Question about Sony Playstation 3 (PS3) Console
When I hook my PS3 to a stereo A/V player or switch box I get a humming noise that gets louder when i turn up sound
  • 371 Answers
Cables are sometimes expensive for a reason: They offer more or less sheilding from grounds of various
sources, including your own body.
Whatever cables you are using are allowing a 60 Hz hum to interfere with your enjoyment of your unit.
Since the cables have to be in close proximity with both your body and the back of the unit, which emits
a 60Hz signal, from your house wiring, which becomes the humming noise you experience, the AV cables
should be heavily sheilded so as to protect the signal from your MP3 player from interference by the 60Hz
signal to increase the signal to noise ratio and thereby reduce your hum.
So, shop for the cables with the least loss and the highest signal to noise ratio. And enjoy!
Posted on Apr 17, 2009
MY 1998 FOR EXPLOYER ELT HAS A LOUD HUMMING NOISE THE FAST I GO THE LOUDER IT GETS CAN ANY ONE TELL WHAT A POSSIBLY CAN BE .MY HUSBAND SAYS THE SPINDLE????
Humming Noise Front End- Any Ideas? - Ford Explorer and Ranger ...
www.explorerforum.com > ... > Stock 1995 - 2001 Explorers
Dec 18, 2008 - 19 posts - ‎16 authors
Have a 98- Eddie 4.0 SOHC, 4WD with a 100,000 mi. When driving it has a humming noise, it almost sounds like a bad tire, or a ... I start to hear the humming noise at 20 mph, it is very loud at 40 to 50 mph ... 94 XLT-95 FX4. humming gets louder as speed increases
May 27, 2010
How to: IAC valve cleaning thread (w/pics)
Oct 29, 2007
humming from air intake
Jun 6, 2002
Loud humming noise coming from the air filter
Oct 6, 1999
More results from www.explorerforum.com
Jan 12, 2016 | Cars & Trucks
I hear a sharp snap then a loud humming noise which sounds electrical. If I turn the refrigerator switch off, then on, the humming stops. Otherwise, it lasts 10 to 15 minutes. Its getting louder.
DID U CHECK UR EVAPORATOR FAN AND LISTEN IF THE NOISE IS COMING FROM IT? COULD BE BROKEN OR IMPEEDED IMPELLER HITTING SOMETHING ON START UP THEN GOING INTO A HUM?
May 20, 2015 | Sharp Refrigerators
2002 grand cherokee laredo humming/grinding
sounds like you have a problem with one of your lines on your power steering or one of its components. the grinding noise could also be one of your pulleys that have gone bad too. check your steering assemby gear box.
Jul 26, 2009 | 2002 Jeep Grand Cherokee
How do you audio output to a stereo amp
if your amp has a optic cable slot u may need one of these to transmit sound from ps3 to amp :)
May 17, 2009 | Sony Playstation 3 (PS3) Console
Humming sound to speakers from amplifier
It sounds like you may have a ground loop issue. I'd start by checking all the power and ground connections. Then disconnect the RCA wires from the amplifier. If the hum goes away then you should try grounding the stereo to a better grounding point, the factory grounds are usually not very good at all. Then try it again, if it is still there try replacing the RCA"s.
If the hum is still there after you've redone the connections and replaced the RCA's, you may need to install a ground loop isolator.
Both www.crutchfield.com and www.sonicelectronix.com sell good ones.
Hope this helps
Mar 28, 2009 | MTX X Thunder 1000XD Car Amp
AKAI 54" Big screen, Turn TV on picture no sound, then within a few minutes humming sound gets louder then stops and starts
Sounds like the audio amplifier circuit is bad. I do not know if where that is in that TV. If you were to hook a boom box or stereo receiver to the TV (via the audio out jacks on the TV), you could monitor the sound that way. If you get clean sound, then the problem is in the amplification circuitry. If you still get humming, etc., then the problem is further upstream.
Also, clarifying... the picture has not changed one iota, correct?
Mar 05, 2009 | Akai LCT2715 27 in. LCD Television
A humming noise coming from tv when cable and ps3 are hooked up
I fixed mine by removing the cable wire from my tv. For some reason tv cable and the old PS3's cause a problem.
Feb 08, 2009 | Sony Playstation 3 (PS3) Console
My dvd player is making a loud humming sound when i load up a dvd. it is the phillips dvp5960
Does the DVD player still work, even though it's making the humming noise?
The humming noise may just be normal for that machine. Turn your TV up louder .
If the player doesn't work, the drive is broken, and you would have to send it to Phillips if your warranty is still working. If the Player still works, check to see if the disc is warped or cracked, this'll make the drive unstable, and make the noise.
Hope my answer helped :)
Nov 16, 2008 | Philips Televison & Video
Sony Playstation 3 (PS3) Console Logo
177 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
