Question about Fantom Drives 120 GB Hard Drive
Fantom Drive won't spin up
I have a 160 Fantom Drive that I use with my Mac that gives a steady red light. If I take the drive out and unplug the drive I get a steady blue. Is the drive fried?
JoAT
  • 121 Answers
SOURCE: Lost my Fantom Drive Icon
As this question is a little vague...Here is a link to the Fantom website (Mac Issues): http://www.fantomdrives.com/support/faqs/hdfaqmac.php4
Posted on Mar 23, 2007
  • 7 Answers
SOURCE: Fantom 160GB Har Drive power light alternating btw red and blue
Have you tried running a search from your start menu (in Windows XP, Vista)? If not, go there and then use the drop down line at the top of the window. It should register what drive is plugged into or hooked up to your computer.
Posted on Mar 23, 2009
SOURCE: how does a external USB SATA drive dock
The Solution: ... IT WORKS REALLY ...
Point 1: Remove power from the mains.
Item 2: The device from your PC, remove the USB plug.
Point 3: The USB Titanium External Hard Disc Enclosure Open, just the screws of the housing, with a special wrench to open.
The drive from the connector of the USB connector for one minute to remove, then the hard drive with the connector of the USB connection,
connect together.
Point 3: The hard disk into the housing insert all the screws screw.
PLEASE precisely again check that all connections are properly connected.
Power to the drive plug the USB connector from the HDD to the PC or notebook is already running and the hard drive, as before, during initial installation of the device.
So everything supper dooper easy ...
Posted on Jun 27, 2009
bruce508
  • 44 Answers
SOURCE: fantom drive is not being detected. Shows a solid
Since you've already tried different cables and computers, that eliminates a lot of things. Are there any configuration switches?
Possibly a cable or connector has come loose within the unit, particularly the edge connector that connects to the drive itself. If the unit is under warranty, try that first, espcially if you don't have important files that could be lost on the drive if you had to send it in for repair or replacement.
If you open it up, re-seat the connectors --- push them firmly into the drive PC board. If possible, remove each and put it firmly back into place. If that doesn't fix it, something is probably burned out and it is probably not something one can handle without access to factory replacement parts.
Posted on Sep 19, 2009
  • 14 Answers
SOURCE: Fantom hard drive red light!
There are no drivers for this unit. It is a plug & play unit that is one of the worst Fantom has ever offered. Very unreliable and many power cord problems.
I tried for several weeks to find the drivers over the net and researched a ton before I called Fantom Tech Support. The number is posted on New Egg under the their Mfg contacts
Posted on Oct 17, 2009
Doesn't show on my mac
So, it appears this drive is a real phantom to your Mac.
If you notice, the internal harddisk of this device will spin up, then you should verify if this drive also is invisible at another computer.
If it does, then something might be wrong with the drive, otherwise it might be related to a driverproblem under Mac OS.
A driver is a type of program which tells your computer how to communicate to hardware-devices. Each device requires it's own communication-protocol. If this is not done well, it's like ,.. erm,. see it as you're on a holiday abroad. You try to speak French to an German cab-driver. It might be hilarious, but you don't understand each other and you won't get to the place you want to go to..
Oct 15, 2013 | Fantom Drives Titanium (tfdf16072) 160 GB...
Use my drive on Mac..
Both OSs have different Security Architectures. NTFS for Windows and HFS+ for MAC. So if you modify these permissions (you could) your MAC OS might not be able to access it properly. But MAC will read NTFS permission (But not write onto the disk).
Jul 11, 2010 | Fantom Drives 300 GB Hard Drive
The hard drive does not appear on my mac
I would check the usb connection. Try your drive in a different usb on your mac, see if that works.
Apr 25, 2010 | Fantom Titanium Hard Drive
I have a Fantom Drive Titanium External USB 2.0 Hard Disk Drive. All of a sudden the drive in gone. I tired to unplug everything & redo but nothing appears. It does not have a disk. It is a plug &...
Hello
If you turn on the drive can you feel that the drive starts spinning? Can you feel movement and see a light flickering?
Does your computer acknowledge that there is something plug in when you plug in the Drive? Does it give you a notification, or does it make a sound?
If so, then this simple setting just might fix your problem.
Just follow these steps and you should be set.
Go to:
Start
Control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your drive in the schematic below.
Right click on the drive and choose to change the drive letter and paths.
Now click on change and change the current drive letter. If there is no drive letter assigned, assign one.
However, if the drive does not spin at start up, there is something wrong with your HDD.
Hope this can be of help.
Kind regards
Andrea
Nov 15, 2009 | Fantom Titanium USB 2.0 250GB 7200rpm...
MY fantom drive TFDU20072 200 gb has worked for years, but today when I turned it on it doesn't show up on the hard drive of my mac. the light is constantly red with a blue flash every second or so. it...
Try the basics first. Unplug and let sit for a while before rebooting the drive. Then if nothing, get a copy of Disk Warrior and you may be able to regain access to the drive in order to save your data.
Aug 15, 2009 | Fantom Titanium Hard Drive
500 GB Fantom Drive not recognized on either of my Macs. Tried Firewire and usb; blinking light turns to steady red.Worked fine for about 2-3 years.
The symptoms don't look too good. Looks like the host controller is querying the hard disk (blink) and not liking the answer - or lack thereof (red).
It looks like the internal disk is defective. Sometimes the disk can be (possibly partially) recovered by disassembling the enclosure and mounting it in another enclosure or directly inside a compatible desktop PC.
Aug 14, 2009 | Fantom Drives 120 GB Hard Drive
Fantom 120 gb external usb harddrive
Make sure you are using the right power unit, or the power unit is working.
May 13, 2009 | Fantom Drives 120 GB Hard Drive
FULL fantom external usb harddrive is not acknowleged after power outage running check disk.
ACS Data Recovery specializes in Fantom hard drives, and can perform successful recoveries on any model Fantom hard drive. If you have a crashed Fantom hard drive, please call us today to get a quote: 1-800-717-8974
unless you fancy trying to connect the drive inside the unit directly to a pc by taking the box a part.
Jul 18, 2008 | Fantom Titanium Hard Drive
Blinking Lights
I had this EXACT same problem. Blinking blue light and the hard drive never powers on. VERY frustrating...I have a home studio was in danger of losing over a year's worth of original music. However, this problem has a solution which I read about on this site:
"The problem was with the power source not the actual drive so I ended up pulling the drive out of the case and purchasing a new case from Newegg.com. It now works fine and only cost about $30 to fix."
This is EXCELLENT advice and FixYa is the only place I read about this solution. Though I'm no newbie with computers, I certainly had never swapped out an external hard drive. But, in 30 minutes for about $30, this problem is TOTALLY SOLVABLE. I went to newegg.com and ordered this product:http://www.newegg.com/Product/Product.aspx?Item=N82E16817106095
an external Azio hard drive enclosure. Because I always used Firewire hard drives, I got an enclosure that accepted Firewire---however, many others are available with just USB 2.0. Following the directions that came with the enclosure, I removed my blue-light blinking, non-functional hard drive from its enclosure and placed it into the Azio. Now, the unit is working fine. No datawas lost and the Azio drive seems to be working properly.
THIS IS A FANTOM HARDWARE PROBLEM---NOT SOFTWARE PROBLEM! I encourage the MANY people who have complained about Fantom drives and gotten no assistance to try this solution and avoid Fantom in the future.
To whoever posted this solution: thanks a million. You made my day.
www.ediesedgwick.biz
Dec 24, 2007 | Fantom Drives 120 GB Hard Drive
Mar 23, 2007 | Fantom Drives 120 GB Hard Drive
Fantom Drives 120 GB Hard Drive Logo
253 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
