Question about Nokia 7610
Repair no signal for globe , smart ok
  • redwolf875 Nov 12, 2007
    no signal for globe but if its smart its ok.. wat could have caused dis and whats d solution?? i tried network search and others but still i cant get a signal from globe
  • Anonymous Dec 07, 2007
    my problem is contact service in the ligth blink.i dont know to repiar this
My mobil nokia 7610 some time tower problem plz replayl solution
Posted on Mar 05, 2008
My 7610 has no signal when i change a lcd after that no signal
Posted on Apr 22, 2008
SOURCE:
Di ako makapagfb using myphone Q19i...paano po b dapat gawin para makakonekta ako gamit ko ung cp n un? ty.
APN Settings for Globe, Smart, Sun, WeRoam Cellular
The following settings are applicable to Smart, Globe and Sun Cellular for their APN settings (Access Point Name). The settings should work with majority of smartphones in the market.
Postpaid APN: internet.globe.com.ph
Prepaid APN: http.globe.com.ph
APN Settings for Smart Bro
Postpaid APN: smartbro
Prepaid APN: smartbro
APN Settings for Smart Buddy, Smart Gold
APN: internet
APN Settings for Sun Cellular
Prepaid
APN (static): minternet
Authentication: PAP
IP address: dynamic
Postpaid
APN (static): fbband or minternet
Authentication: PAP
IP address: dynamic
APN Settings for PLDT WeRoam
Postpaid: WEROAMPLANor internet
Note: If you’re using a variety of postpaid or prepaid SIM cards in one dongle, make sure to create a Setting Profile for each SIM card so it’s easier to set the APN when switching SIM cards.
Leave all other settings blank or as is.
Mar 05, 2014 | Computers & Internet
No taillights park or dash lights
check park/tail fuse regarding dash ,park ,tail problem .brake light on passenger side is probably the brake globe needs replacing .Turn signals on passenger side could be globes or switch,check globes first ,if globes and fuse are ok ,may well be the switch especially if park switch and turn signals are on the same switch lever/stalk
Jan 15, 2014 | 1990 Buick Century
How can I update my smart globe? I bought my smart globe in Nov. 2010. Since than I uddated the globe twice in english. Now I want to switch into german language but when I put in the smart globe disc,...
Simply subscribe online using the SmartGlobe™ Infinity software. There is no response when I touch the SmartGlobe™ Infinity with the SmartPen or the LED on the pen is flashing repeatedly.
Smart Globe will filter your results and update with current version App of SmartGlobe.
Apr 25, 2017 | Cell Phones
Manual configuration of my "MY
Manual Configuration for Globe Subscriber:
GPRS Settings
GPRS Data Account 3 Account Name: myGlobe MMS Access Point Name (APN): mms.globe.com.ph GPRS Data Account 4 Account Name: myGlobe GPRS Access Point Name (APN): www.globe.com.ph WAP Network Settings
Rename Profile: myGlobe WAP Homepage: http://www.globe.com.ph/globe.asp Data Account: myGlobe GPRS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
MMS Network Settings
Rename Profile: myGlobe MMS Homepage: http://192.40.100.22:10021/mmsc Data Account: myGlobe MMS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
Manual Configuration For SMART subscribers:
GPRS Settings
GPRS Data Account 1 Account Name: Access Point Name(APN): GPRS Data Account 2 Account Name: SMART GPRS Access Point Name(APN): Internet Exit and save settings WAP Network Settings
Rename Profile: Smart WAP Homepage: http://wap.smart.com.ph Data Account: Smart GPRS Connection Type: HTTP Proxy AddressL: 010.102.061.046 Proxy Port: 8080
Rename Profile: Smart MMS Homepage: http://10.102.61.238:8002 Data Account: Smart GPRS Connection Type: HTTP Proxy Address: 010.102.061.046
Jun 27, 2011 | Cell Phones
No signal
hi there!
this can be due to wrong simcard used or if you're using the right simcard, your telco (at&t, verizon, globe, smart) may be down but if your friends with the same telco say that theirs dont have problems with the signal then repair may be need, to replace the antenna inside of your phone.
Apr 09, 2011 | Nokia N70 Cellular Phone
What is the gprs settings for china phone 9000c blackberry clone for globe provider?
bought a similar unit yesterday blackberry 9000c and Im quite lucky to be able to successfully configure its gprs settings for globe and sun.
You may try this out:
Smart 3G/Internet
  • Connection name: Smart Internet
  • Access point name: internet
  • Username: blank
  • Password: blank
  • Proxy: blank
  • Proxy port: blank
  • Homepage: http://m.smart.com.ph
Smart GPRS
  • Connection name: Smart GPRS
  • Access point name: smart1
  • Username: blank
  • Password: blank
  • Proxy: 10.102.61.46
  • Proxy port: 8080
Smart MMS
  • Connection name: Smart MMS
  • Access point name: mms
  • Username: blank
  • Password: blank
  • MMSC: http://10.102.61.238:8002
  • MMS proxy: 10.102.61.46:8080
If you're too lazy to manually tinker with the settings, however, you could opt to text SET to 211 and follow the instructions. It'll cost you, though, and you'll need to key in a PIN (1234).
Once you've entered the values stated above, you'll need to activate them. To do this, simply text MMS ON and 3G ON to 333.
Sun 3G/Internet
  • Connection name: Sun INTERNET
  • Access point name: minternet
  • Username: blank
  • Password: blank
  • Proxy: enabled
  • Proxy port: 0
  • Homepage: http://www.suncellular.com.ph
Sun GPRS
  • Connection name: Sun WAP GPRS
  • Access point name: wap
  • Username: blank
  • Password: blank
  • Proxy: 203.138.159.78
  • Proxy port: 8080
Sun MMS
  • Connection name: Sun MMS
  • Username: blank
  • Password: blank
  • MMSC: http://mmscenter.www.suncellular.com.ph
  • MMS proxy: 203.138.159.78
  • Proxy port: 8080
Globe 3G/Internet
  • Connection name: MyGlobe INTERNET
  • Access point name: internet.globe.com.ph
  • Username: blank
  • Password: blank
  • Proxy: enabled
  • Proxy port: 0
  • Homepage: www.globe.com.ph/globe.asp
Globe GPRS
  • Connection name: MyGlobe GPRS
  • Access point name: www.globe.com.ph
  • Username: blank
  • Password: blank
  • Proxy: 203.177.042.214
  • Proxy port: 8080
  • Homepage: http://www.globe.com.ph/globe.asp
Globe MMS
  • Connection name: myGlobe MMS
  • Access point name: mms.globe.com.ph
  • Username: blank
  • Password: blank
  • MMSC: http://192.40.100.22:10021/mmsc
  • MMS proxy: 203.177.042.214
hope this info helps.
Jan 16, 2011 | Cell Phones
No Signal i Some Areas
i have this samsung 821sc phone from japan, twas unlocked and open line but it doesnt have smart signal in our place...it has signal for globe but dosnt have smart?wats the prblem with this? can the experts help me
May 14, 2010 | Cell Phones
Jst want 2 know all 4 digits of globe cp and also
Areas codes are grouped by provider with no single contiguous block of codes for a single provider. These companies and their respective area codes are listed below:
notes:
  • as of Sep 2010 Globe number prefix ends in 5,6,7 except for 907 w/c is a Smart prefix
  • as of Sep 2010 Smart number prefix ends in 0,1,8,9 except for 979 w/c is a Next Mobile prefix
Jan 24, 2010 | Nokia N70 Cellular Phone
My smart globe is speaking in French, how do I change it to Engli
When you initially install the software, you are given a choice of language and age group. I would recommend trying to reinstall the software (which can be downloaded as well) and then make sure your preferred language is chosen.
Jan 05, 2009 | Oregon Scientific Smart Globe Junior
No signal...
reset ur ohone than try
Nov 12, 2007 | Sony Ericsson T637
Nokia 7610 Logo
167 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
