The printed page comes thru with white streaks thru print.
  • 3 more comments
  • plainfieldpa Apr 17, 2009
    hplasterjet1006
    hplaserjetp1006
    Thank You!!!
  • Allan Gabston-Howell
    Allan Gabston-Howell May 11, 2010
    Laser printer, ink jet or dot matrix?
  • adi May 11, 2010
    please give me the model and brand of printer you are using.
  • 526 Answers
Try taking your toner cartridge out and shaking it, see if that helps.
also, are you using generic toner. what type of paper are you using?
Posted on Apr 17, 2009
Canon Pixma iP6000D prints white streaks thru the words
Run a self clean on the printer a jet may be clogged. print a test page to see if problem persists. If ink is low put a piece of electrical tape over the sensor of the ink cartridge and try again.
Hope this helps!
Aug 13, 2012 | Canon Pixma iP6000D InkJet Photo Printer
When we attempt to print it leaves black streak marks. At first it printed all black and when we went to setup under maintainence we chose alignment and clean cartridges. This worked however we still see...
If an inkjet printer gives white streaks where it should be black, it means the ink is very low, or there is dirt under the nozzles preventing it from printing properly, or, in the case of non original cartridges, ink might be leaking which prevents the bubbles of ink to squirt onto the page.
If the streaks are black where it should be white, is sounds like some dust or fluff below the cartridge leaves ink smears on the page.
Aug 23, 2011 | Lexmark X4650 InkJet Printer
My canon pixma 480 has thin horizontal lines. tried cleaning and deep cleaning where is the head alignment tool?
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(A) Less noticeable vertical white streaks
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Jan 12, 2011 | Canon Pixma MP480 All-In-One InkJet...
On my Test Pattern 2 the blue/light blue and green/yeallow have steeks in it. The documents that I print have streaks going across the page. I've cleaned everythign I can clean. The printer has 6,251...
SolutionFollow the given steps in the order presented to resolve the issue: Step one: Retry the print jobThe problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality modeIf reprinting did not help, try increasing the print quality mode.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Step four: Clean the printheadsIf the print quality is still bad, clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Open HP Solution Center .
  3. Click Settings , Print Settings , and then select Printer Toolbox .
  4. Click the Service Tab .
  5. Click Clean Printhead , and then click Clean .
Step five: Align the printheads If the print quality is still bad, align the printheads.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
  2. Open the printer Toolbox and select the Printer Services tab.
  3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
  2. Press the Setup button.
  3. Press 1 and * simultaneously.
  4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
    • If the Black block has lines – replace the KY printhead.
    • If the Cyan block has lines – replace the MC printhead.
    • If the Magenta block has lines – replace the MC printhead.
    • If the Red block has lines – replace the KY printhead.
    • If the Green block has lines – replace the KY printhead.
Dec 21, 2009 | HP OfficeJet Pro L7580 InkJet Printer
There is a white vertical streak on pages I print.
You can pull out each cartridge and shake it gently to redistribute the toner. Try a half page test to eliminate the various stages of the image formation. The timing on this is not easy but through trial and error it can be helpful.
Jun 25, 2009 | Cannon MULTIPASS C530 Printer
Not printing properly
1 try printing from the adf feeder
2 try printing from the scanning glass
if from one of the above method has the problem try to clean your optics
if streaks comes from both u might have problem with the following parts
the charger unit- service it
the toner cartrigde- try a new one
the transfer roller - its is a black roller of it becomes white replacement is needed.
May 05, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Streaky print out from canon Pixma mp830 all in one
I just bought a PIXMA iP3500. The 1st 2 photos I printed had veritcal White lines. I did a Nozzle Check and Alligned the Print head after the 1st photo printed. The 2nd still had the lines. Then I changed brands of Glossy Photo Paper and tried a 3rd time. This time I noticed that it printed much slower and it turned out just fine. Information says that you should have the settings at "high" not "standard". Double check that this hasn't inadvertently changed back to Standard. Gator
Dec 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Printing streaks
Sounds like the fuser.
stop the printing before it comes out of
the exit rollers by powering it off.
If half your page is good its the fuser.
Dec 05, 2007 | HP LaserJet 3550 Printer
110 people viewed this question
jasbo
jasbo
