Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Sing a Futura Sewing Emboidery Machine, how do I
Using a Futura Sewing Emboidery Machine, how do I hoop a t shirt so that it does't sew front and back of shirt?
  • 4 Answers
Be careful to only hoop the front of the shirt. Use LARGE safety pins to keep the rest of the fabric away from the needle. Roll the other pieces of the shirt and pin them to keep them out of your sewing area.
Posted on Apr 26, 2009
This I do quit often, just pull the shirt away from under the foot as you go, pause the machine every now and then and readjust the position of the shirt, it is time consumming but it really works and using the correct stabilizer with spray on glue as well as the plastic stabilizer on tob, (pin this very tight on top of the shirt) you get a beautiful result.
Posted on Apr 24, 2009
Use temp basting spray and place just the front of the shirt on the hoop on top of the stabalizer. You will need to just hoop the stabalizer so as not to make the shirt pucker when it is done. pin the rest of the shirt up or use a rubber band ( which is what I do) by using the spray you can adjust the shirt on the hoop without making the backing loose (backing that is loose will pucker the final image when it is washed. I use self adhesive washable on the front of jersey fabric as well to make sure it does not stretch out while I sew.
Posted on Apr 24, 2014
Board
Close your futura file & exit, switch off your futura machine. Disconnect the embroidery unit from the machine,move the hoop carriage a bit to the left then to the right & it should be able to move. Connect back embroidery unit to your futura machine,ensuring the connecting point click properly. Re thread the machine & ensure needle is fully up position. Now you switch on the machine, you will see hoop carriage moving and stop at its zero point. If that is OK and the earlier led blinking gone, you should be able to operate the futura embroidery program again.
Jul 18, 2013 | Singer CE-200 Quantum Futura Computerized...
Futura 150. Using autopunch. The machine does some of the
have you tried changing the needle?
it could be a part of the computer is mal-fuctioning
it could be out of time
it needs to be serviced to find out what's wrong with it.
Mar 22, 2012 | Singer CE-200 Quantum Futura Computerized...
WHEN I SEND DESIGN TO MACHINE MY HOOP DOES NOT GO TO THE RIGHT PLACE THIS IS A EMBORIDY SEWING MACHINE SINGER FUTURA
Keep trying. I read on the Future web site, that there is an "order" to staring. The software assumes you are using the large hoop. Every thing needs to be in place, before you turn the Future software on. Then the hoop should move to the correct portion. I just get mad and move it by hand. Check out the FAQ on the web site.
Aug 15, 2009 | Singer CE-100 Futura Computerized Sewing...
Carriage of my futura 200 is stuck
Turn off the machine, remove the Hoop from the embroidery arm, then turn it back on. You'll notice some of the hoops have an extra piece of metal that the machine identifies it with. Mine just didn't like the hoop I had on.
Jul 07, 2009 | Singer CE-200 Quantum Futura Computerized...
Trnsmitting problems I cant transmitt to my machine and it is now getting frustrating.
I have the solution! After calling 1-8004SINGER.
When this happens,
turn off emb. machine
detach hoop
exit out of futura program back to the windows screen
Then, turn on emb. machine
Reattach hoop
Open Furtura program
Select design
Select transmit button
and this should work. You have to this in the exact same order each time.
Mar 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Hoops
i found both hoops on this websit.....thesewingcenter.com...lrg...13.99, sm...12.99!!!!! it took me 2 months of web seaching to find tem
Jan 15, 2009 | Singer CE-200 Quantum Futura Computerized...
I have a futura 150 and I can't get it to change hoop settings. I will put the small hoop on it but it doesn't recognize it. What do I do to fix it. It will change it on the computer screen but doesn't on...
Do not switch on the machine with the small hoop attached. After changing the hoop reload (close and open again) the design or restart the software or select the small hoop manually from the menu.
Aug 26, 2008 | Singer CE-100 Futura Computerized Sewing...
Hi, I'm trying to embroider using my Singer Futura CE-100. After it starts to embroider, it will either bunch up bobbin side or the machine will beep, and the computer says to turn it off, remove hoop,...
could be a threading problem. on the top of the machine, where you go under the plate, pull the thread back and forth like you are flossing. you should feel the thread snap around the 2 wheels, then continue threading. hope it helps
Aug 15, 2008 | Singer CE-100 Futura Computerized Sewing...
Errors
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura software.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
Jul 28, 2008 | Singer CE-200 Quantum Futura Computerized...
I recently bought a Singer Futura CE-200. I was using the embroidery function, but had to stop due to threading problems. When I went back to the computer a few days later my computer was shut down. I...
2. Remove the hoop.
Jul 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
96 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
