout is listed on the DFP page
Styles of DVI Connectors
Jan 13, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Please help.... I need a wiring diagram or pinout for my Jensen xa1120 amp, thanks
xa 1120 amp pin out 123
1 left neg
2 ground to radio
3 left positive
4 right neg
5 blank-not used
6 right positive
May 02, 2008 | Jensen XA92 Car Audio Amplifier
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Serial meaning 2.5mm stereo headphone looking jack to DB9 or "atari joystick" looking plug? I had one on my first Toshiba PDR-M1 camera but that was like 9 years ago. You can probably find the pinouts online for that cable, I believe it is a standardized cable.
The stereo plug is wired to the PC serial port as shown in the following diagram:
tip ring sleeve +---------------------------------+
| RxD | Gnd | TxD | 2.5 mm Stero Plug |
DB9*: pin 2 pin 5 pin 3 +---------------------------------+
DB9*: Optionally short together pin 4 (DTR) to pin 6 (DSR) and
pin 7 (RTS) to pin 8 (CTS)
The following table also describes the camera cable's wiring: Camera PC's
Plug DB9* Signal Name Direction
- 1 Carrier detect (CD) input to PC
tip 2 Receive data (RxD) input to PC
sleeve 3 Transmit data (TxD) output from PC
- 4 \ Data terminal ready (DTR) output from PC
ring 5 | Signal ground (Gnd) -
- 6 / Data set ready (DSR) input to PC
- 7 \ Request to send (RTS) output from PC
- 8 / Clear to send (CTS) input to PC
- 9 Ring indicator (RI) input to PC
* Note that the cable's D-subminature DB9 RS-232 serial port connector is female. This connector also goes by the historically more correct name of "DE-9J".
Feb 22, 2008 | Epson PhotoPC 500 Digital Camera
PS2 Controller Wiring Diagram
heres the diagram
Dec 09, 2007 | Sony PS2 Dual Shock 2 Controller...
Samsung 4 Channel Dvr Logo
301 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
