Question about Audiofonics ADF-243 Car Audio Amplifier
Component for amplifier
I blew some of the outputd on the amp and im trying to fing a store or a website where i can purches the parts can someone help me please IRFZ44N 1-R450G =4 OF THESE 86 EE IRFZ44N 1-R450G =2 " " 87 01 FMG5 ->
  • 1 more comment
  • naldo hoyte
    naldo hoyte Oct 03, 2007
    one more thing theres a transistor that is burnt very bad and i cant make out the number it has something to do with the power i couldnt make out the number to good it has k238
    a266
  • naldo hoyte
    naldo hoyte Nov 12, 2007
    check the resistors on the power area, this was happening to my amp and one of the 100 ohms resistors was bad but i cant tell you which one is bad you will have to check all
  • naldo hoyte
    check the resistors in the power area
  • 631 Answers
All of the components with the IRFZ44N part numbers are the same. The rest of the information is the date/manufacturing code and isn't really important (although they should match if they were all used in the power supply). Digikey has them. The new lead free version is IRFZ44NPBF. The rectifier ->
Posted on Sep 19, 2007
SOURCE:
My power acoustik bamf 2200 amp keeps blowing its fuses, why?
another couple of things is a bad ground wire. a sub going bad( causing a different ohm load then before) ive run into a bad fuse link in the amp before as well
Aug 04, 2014 | Power Acoustik BAMF2000/1D Car Amp
Hi, I have a YST-SW800 that just went dead on me. I don't have the knowledge to fix the amplifierunit. Is there anywhere I could buy a new amplifierunit to the subwoofer. O.E.
Possibly, try a search engine.
But even if you find one you're stuck with the same dedicated amp.
I once had a powered sub that blew its internal amp and the store gave me a whole new sub. THAT one blew the same way so I disconnected the internal amp and now use it as a passive sub with a separate amplifier that I own. Separable amp/speakers allow for the surviving component to be redeployed.
Jun 01, 2011 | Yamaha YST-SW800 Subwoofer
Well i think i freid my amp i had a friend take a look at it and thats wat he said might of happened cuz as soon as i try to put a fuse in it blows it so idk wat to do now i want to get it fixed but in...
  • Open the Amp up. Look for any black spots on the board. If it "blew" you should see a burnt electrical component, perhaps a RCA jack where the cords go. That's the first step in looking at a suspected "blown amp"... is to try and see if you can see what blew.
  • Let me know what you find. If the fuse is blowing just as quick as the power feed is connected there is a burnt part of the board and/or a component. I suspect a diode. They allow current one way and are what one may say a fuse on the board itself in the form of a component.
  • Let me know.
Tony
May 30, 2011 | AudioBahn A2300HCT Car Audio Amplifier
The only time someone can herte me is when im right beside them?
Sounds like someone or something blew out the final (amplifier). If they aren't getting any signal on their meter, when your are further away, then this is what would be going on. A service tech or repair shop would need to replace the bad part(s) and recalibrate the radio for the new amp.
Only other problem would be if you either have no antenna connected, or one that is non-functional.
Apr 02, 2011 | Cobra 29 LTD CB Radio
I recently purchased an Orange AD5 amp. It came to me dead so the store I bought it from told me to try to change the fuses for this amp is becoming rare and hard to get. I replaced both fuses with the...
Check for burned components, broken wires or cracked insulation on wires. Inspect the tube sockets and circuit boards for carbon tracks. Next, check the power supply rectifiers for shorts.
If you don't find anything, pull out all of the tubes (be sure to document where each tube goes!) and see if the fuses still blow. If they don't, one of the tubes has an internal short. (If the fuses blew only after warm-up, it would be an overload on a tube rather than a short through the tube.)
If this was a solid-state amplifier, I'd suggest checking the audio output driver transistors - this is the most common fuse-blowing failure in those.
Feb 13, 2011 | Orange Amps Orange Amplifiers AD Series...
Due to no electrical safety fues on the amp my channels burnt up because the speaker blew can i buy channels for my amp or do i throw it away I own a punch 301s 900watts
your amp can be repaired by a professional to hard for someone without electronics training. you may find it is to expensive to repair. new will probably be your best bet.but do find out about repair before buying new. I have a local shop here that has a 60 dollar fee to look at it then if parts are needed they have an hourly rate plus parts. good luck
Apr 23, 2010 | Rockford Fosgate Punch 301S Car Audio...
I just got a 600 watt sony xplod amp with a 10 inch xplod sub and it keeps turning off i thought i blew it but it went back on im confused
Could be overheating or a bad ground. Could also be a cracked tube or other internal part, that is expanding under heat and failing out.
Apr 07, 2010 | Sony XM-1502SX Car Audio Amplifier
My directed d1200 amp blew a fuse i replaced it and the power light is green. However im not getting any sound out of the sub and the esp indicator light is on. what does it all mean.
Hello, first the ESP is for communicating with Directed security systems. If your fuse blew then your amp may have a security feature that disables the amp. The new Directed amps have these features. You need to read your manual or see if you can download one. You should be able to take care of it that way. If you do get it unlocked cause of a security feature and it still does not work, then you are having some internal component problems. I do amp repairs for a living. I own a car audio installation and amp repair shop. I'm the cheapest amp repair you will find anywhere. So if it turns out to be more than you can handle I can repair it for you if interested.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Aug 13, 2009 | Directed D1200 Car Audio Amplifier
Amp keeps blowing speakers
If the amp blew the speakers , it sounds like the amp pumped HIGH levels of DC voltage into the speakers.
Get another amp and not Behringer,not Pyle,not Gemsound and not Numark.
Feb 02, 2009 | Behringer EUROPOWER EP2500 Amplifier
Amp repair
Often times, car audio amps arent worth repairing, the components are hard to find, and harder to get small numbers of (like one amp worth) if its a blown cap inside the amp theres a very high likelyhood it took out other parts in the amp too...
When working one of thease kinds of problems, always ask yourself, WHY, 1) why am i repairing it, is it worth the time/effort. 2) Why did Component "X" die? What Killed it? and in turn what did it killed as it died?
Jan 16, 2009 | Car Audio & Video
Audiofonics ADF-243 Car Audio Amplifier Logo
217 people viewed this question
Top Audiofonics Car Audio & Video Experts
Dalynn Turner
Mark Skinner
Billy McCain
Billy McCain
Level 1 Expert
Are you an Audiofonics Car Audio and Video Expert? Answer questions, earn points and help others
