Question about Asko W6441 Front Load Washer
Asko washer 20004
Washer leaks during spin cycle. What could be the problem and is it worth fixing?
  • jdesjr1 Mar 24, 2009
    My 10505 washer does the same thing and i can see it comming from around the v ring but i cant pull the drum apart do i need a puller to get the berrings off.
It could also be a leak in the hose that connects to the pump, toward the front.
Posted on Apr 04, 2008
  • 126 Answers
Could be a leak in the 'V' ring at the back of the drum. Or a object have damaged the outer tub.
Posted on Jan 24, 2008
  • 175 Answers
Where does the leak appear at?
Posted on Nov 06, 2007
SOURCE:
After 23 years of good service the drum has fallen off at one side. Is it worth fixing or buy a new one?
HAS SHOCK ABSORBERS WHEN THEY GO BAD ONE SIDE CAN LEAN ALSO CHECK FOR BAD OR LOOSE BALANCE WEIGHT. LOCATED NEAR THE MOTOR.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Jan 28, 2014 | Asko W6221 Front Load Washer
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
Asko washer 20004 stopped mid cycle, water is
Do not play with water and 240volts or 120 volts....it is a LETHAL cocktail.
Get a techo to save you the headache and possibly YOUR LIFE!
Oct 19, 2009 | Washing Machines
I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
Oct 19, 2009 | Asko Washing Machines
My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Aug 02, 2009 | Frigidaire ATF6000ES Front Load Washer
ASKO washer WL6511XXLPP
Purchased ASKO Washer WL6511XXLP and Gas Dryer with pedestals, 12/01/09. It threw a drum paddle during 2nd. wash cycle. Damaged several articles of clothing.
ASKO replaced the paddle 2/19/09 after a lot of phone calls (lip service from the ASKO 800 #). They claimed the part had to come from Sweden (reason for delay).
Washer threw another drum paddle during 4th. wash cycle. Damaged several more articles of clothing. We have made no claim for the damaged clothing, the retailer has been cooperative.
ASKO has promised to replace the washer after the retailer we purchased the washer from, strongly encouraged them to do so. We are still without a washer (03/23/09). My wife and I are retired, I am 76. Point being; we do not abuse washing machines and we don't like going to a launder-mat.
I know this is not the venue to address this problem, but am at my wits end.
Mar 22, 2009 | Asko WL6511W Front Load Washer
My Asko W620 washer won't spin the first time through.
Try Googling (asko)(W620)(manual) without parens.
Jul 22, 2017 | Asko W620
Water leaking
If the water is leaking at what seems like the beginning of the spin cycle it might be the hose connection to the drain pump or the pump itself. If so, it's a lot easier to fix than the drum seal.
Dec 31, 2007 | Maytag SAV5701A Top Load Washer
Asko W600 spin cycle not working
Check the brushes oin the motor. It's the most normal fault when this problem appears. Not a big thing to fix for a technician!
Sep 24, 2007 | Asko W640
Washer spin when in wash cycle
the problem is specifically the motor tacho which consists of a rotating magnet screwed to the motor shaft and a fixed coil around the magnet. the problem can be the magnet unscrewed or the coil fallen out.either way, they can usually be repaired by glue or packing.
Nov 07, 2006 | Zanussi FJ1454W Front Load Washer
Asko W6441 Front Load Washer Logo
247 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
