Canon ip4300 service error b200 green and orange light keep flashing ink toner won`t move
  • gggggggggg Apr 30, 2009
    mine has same problem, but its still flashing 10 amber with printhead out
  • Anonymous May 07, 2009
    error b200
  • 14 Answers
Try this:
Pull the power cord out of the back of the printer.
Then move the printhead to the center and pull out the ink and the printhead. Clean the printhead and examine the bottom for burned areas.
With the printhead still out, close the cover and plug the power in and turn the power on. If your printer isn't damaged, it should go through all diagnostics and give you a solic green light. This means you probably need a new printhead.
Posted on Apr 17, 2009
Flashing green orange lights
There is many reasons for that,
are you printing any thing???
Just restart the printed and see if lights turned off....
Jan 20, 2014 | Canon PIXMA iP4300 InkJet Photo Printer
IP2770 EROR B200
If your all cartidge is not fully loaded on ink than showing the error.
Dec 09, 2010 | Canon Pixma iP2700 InkJet Photo Printer
I keep getting a service error B200, and the lights flash green and orange alternately. How can I fix this?
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Jun 07, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
My is not working & shows an error code B200.
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 25, 2010 | Canon Office Equipment & Supplies
Canon IP4300 flashes orange and green
Oct 25, 2009 | Canon BubbleJet i560 InkJet Printer
Ip 5300 error b200 10 blink orange-green
Sep 26, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
Canon ip5300 b200 error message unplugged and replugged lights still flashing between green and orange pulled all printer cartridges no resolve
Jun 16, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Ip4300 canon pixma
I have the Canon Pixma iP4000R printer. I had an error code of a600 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Nov 19, 2008 | Canon PIXMA iP4000R InkJet Printer
Ink tank lamps - the magenta horror
Call Canon, this is a chip error on the ink tank itself, they replaced mine.
Jan 27, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
11,270 people viewed this question
k24674
jasbo
jasbo
