ER appears on panel, can't eject discs, #4 disc doesn't appear on the panel, all others flash. 4-7 have discs, cannot eject. I turned player off and on per manuel troobleshooting, no change.
MB 4s 7 disc cd changer - tray stuck ER notification on panel. All except for disc 4 #s of discs on panels flash. Turned off and back on - no change. 4 discs loaded (4 thru 7) cannot eject.
I shook the cd player until the disc which must have been stuck slide back into its tray.
Posted on Apr 20, 2009
How to update firmware for vizio vbr100
To update the firmware for the Vizio VBR100 Blu-ray player, you need to download the firmware package to a computer with a CD-R or other optical disc burner. The firmware is a .zip file. Next extract the contents of the compressed folder to see the .ISO file. Use the computer program to burn the ISO to CD. Windows 7 and later included this type of program (right click on the file and choose Burn disc image). For other systems, you need a program that can burn image files to disc. Nero Burning ROM is one such program.
Now make sure that the player does not have an optical disc in the unit and turn it off. If possible, plug the Blu-ray player into an UPS (battery backup). Turn the player back on and wait for the No Disc message. Press Eject to open the disc tray and put in the CD with the firmware. Close the disc tray. The Loading Disc message should appear on the screen followed by the firmware screen. Press Select on the remote to start the update process. (Use the down arrow followed by Select to cancel the procedure.) Wait for the update to finish; you do not want the power to go off during this time. The disc tray will open when the "Success" message is displayed. Remove the CD and press Select. The unit will restart. To check your firmware version, turn on the Blu-ray player with no optical disc in the tray. When you see the "No Disc" message, press eject to open the disc tray. Press the digits 7 8 0 4 in order on the remote. Look at the Revision number of the firmware.
Note: not all versions of the VBR100 can have the firmware updated. Also, Vizio no longer supports this model. There are some third-party sites that claim to have the file. Use caution; suspicious code can be added to the file by various parties.
I hope this helps.
Aug 04, 2016 | Vizio Televison & Video
How can I unlock Samsung HT-H4500R
1) Turn on the player with no disc in the tray.
2) Open then close the tray, wait to see the No-Disc Message
in the top Left Corner.
3) Now press the REPEAT button on the remote, followed by a
five digit code. eg. 57538 if you have a region 2 player.
4) When it works a 2 (your current region) will appear in
the top left corner.
5) Press 9 to make it region less.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all
regions of DVD/BD Disc.
Here is a list of all the region codes:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
Aug 25, 2014 | Samsung Televison & Video
I am having a sony blue ray dvd home thatre bdv e280 bought from switzerland and I came to India which I wan't to play some dvd's bought from India which is is blocked of region code. How to unlock the...
Works with most Sony Players
Step 1
Unplug the power cord of the Sony Blu-ray player. Plug the power cord back in. Turn on the Sony Blu-ray player. Turn on the TV to which the Sony Blu-ray player is attached. Wait for the "No Disc" text to appear on the front of the Sony's LCD display and on the TV's screen.
Step 2
Press the "Eject" button on the remote control. Wait for the disc tray to eject itself from the front of the Sony Blu-ray player.
Step 3
Press the "Disc Info" button on the remote control. Look for a number to appear on one of the upper corners of the screen of the TV.
Step 4
Press the "Disc Info" button repeatedly until the number "9" appears on the TV's screen. This number indicates that the Sony Blu-ray player is now set for "multi-region" and will play any Blu-ray disc that is commercially made.
Step 5
Turn the Sony Blu-ray player off using the remote control. Turn the Sony Blu-ray player back on using the remote control. Press the "Eject" button on the remote control to close the disc tray. Turn the Sony Blu-ray player off using the remote control.
Dec 28, 2017 | Televison & Video
My sony dvd player will not allow the tray to eject. when the eject button is presses "tray locked" appears on the screen
Follow this procedure to lock and unlock the disc tray.
IMPORTANT: This procedure will only work while a disc is inserted in the player and when the disc is playing.
While a disc is playing in the Blu-ray Disc player, press the SYSTEM MENU button on the remote control.
After the System Menu screen appears, slowly press 0 0 0 0 7 6 6 9 using the number pad on the remote control. NOTES:
If the procedure has been performed correctly, the disc will stop playing and the player will go in the Resume mode. Each time this procedure is performed the disc tray will either lock or unlock.
Jan 02, 2011 | Sony BDP-S300 Blu-Ray Disc Player
REGION 2 DVDS ON REGION 1 PLAYER
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 29334
4) When it works a 1 will appear in the top left corner
5) Press 9 to make it regionless.
9) Now power the unit on again, it should now read all regions of DVD Disc.
Enjoy
Jul 18, 2009 | Samsung DVD-1080P9 DVD Player
Jensen hd5112 error 2
CD Changer Error Codes: If problems arise during CD changer operation, the following error codes may appear in the display:
ER-1: No magazine loaded.
ER-2: Problem in the disc loading function.
ER-3: Error in the disc loading function.
ER-4: Error in the disc unloading function.
ER-5: Error in the magazine position.
ER-6: Error in the laser pickup position.
ER-7: Error in the laser focus on the disc.
Dec 21, 2008 | Car Audio & Video
Stuck cd discs
I think there are a couple of faults here. The first one is maybe a faulty motor on the eject mechanism. The second one is a faulty laser unit as it is not scanning the disc. Hope this helps.
Jul 25, 2008 | Sony RCD-W500C 5-Disc CD Recorder
135 people viewed this question
 Grubhead
Grubhead
