Question about Poulan "Poulan" Push Mower
I have a POULAN lawn mower that has sit unused for 5yrs. Engine Model: LEV80 Engine Family: YTPXS.1271BA Displacement: 127 >> I overhauled the moter & fuel system, but when I crank it there is no 'spark' going to the spark plug. So, what's wrong???
  • 2 more comments
  • logandiez Apr 17, 2009
    I changed both fuel and oil when I overhauled the motor. Uh-duh. The problem has nothing to do with the fuel; fuel feed; oil; lubrication system; etc.; etc., Marc ... it is a failure of the electrical system.
    There is NOT electrical feed to the spark plug, but I have already checked all the wiring and found it to be intact. So there must be something else ... what else could keep power from the spark plug?
  • Anonymous Mar 16, 2014
    Engine set with gas in it now it does not crank . Has good spark nice and blue . Is there a strainer in tank possibly clogged?
  • Ron Jones
    Ron Jones Jun 05, 2014
    try unplugging the cut off cable located on the coil.....if it cranks then....your coil is being grounded out .....look at how it operates and make your adjustments....really and easy fix...hope this works for you.....i see it about twice a month on mowers i fix...
  • Ron Jones
    or replace the coil..
  • 36 Answers
Ensure that you refill it with new fresh fuel not the fuel that was left inside it as fuel does has a limited life.
Regards
Marc
Posted on Apr 17, 2009
  • Marc Buck
    Marc Buck Apr 17, 2009
    In all probability logandiez , the fact that sitting idle for so long has caused rust to form on the magnetic strips in the flywheel,
    and on the legs of the coil/magneto! You will have to remove the engine
    cowling-the part that covers the flywheel and cylinder. 4-1/4 inch
    bolts (7 sixteenth heads) hold it on. Some times the bolts might be
    larger. Any way, take those bolts out, unclip any wires from the cover,
    and lift it off. Remove the coil,-held on usually by 2-1/4 inch head,
    bolts.
    Using sandpaper, sand the legs of the coil until they shine, then sand the strips on the flywheel.
    To install the coil and to set the proper gap:
    Cut a 1 1/2 inch by 7 inch strip from a greeting card.
    Set the coil back on, with the magnets on the flywheel turned away from
    where the coil sits. Install the bolts loosely., through the coil, into
    the posts. Then tighten the bolts snugly enough to hold the coil away
    from the magnets. Place the strip of greeting card between the coil
    legs and the flywheel. Turn the flywheel until the coil legs are
    opposite the magnets, and the card strip is in place. Then loosen the
    coil bolts, the coil will slip in against the the card strip, then
    tighten the bolts snugly, so no movement is possible, but don't break
    them off, as that will cook yer goose! Then turn the flywheel and the
    card strip will come out, and the coil leg gap will be correct.
    Reinstall the flywheel cover, and it should start up.
    I hope this helps a little more.
    My best regards
    Marc
How do I determine horsepower by serial number?
A quick explination of how to tell how big a Kawi is the model number. Those ending in 0 are the rough displacement (cc's) of the engine, those ending in 1 are a up or down hp version of the 0's in the same family. A quick explination of how to tell how big a Kawi is the model number. Those ending in 0 are the rough displacement (cc's) of the engine, those ending in 1 are a up or down hp version of the 0's in the same family. A quick explination of how to tell how big a Kawi is the model number. Those ending in 0 are the rough displacement (cc's) of the engine, those ending in 1 are a up or down hp version of the 0's in the same family. all aa
check your engine model #
all fh641v series 675 cc 21 hp
Specs: HP cc Bore x Stroke
FH480V 16HP 472cc 68mm x 65mm
FH541V 17HP 585cc 74mm x 68mm
FH580V 19HP 585cc 74mm x 68mm
FH641V 21HP 675cc 75.2mm x 76mm
FH680V 23HP 675cc 75.2mm x 76mm
FH721V 25HP 675cc 75.2mm x 76mm
FH641V 21HP 675cc 75.2mm x 76mm 41.19 cubic inch
there must be differences in the valves and carb sizing / jetting to make engines put out more hp similar to briggs with their engines
When asked for serial, I.E. AS01, BS01, etc., the lower the letter, the newer the engine. It doesn't really matter, except for maybe spark plug reach or other subtle changes
here is good website for any parts -:
http://www.ereplacementparts.com/kawasaki-fh641vas04-stroke-engine-parts-c-30157_30211_32002.html
cheers pauly46
May 22, 2011 | kawasaki Fh641v 21hp 21 Hp Riding Lawn...
Continues blowing out white smoke after I start the lawn mower
Hik marie carten...
Normally white smoke coming out of the exaust will me one of two things.
You have overfilled the crankcase with too much oil and it is making the smoke, in which case you can drain the excess oil out and that should elimanate the white smoke.
Or, you have a worn out engine and oil is getting by the rings of the piston and being burnt in the combustion chamber of the engine.Which means engine overhaul, or buy a new mower.
Free answer...Please take time to rate me.
May 14, 2011 | Poulan Pro 22inch 625 Series Briggs ...
My Craftlman lawn mower stopped running in the middle of mowing the lawn. Engine YTPXS.1951BA Engine model 143.016722. The rope would not pull and the blade would not move. Checked the dip stick, no oil....
Either the magneto or the off switch is stuck in closed position, If you have dead man's control make sure that it is activated when you go to start the motor.
Apr 27, 2017 | Garden
Poulan 550 Series push mower won't pull start
Hmmmm,,and the plot thickens. Without seeing the unit, i would have to think that when you pull the engine control cable bar, its not releasing the brake that sits against the flywheel. These cables do stretch. Pull the engine cover and you will see the brake against the flywheel. Pull the engine control handle and watch and see if brake is releasing. If its not, replace the cable.
That would be my bet. I hope this is of some help.
May 28, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Oil leaking from under the exhaust mower has been
souds like the carb needs cleand out it has stuck open and let the gas run in to the moter
Nov 05, 2009 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Engine started smoking real bad, it still starts
Could be just a head gasket, also could be rings. Could also be oil in the gas or bad gas overall. Empty out the gas, change the oil, and try again. If it does the same thing take it to service shop.
Sep 29, 2009 | Poulan Pro " Pro" Self Propelled Mower
I can't locate the timing marks on engine model YTPXS 185 BB / 143.003504 it is a tecumseh 4hp craftsman
what timimng marks do you refer ? the crank and cam are marked on the inside at the gears internally? the flywhell has a key? searsparts.com has exploded veiws
Aug 26, 2009 | Garden
6.75 Craftsman Eager1 Lawnmower, My son had this mower given to him,after cleaning the carb,plug,air cleaner etc. I noticed a black rubber tube entering the top of the motor at the back, upon starting the...
Go to parts www.searspartdirect.com and put in the model # and it will display all the parts that are supposed to be on the mower. Whatever you are missing just order from them.
May 16, 2009 | Garden
Poulan PO175H42STB lawn mower operator's manual
Check searsparts.com web site type in your model you can most likely get what you want
May 06, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan "Poulan" Push Mower Logo
261 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
