Cant work out how to use the two tuners to record and or watch two channels at once
I've recently got a kworld dual digital tv tuner card, PE355-2T with arcsoft total media software for my pc and I Cant work out how to use the two tuners to record and or watch two channels at once. When I set a recording and then tried to watch a another channel the recording was cancelled
    Problem Solver:
  • 28 Answers
You might only be able to watch this in a dual monitor type setting good luck
Posted on Aug 07, 2009
Why cant I change channels when recrding 2 progs?
Hello Anonymous,
You did not specify if you are using a DVR capable cable/satellite box, which I what I presume is the case.That DVR has two tuners in it - each tuner allowing you to watch and/or record two programs at one time and in any combination.If both of those tuners are used for recording then you cannot watch another "live" stream as there no available tuners to tune and display (or stream to the DVR hard drive for recording). You can only switch between the two recording programs.
As a side note, if your TV has a built-in tuner, you can split the cable and have one going to the DVR and the second run going to the TV set. You can then use the TV's built in tuner and watch what anything it can get. It won't get scrambled digital cable but will get analog and Clear QAM channels.
Feb 15, 2015 | Televison & Video
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
How can i watch the tv from philips tv tuner card tuner
First step is that you have to install the Philips TV Tuner Driver that suits for your PC Operating System.
Second step, Install the TV Tuner application that came along with CD driver when you bought the TV Tuner, connect TV antenna into TV Tuner, Run the Application, search for TV channel, autosearch will automatically save the channel. All features including recording the TV programs and save them into the harddrive is on the TV Tuner Application features and good luck
Dec 10, 2010 | Philips TV Tuner Video Capture PCI Card -...
I purchased a MDR513h/f7 hdd & dvd Player/recorder for my cable TV. I can not watch one channel while recording another. Comast said I must have a dual turner and that is what I purchased (I think)....
This model has only one tuner, I'm afraid. You can only watch one channel at a time, unless you split the cable signal going into it. One side goes to the recorder, the other to the TV. Then you use the single tuner in the recorder to record and the TV's tuner to watch the other channel.
Sep 12, 2010 | Philips Magnavox DVD/VCR Dual Player
I have a new digital tv in which i use an antenna to watch it. i hooked up the vcr to it but i cant get it to record the tv show i want recorded.
Your VCR most likely does not have a digital TV tuner. Therefore you must supply a digital TV input signal so you can record it. Unless your TV has a composite video output, you would need another box, namely a digital TV tuner/converter which would connect to the VCR's input. Select the channel to record on the tuner/converter and select on the VCR the input where the tuner is connected.
Aug 14, 2010 | Sony SLV-N71 VCR
Recording on a STB and being able to watch a DIFF channel.
It is possible to record a channel and watch a second channel. If your cable vision has digital-only signals, you will need a Digital tuner or a second cable box.
If your cable has conventional channels still, you can buy a splitter and run the cablevision to the TV and the CableBox at the same time.
Switch to the TV tuner, you see cable.
Switch to the recorder (connected to the CableBox) and you see what you can record.
Mar 28, 2010 | Televison & Video
On comcast i cant tape 2 shows and watch another
You can tape 2 and watch one that is recorded, it has a dual tuner to record 2 shows. you can record one and watch another channel at the same time.
Hope this helps
May 05, 2009 | Directv (R10) DTV Receiver / 70-Hours...
I have no driver to get it ready for work
Look here for your drivers
http://us.kworld-global.com/main/support_down.aspx?mnuid=1312&modid=21
Apr 24, 2009 | KWorld PCI TV/FM Tuner, DVD Maker Card,...
Our Dvr will only record on the channel we are watching. I cannot watch one show and record another? It says I have to be watching the channel I want to record?
for the dual tuner, if you are unsure what this is... please look at the back of the satellite box and see if you have 2 sat in cables. if you do, then you need to reprogram your satellite. if you do not have 2 sat in cables then you would need to contact dtv to get this installed.
Mar 29, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Configuring I/O cable box, VCR, DVD.
Unfortunately you would need a second digital cable tuner to do what you are trying to do.
The digital tuner only outputs one channel at a time, selected by that box, so you can only record or watch that one channel at a time.
Many people are switching to dual tuner DVR's to cure this dilemma.
Feb 17, 2008 | Televison & Video
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
