Question about Compaq Evo T20 - 128mb Flash (305253001) Network Terminal
Compaq T20 printing
We have a number of Compaq T20 thin clients. In the past we have been able to attach printers to these units. Newer printers are not specified in the list of available printers and using drivers for older models has not worked. How do I install a printer? The installed printer will only be used for local printing - ie not shared.
  • 82 Answers
Dear you will have to make a print server then you can share you printer,install the printer driver then access from client computer then you can use both printers
Posted on Sep 20, 2007
SOURCE:
Can i print lyrics
1) Copy, then paste the lyrics to Windows Notepad.
2) Top left of notepad click "File", from the drop sub-menu click "Print".
3) This will open your default printer client, follow the onscreen instructions.
May 12, 2016 | Compaq Computers & Internet
Zebra LP 2824 Plus Giving Endless Labels
OK where is the print spooler on the remote client or the server. Have you check whether this is clearing and not an issue with your remote setup and not the printer does the printer work correctly attached directly to the server break the problem down in stages
Dec 07, 2012 | Zebra LP 2824 Plus Thermal Label Printer
After giving the print to immage runner 400s copier the print sends to the copier. The data button blinks once. but print out automatically cancels. why?
Windows Server 2003/Thin N Computing thin client L300 Printer Epson FX2175 installed with thin client when dos base print command is given 1st page is printed but when 2nd print command is given printer gets offline either switch off printer before giving comman or print from printer properties. Again third page print command is taken by printer (For alternate pages print command printer gets offline automatically)
Aug 29, 2012 | Canon imageRUNNER 400S Copier
How can you configure Zebra printer 105sl (over network) to print labels in IE and have a regular printer from reducing the document size from a thin client?
I have this issue whenever I set my default printer to a label printer. Use the other printer as the default and set to the zebra only when you need it.
Dec 07, 2011 | Zebra 105SL Thermal Label Printer
I have ncomputing L300 thin client with usb port. I attached Cannon Laserjet LBP2900 to thin client usb. also installed drivers on host. printer is detected & shows printer ready. but when i give...
Since you posted this four months ago, there has been some major updates from NComputing to improve the USB architecture. This should improve support for peripherals such as your printer. Download the latest software for either W2K3 (v4.9.5) or W2K8r2 (v6.1.3) and update your system. Lastly, it is critical, and I mean absolutely critical, that you update the firmware on the L300 as well. The firmware is included with the vSpace update so once the host is updated, go to the L300 and tell it to update the firmware. The current firmware version that works with v6.1.3 or v4.9.5 is v1.4.1. As of this writing, 8/16/11, those are the current versions.
Apr 21, 2011 | NComputing L230 Network Terminal
Bought a used T20, is there a way to just plug this into a switch and getting around the Compaq Connection Manager?
One of the computer within a company does not work as displays the out of frquency error. Enginear is unable to detect in normal mode what should be done in this situation explain
Nov 25, 2009 | Compaq Evo Thin Client T20 (289079-001)...
I forgot the Administrator password, how can I still access my client thin system.
Here is a download that will solve your problem It costs $39, but considering what's at stake, it's probably money well spent.
http://www.lostpassword.com/windows.htm
Sep 16, 2009 | Compaq Evo T20 - 128mb Flash (305253001)...
I have mtnl garuida -fw modem, but i have no driver for this, so plz tell me how can i download driver, from where???????or what is link
elaine.teleport.com/%7ecurt/modems.html
www.drivershq.com/drivers
www.k56.org
www.itu.ch
www.chipset.com
TYPE IN THE FOLLOWING INFORMATION IN THE ADDRESS BARS:
HP COMPAQ EVO T20 NETWORK TERMINAL DOCUMENTS
HP COMPAQ EVO T20 NETWORK TERMINAL DRIVERS
HP THIN CLIENT T5135 NETWORK TERMINAL DRIVERS
HP THIN CLIENT T5135 NETWORK TERMINAL DOCUMENTS
HP THIN CONNECT RK271AA#ABA DOCUMENTS
HP THIN CONNECT RK271AA#ABA DRIVERS
HP E104
HP DK407AABA
HP 700/70 DRIVERS
HP 700/70 DOCUMENTS
HP 700/70 INFORMATION
I HOPE THIS CAN HELP YOU, BUT I MAY OF MADE MORE WORK THAN HELP
CANDYMANGANDY
Mar 07, 2009 | Computers & Internet
Compaq Evo T20 - Performance sluggish
its 16 years old now.
is this the only slow client.
after all a terminal server always serves many, not one.
if only 1 client is slow that it needs work.
what can that be,?
well , check that all software in the client are fresh and clean.
reload it?
like NIC card, driver , try another port on the router to the slow
client.
to the full reset yet and reload all software and re configure
it per the manual>?free it is, and very OLD.
https://www.manualslib.com/download/359290/Compaq-Evo-T20.html
id say the client has issues if the mouse is slow, all the time.
Dec 25, 2017 | HP Compaq Evo t20 Network Terminal
Compaq Evo T20 - 128mb Flash (305253001) Network Terminal Logo
150 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
