Question about Conair TAD 2014 Answering Machine
Can't program the greeting conair tad 2014
Can't program the greeting and other functions conair tad 2014
  • Conair Master
  • 8,073 Answers
Here is a link to the manual.
http://www.conairphone.com/IBs/digital_answering_systems/tad2018.pdf
Hope it helps
Posted on Sep 16, 2009
Flashing L on display conair TAD 1216PWT answering machine
i was wondering the same thing. i contacted conair, and although they no longer make these things, a very nice lady named maria was able to find an owners manual which she promptly sent me via email. the L means the 4 triple A batteries need to be replaced. hope this helps.
Mar 12, 2011 | Conair TAD1216PWT Digital Answering...
Remote operation
Here it is.
To erase messages.
Aug 03, 2009 | Conair TAD 2014 Answering Machine
I lost my manual for TAD 1212. I cannot access my
Check this link and select the product:
http://personalcare.owneriq.net/manuals/mfg/conair/conair_product_list.html
Have a good one!
Jun 22, 2009 | Conair TAD 1212W Digital Answering Machine
Conair TAD-1220 Digital answering machine
Background: The TAD1220 does not have a way to manually delete messages. It more or less has a FIFO(FIRST IN-FIRST OUT) method of retaining messages. It will save up to 14 minutes of messages and then they are deleted automatically after you play them back and receive another incoming call.
This is important:
It will only erase the messages AFTER you have listened to them *AND* received another message.
Exception: If you happen to press the STOP/SAVE button, then all of the messages will be RE-SAVED until the memory limit has been reached.
Extreme Solution:
The only manual way is to remove the battery, disconnect the power cord and erase everything. You will then need to reprogram your greeting.
Jul 17, 2008 | Conair TAD-1220W Digital Answering Machine
Power adapter
As long as you dont EXCEED the power rating listed on the answering machine itself, you can use/purchase a new power adapter for it.
You should be able to find a power adapter that matches the answering machines power need exactly.
I hope this has helped to solve your problem, good luck!
May 16, 2008 | Conair TAD 2014 Answering Machine
Conair TAD 2014 Answering... Problem
The time associated with messages is incorrect. How can I change it?
May 06, 2008 | Conair TAD 2014 Answering Machine
Conair digital answering system
TAD2012 Quick Reference Guide
To Install
1. Open the battery door with a ballpoint pen. Install one 9-volt alkaline battery (not included)
and replace cover.
2. Plug the telephone line cord (connected to the back of the TAD2012) into the modular wall
jack.
3. Plug AC adapter into standard 120-volt outlet. Plug your phone directly into an outlet, not into
an extension cord.
Answering System Operation
Recording Your Personal Greeting
1. Press and hold down the GREETING control.
2. After the beep, speak towards the front of the base; you have 30 seconds.
3. When finished, release button. Your unit will play back your greeting and
reset to answer incoming calls.
4. Adjust volume control on the side of the unit to set the speaker to the desired level.
Select the Number of Rings
Choose 2,4 or TS (Toll Saver), which programs the number of rings that you want before your unit answers.
To Play Back Your Messages
1. When the message indicator flashes, you have received messages.
2. To hear your messages, press and release the PLAY control. Your unit will automatically
reset after messages are played.
To Save Your Messages
After the last message and 2 beep tones, press the STOP/SAVE control.
IN CASE OF POWER FAILURE OR IF ANSWERING SYSTEM IS NOT OPERATING PROPERLY
If a power failure occurs or the plug comes out of the wall, your unit will shut down until the power is restored. One 9-volt battery must be installed to retain your personal greeting message and incoming messages during the power failure. Occasionally outside factors, such as power surges, may adversely affect the unit. If the unit is not operating properly or if the light continues to flash once power is restored, try these steps:
1. Unplug the AC adapter from the power outlet.
2. Remove the 9-volt battery. Replace with a fresh 9-volt battery.
3. Plug AC adapter back into power outlet.
4. When your unit is initially plugged in, it will check its memory for approximately 3 seconds.
Three deep tones will be heard if you attempt to record a greeting message before this
period.
5. Record a new greeting message.
Indicator Status: Message indicator is consistently flashing slowly.
Reason: No greeting message has been recorded.
Action: Record your greeting.
Indicator Status: Message indicator flashes rapidly.
Reason: A 9-volt alkaline battery (not included) has not been installed or needs to be replaced.
Action: Install a fresh 9-volt alkaline battery. (Battery provides power failure backup. Unit is functional without it).
Indicator Status: Message indicator flashes to indicate number of messages received,
and then repeats.
Reason: Messages have been received.
Action: Press PLAY control to hear your messages.
Indicator Status: Message indicator is lit solid.
Reason: System is in Answer Mode.
Action: No action required. Unit is ready to receive calls.
Conairphone™ Consumer Hotline
Questions? Call the Conairphone™ Consumer Hotline, toll-free, 1-800-366-0937.
Hotline Hours: Monday-Friday 8:30 a.m. - 9:00 p.m. (EST)
Saturday 8:30 a.m. - 12:30 p.m. (EST)
7475 North Glen Harbor Blvd.
Glendale, AZ 85307
Nov 08, 2007 | Conair TAD 2014 Answering Machine
TAD erase and record greeting message
Just record a new one, it will overwrite the previous message
Sep 27, 2007 | Office Equipment & Supplies
Bought system at yard sale but no manual
Here's the link for Conair; http://www.conairphone.com/Pages/IBs.html They have a manual for the 2012 which may be useful; http://www.conairphone.com/IBs/digital_answering_systems/tad2012.pdf else contact them on; 1-800-366-0937. Sorry doesn't seem to be available online anywhere else. Hope this helps :)
Aug 21, 2007 | Conair TAD 2014 Answering Machine
Conair TAD 2014 Answering Machine Logo
244 people viewed this question
Top Conair Lands Phones Experts
k24674
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Conair Lands Phone Expert? Answer questions, earn points and help others
