Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Rainbow and Bowtie Effect
Here is link to PIC: http://www.niemergs.com/coppermine/displayimage.php?album=1&pos=9 This just happened after turning on the unit. It is a 2003 model. We bought it new. It has never been serviced before. The flash focus does not reset to automatic/default settings. I am prepared to fix it myself. Soldering if necessary. I would like some help to point me in the right direction. It could be as simple as a fuse, or a replacement IC board, or chip. Thanks in advance! Jim
  • Jackall Sep 20, 2007
    Tried your solution and it did not work. I did see what difference it makes while adjusting. But my problem has more to do with convergence and very likely the STK392-560 chips 1 and 2 (IC8001 and IC8002) Looks like a professional repairman is necessary. After adjusting though, the Stby/Timer LED is now blinking 5 times which indicates special problem. Looks like professional help also.
    Thanks for trying!
  • j_nall May 11, 2010
    where is the voltage and convergence adjustment on a sony kdf60xs955 located
  • 3 Answers
Go here: this solution works for many sony issues (slight voltage adjustment is all it takes) http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Sep 19, 2007
SOURCE:
Where can I download an owner's manual for an Endura 30 trolling motor
I have an Endura 30 also and haven't been able to find an owner's manual or a service manual. I did find a schematic which is almost as good as a service manual. It gives an exploded view of the entire assembly as well as names and part numbers for each part. It's all I needed to order parts & repair mine. It is even done in such a way as to illustrate how it comes apart and goes together.
Here's the link: http://www.mikesreelrepair.com/schematics/displayimage.php?pos=-4777
Sep 11, 2010 | Minn Kota Endura 30 Freshwater Transom...
Can I download owners manual?
Aug 26, 2010 | Minn Kota Endura 30 Freshwater Transom...
Where can I get a schematic so I can put the shimano 4000FA back together
Go to the shimano website, at the very bottom of the page is written contact us. Call the number and a rep will hook you up.
Apr 12, 2010 | Shimano REELS TYR20 Tyrnos Lever Drag...
I have marshall 250 dfx when i turn it on cooling fan makes weird noise then plays 10 min. amp starts fading in & out
Try carefully cleaning your cooling fan with qtips for the blades and a vacuumn. See if that helps the fan. If not it will need to be replaced. If you are experienced with amp repairs have a look for loose parts on the circuit board. If you can safely disassemble it, look at the soldered side for bad solder joints. From another poster on here with the same problem I have learned that resoldering R107 and R96 helped. Make sure they aren't burned out or have changed in value.They are in the FDD circuit. Have a look at your owners manual and it will make sense. The schematic is available here:http://www.ampix.org/displayimage.php?album=search&cat=0&pos=0 If it doesn't come up use the search function on that site. Do not attempt to service this yourself unless you are absolutely sure you won't hurt yourself or the amp.
Mar 02, 2010 | Marshall Amplification Marshall MG250DFX...
My marshall valvestate 100 will completly cut out when im playing and the only way to make it come back is to turn it off and then on. it makes a really loud pop when i have 2 preform this task
It sounds like one of the filter capacitors is getting ready to fail in the power supply. Here is a link to some good info:http://www.geofex.com/ampdbug/ampdebug.htm Here is the schematic:http://www.ampix.org/displayimage.php?album=31&pos=112 Let me know if this helps.
Nov 30, 2009 | Music
I have a Penn 650 SS spinning reel Ihave loss the drag I have tighten it as hard as I can and it still has no drag
If the knob is not stripped, replace the drag washers under the drag knob.
Replace key #'s 6 and 56T with 3x 6-155 carbon drag washers, available here: http://www.mikesreelrepair.com/product_info.php?products_id=7806
this will bring your drag back to better than new condition!
Here's a schematic: http://www.mikesreelrepair.com/schematics/displayimage.php?pos=-4123
Best of luck!
Mike
Nov 12, 2009 | Penn Gt Series Levelwind Reels 330GTi
Humminbird 250 DX Fishfinder
Hi!
Here's the closest match:
http://www.mikesreelrepair.com/schematics/displayimage.php?pos=-5218
best of luck
Mike
Aug 19, 2008 | Boating
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
120 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
