Question about Nextar X3-03 Car GPS Receiver
GPS CAN NOT FIND MAP DATA FILES
WENT INTO FATEL MODE THEN BEEPED A FEW TIMES I TURNED IT OF NOW IT CANT FIND THE FILE
  • Anonymous Apr 26, 2009
    loads up, but cannot find map data files. tried previous solution but still persists.
    Problem Solver:
  • 5 Answers
I had a similar problem with a nextar X4-T, which has it's maps on an SD card. If your GPS uses an SD card for it's maps, you can try this:
You will need a computer with an SD slot, and running Windows Xp. I tried the following method on a computer running Windows Vista, and it did not work. I tried again on an older Xp machine, and it worked first time.
  1. Put the SD (Map) card in the computer's SD slot.
  2. Open Windows "explore". (RIGHT click on "Start", then select "explore"
  3. Locate your disk on the file menu.
  4. RIGHT click on the map disk
  5. A menu pops up.
  6. At the bottom of the menu, select "properties"
  7. Another menu pops up, with several tabs along the top.
  8. Select the tab that says "tools".
  9. In the "error-checking" section, select "Check Now"
  10. Another menu pops up.
  11. Select the box that says 'Automatically fix file system errors".
  12. Click "Start"
The program will only take a few seconds to run. If it works, you will see the file directories of the SD card display on the "Explore' screen. You can then put the SD card back in the GPS, and see if it works.
Good luck.
Posted on Apr 18, 2009
Can not activate nuvi 350. gives: No Map Available..
Connect your unit to a PC and look in the Garmin directory for the following files:
gmapprom.img - ~1GB file size
gmapprom.unl - map unlock file
If these files are missing or if the map file size is much smaller than 1GB then they will need to be replaced. Also check to make sure that your map is not turned off. Go to the map menu screen and make sure that the map is checked (turned on).
If you can need further help, please see this link for further help:
http://www.sharc.net/gps_lost_map.htm
Mar 23, 2013 | Garmin Nuvi 350 Car GPS Receiver
I have recently purchased nüMaps
Since you have (2) maps, North America and Europe, you will have (2) map files on the directory. They are:
gmapprom.img (North America map)
gmapprom1.img (Europe map)
Do you see both of these file names? Do you have unlock files associated with them such as:
gmapprom.unl (North America map unlock code)
gmapprom1.unl (Europe map unlock code)
These files should be 1 gigabyte or more in file size. If they are not, then they are possibly corrupted.
- Jim
SHARCNET-USA
Apr 16, 2011 | Garmin Nuvi 370
Hi, I have a Nuvi 255 (205 series) gps, three years old. Last week the screen went blank, came back grey with 'crosshairs' and a black dot in the middle indicating 'press here'. I did so and the dot moved...
Graham - what your describing sounds like you somehow managed to erase the street level maps and POIs in your Nuvi.
If you connect the GPS to the computer with your USB cable, you should at the contents of the Nuvi directories and find a file called GMAPPROM.IMG or GMAPSUPP.IMG. These are the street level map files. Generally, these are found in the root directory of the Nuvi - or if yours has / and you use a memory card slot for maps - find it in the /GARMIN directory. GMAPPROM.IMG is the name of the first map set and GMAPSUPP.IMG is the name of the supplementary or second map set (if you purchased & installed one). You will likely have only one of these files - and may be named either. The size of this file depends on the area and age of the map. Current maps of the entire US run over 1 GB in size. If you do not have any maps named GMAPPROM or GMAPSUPP, you will not see any street level maps.
Something happened to delete the maps. Garmin will probably NOT provide free replacement maps for you, unless under warranty. If the devices is trashing maps and other files, you probably want to replace the unit under warranty or not. Garmin will, upon return of your old Nuvi - replace it with a factory refurbished unit with the latest maps installed, for $79. You can take advantage of this service by following this link to Garmin Service.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 23, 2011 | Garmin nuvi 205 GPS Receiver
I recently bought a nuvi 680 from ebay and turned it on, seemed to work ok except that the bluetooth firmward was absent. I found and updated the firmware...worked ok....then decided to update the map...
When you install a new map, you need a new unlock code. Do you have a file named "gmapprom.unl" within the Garmin directory on your Nuvi?
- Jim
SHARCNET-USA
Apr 15, 2010 | Garmin Nuvi 660 GPS Receiver
"No Map Data Available" - Garmin Nuvi 350
This is because your map file has either been deleted or corrupted and needs to be replaced. Please see this link for more info. Too much info to copy & paste here:
http://www.sharc.net/nuvi_lost_map.htm
- Jim
Dec 12, 2008 | Garmin Nuvi 350 Car GPS Receiver
Unable to send and open data sent to my Garmin GPS from Anquet map. I planned a route on my Anquet map software with wayponits etc but was uable to send it to my gps. I have enquired with Anquet and they...
Currently, the POI Loader only supports CSV files because that is the format that most data vendors support. POI Loader may support additional formats in the future.
MapSource only supports .mps, .gdb and .gpx files. You can save files as .txt files if you wish to use this data in other applications.
Sadly Garmin does not produce any software which can convert .txt files.
However, this maybe possible with GPS Utility. Please note GPS Utility is not Garmin software and Garmin does not support this. Click on the following link for more information:
www.gpsu.co.uk
Oct 13, 2008 | Garmin GPS
Need the map files badly
way too large a file set for email, I made a dvd that I sell on ebay for the cost of materials and labor... search for finedrive dvd
Sep 02, 2008 | Fine Digital FineDrive 400 GPS Receiver
Map data
the site changed their limits and I am unable to post. I have instead listed the upgrade dvd on ebay with the upgrade files and map data as well as instrucitons...
Apr 02, 2008 | Fine Digital FineDrive 400 GPS Receiver
Nextar X3-03 Car GPS Receiver Logo
910 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
