Question about SanDisk Sansa m250 MP3 Player
I am not able to format my Sansa m240 mp3 player. In the windows explorer, I do not see the Sansa m240 - instead I see MTP device. I do not see the format optiion when I right click on the MTP device item in the windows explorer. I am not able to do any operation with this mp3 player in the system now. Can anyone help me in getting rid of this problem? Thanks Sri
  • murthybng Sep 17, 2007
    Thanks for the immediate reply.
    I made the USB mode as MSC instead of autodect, then connected to computer.
    This device is mapped as E: and when I click on the Removable Disk E drive, I get a message box "The deisk in drive E is not formatted Do you want to format it now"? When clicked Yes, it shows the format removal disk (E:) window. When I click on Start button, I get a message "Windows was unable to complete the format".
    So the format is still not working. Plesae let me know anything else I need to do.
    Thanks
    Sri
  • 150 Answers
The below was copyed from an earlier post of mine. Over a period of time your info can get corrupt from transering music back and forth. To format plug it in to usb. Go to my computer It shows up as a removably disc, usually drive f: Right click on drive f: (or the approriate drive) and click format. Let me know what happens, you will have reload the player, also try bypassing the software you are using to tranfer, by opening up drive f: and clicking and dragging your music into it , or you can copy and paste it into drive f: L8R
Posted on Sep 17, 2007
SOURCE:
I dont have a disk or manuel for my sandisk sansa m240 how can i download music to it? I have the usb cord tho.
Follow these steps to drag-and-drop music files to your Sansa player:
1. Connect your Sansa player to your computer.
2. Open Windows Explorer.
3. Double-click on your Sansa player.
4. Double-click Internal Memory if you are using WMP 11 or double-click
Media if you are using WMP 10.
5. Drag and drop music files from your computer to the Sansa player’s MUSIC
folder.
Dec 10, 2008 | SanDisk Sansa m240 MP3 Player
Sansa
Format it in windows explorer and try again by ading in new files.
Sep 01, 2008 | SanDisk Sansa m240 MP3 Player
I have a sansa sandisk mp3 player. when i bought it it was working excellent.but all of a sudden it stopped working.this mp3 has no reset button i do not know how to fix the problem. sansa sandisk...
1. Are you able to turn it on ?
If so, press the the "power on" button the second time to activate the menu.
Still no luck ! Try putting in a new battery and try again.
2. You cannot "reset" anything.
3. Open up "windows explorer"
4. Scroll down the left pane of the window till you see the "sansa" removable disk
5. Right click it and select "format"
6. After formatting, try adding your files back again.
7. Use the >= button on the player tp play the songs.
Hope this has been helpful to you.
Aug 29, 2008 | SanDisk Sansa m240 MP3 Player
How to download the software of SanDisk Sansa m240 MP3
did you try the website, usually they have the software
Jul 25, 2008 | Transcend T.sonic 610 MP3 Player
Formatting sandisk sansa m240
how to download songs and delete the songs
Jul 05, 2008 | SanDisk Sansa m240 MP3 Player
PROBLEME OF MEMORY.
My Sandisk Sansa m240 lost all the songs and then I could not delete them. I was able to laod up new songs, but there was no spare memory. I was able to fix this issue by re-formating.
Using windows explorer right click on the "Sandisk sansa M240" and click "format".
Now working OK.
Feb 20, 2008 | SanDisk Sansa m240 MP3 Player
Sansa m240 not formatting
go to samsung.com go to support and email them
Jan 13, 2008 | SanDisk Sansa m240 MP3 Player
Formatting the sansa m240
You need to switch the player to MSC mode. Got to settings -> USB -> MSC. Then you will be able to format the drive. If it is in MTP mode you can only tranfer files using Media player.
Dec 29, 2007 | SanDisk Sansa m240 MP3 Player
Not enough memory space for music db
Your M240 may have encountered a corruption in its Music Database, and may be corrected by formatting and updating the firmware. Try this: Manually switch the player to MSC mode and format through "Disk Management". Here are the steps: Step 1: Locate the "Hold" switch on the side of the M240 and enable it (you should see an "orange-colored" surface when it's enabled) Step 2: Plug the M240 to your computer (recommended Operating System is Windows XP and above) and check Windows Explorer if the player is detected as a "Removable Drive" Step 3: Open "Disk Management" by right-clicking on the "My Computer" icon, then selecting "Manage" Step 4: Your "Disk Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" Step 5: On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa M240. The lower section also contains the drive # pertaining to your M240. Right-click on either drive letters pertaining to the M240 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. Step 6: In general, Disk Management is more the effective tool for formatting your M240 and assuming the format processing completed without any errors, proceed to updating the firmware of your player. Step 7: Use this link to download the Sansa Firmware updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Save this file to your Desktop and run it while your M240 is still plugged in to your PC. Follow the on-screen prompts. Step 8: "Safely remove" your M240 from your PC and -- with a fresh battery -- power on your player. It should boot up normally. I hope this works. The M240 is a great player
Apr 24, 2007 | SanDisk Sansa m240 MP3 Player
Sandisk sansa problem
This error message may largely be due to the corrupted Music Database file that the Sansa M240 creates to maintain an information pool on the music files downloaded to it. Normally, if you are unable to completely format the player in Windows Explorer, there are still 2 other (and actually, more recommended) options that you have: (1) Switching the M240 to MSC mode and formatting in "Disk Management". You can get to this window by right-clicking the "My Computer" icon and selecting "Manage". Make sure that you use the FAT file system to optimize the 1GB memory (2) Switching the M240 to MTP mode and formatting the player in Windows Media Player 10 or version 11. The mode of the M240 can be changed by accessing the menu and going to "Settings", then choosing "USB" In general, formatting the player in "Disk Management" is more effective than formatting it in Windows Explorer. Also, it would be a good idea to upgrade the player's firmware to the latest version via the SanDisk website: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 I hope this helps. The M240 is a great player.
Apr 20, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
82 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
