Question about HP PSC 750 All-In-One InkJet Printer
Color ink is out I need to print black and white can I change it
  • 526 Answers
You need to have both cartridges with ink for the unit to work.
thanks
Posted on Apr 17, 2009
My school room printer Dell 5130cdn is out of color ink, however it does still have black ink, how can i get the printer to print with just the black ink?
when in print section go to settings and click on black or unclick color
be aware that color is need to get black and white reproductions ( copies)
Aug 17, 2016 | Dell 5130cdn Color Laser Printer
Need to print only black ink on canon mp510
in the printer set up ( normally in the print section , change the color to black and white , make default and ok
Jan 11, 2012 | Canon PIXMA MP510 All-In-One InkJet...
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
My HP Officejet 7410 All-in-One Inkjet Printer is doing the following: 1) It prints in color even when the document is black and white (using up the color ink) 2) It prints much more slowly than it did...
go into your driver and change your color preferences to black and white. that way when you want to print color you actually have to tell it to do so. which will save your color ink, and will print much faster. full color printing of a black and white document uses all ink colors except black to make what is called process black.
Dec 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Can i print black and white text only when colour cartridges are empty but black is full on an ip14300?
you can make a selection from the File->Print option of your word processor or whatever package you are using. it is your command that sets the printer to B&W or color. If your Black ink finishes then the printer even if set to color will print black as near black with color inks.
Sep 14, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Can't print in black and white
Hi Aaron,
There should be a setting in your PREFERENCES that allow you to set it to black print only. Select it as your default setting so that you don't have to change the settings each time you print.
Hope this helps. Good luck!
Jul 31, 2009 | Office Equipment & Supplies
Is there a setting to print in B/W only?
Yes
When printing press file,then print, from there select printing preferences go over the pages and look for black and white setting or grayscale setting.
it will print in black and white only.
May 29, 2009 | Office Equipment & Supplies
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
HP PSC 750 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
