Question about Dryers
The dryer is 3 months old and recently it stopped in a cycle and showed "PF", I checked the circuit breaker and it was ok. Finally after several times it reset and went back to drying except after on a normal cycle it jumped up to 62 minutes...I think a sensor is going bad, does this sound right?
  • 77 Answers
PF usually refers to a power failure. You may have a loose connection. Unplug the dryer and check that all terminals are tight. That may confuse the board. If that is doesn't do it, your probably on the right line about the sensor.
Posted on Apr 17, 2009
My whirpool dryer panel comes on but when you push the start button!, it clicks off and then displays the pf code.
PF is a Power Failure error meaning electricity has been interrupted to the machine.
Any electrical interruption to the machine such as a circuit breaker being reset or weather related power outage can cause a PF error code.
To remedy;
Press the Pause/Cancel/Stop button twice to clear the PF in the display.
Try to start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button.
If you continue to receive the PF error code, the control board may need to be replaced
Apr 23, 2015 | Dryers
I have had my Kenmore HE2 dryer for a little over a year. Recently, I am getting a "PF" in the display and the dryer stops after the dryer is on for a short time. This happens 3 out of 4 times...
PF is a power failure code. Try turning the breaker completely off and back on again. If it continues to happen you may want to call an electrician as your circuit may not be able to handle the strain which could be potentially hazardous.
Apr 05, 2011 | Kenmore Dryers
My bravo steam dryer is showing an F1 code, and I can't get it to start
this is a control board issue, you may be able to clear the fault using these steps:
1) Unplug or turn the circuit breaker off for 30 seconds.
2) Plug the dryer back in or turn the breaker back on.
3) Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
4) Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
If it will not clear then you will need to replace the control board, Good Luck Tim
Mar 05, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My Frigidaire dryer will not start. It shows a PF trouble code. What does this mean?
PF is showing you that there is a power problem. Check your dryer circuit breaker at the power panel. This can be a sing that one of the 2 breakers has tripped. Push the CB hard to OFF and then back to ON. Then try and start your dryer. If that does not work just respond here and I will help you.
Try selecting "No Heat" after resetting the CB and see if the dryer starts. If it does you could have a bad heating element that caused the breaker to trip to begin with. Sometimes when the heating element fails the broken link will contact the chassis and cause the CB to trip. Heating element failures are usually caused by poor airflow. You may want to look for any signs of lint in your dryer to include the lint filter area and all the way to the outside wall exhaust point.
Kelly
Oct 01, 2010 | Frigidaire Electric Dryer
The dryer works, but dont heat, and apears the PF on the display
Hi
Error PF means power failure, it appears when the dryer is unplugged or when an intermittent power failure is observed by the dryer. If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 15, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Power Failure without tripping breaker
Sounds like an overheat code tripped due to obstruction in the exhaust. There is also a vent tube on the bottom of the dryer that could be loose.
Jul 27, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I just plugged in the dryer it has a "PF" message and won't do anything, unplugging dosen't change anything....
Pf is power factor. It is showing you there was an interuption of power. Some models you have to wait at least 3 minutes before you can press stop / pause / cancel to clear the PF. If you still keep getting PF go to the main CB panel and turn off the Dryer CB by physically pushing to breaker to the OFF position to reset the breaker then back to on. You will have to wait again before you can clear the PF. If after resetting the breaker you still get the PF in the display you may have to find out what power you actually have at the outlet. 115V or 230V. Other factors come into play also like 3 or 4 prong connections vs the previous connection. They do make a difference and if the power cord was installed incorrectly the PF will never clear until the cord is connected correctly.
Thanks for using FixYa.
Kelly
Mar 07, 2010 | Dryers
Won't run, shows code PF
Well the code pf means power failure, check your cord and see if it connected ok. make sure you didn't blow a breaker in your powerbox.
Apr 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer kicks off circuit breaker, pf code is on dryer. now won't let me do anything
pf is for power failure. sounds like You may have a short somewhere. Be careful of electric shock.
Apr 21, 2009 | Dryers
Kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Dec 24, 2007 | Kenmore 67082 Electric Dryer
Dryers Logo
74 people viewed this question
Top Dryers Experts
