I got one of my buddies laptops trying to fix it for him. It is a toshiba p700. I'm thinking there is something wrong with the screen. I don't know much about computers but when you press the power button, it comes on but you can't see anything on the screen. You can put software in and hear the drive running. The lights come on when you turn it on. That's pretty much about it. Thanks, Becky
  • 526 Answers
One thing you might want to try first, is to connect an external monitor and see if you see things, if you do, most likely your screen will need to be replaced. Probably the back lighting bulbs are burnt out or the inverter is dead.
thanks
Posted on Apr 17, 2009
My Toshiba Satellite C665 Laptop will not start up, when I push the power button to turn it on it does not load or start. On the bottom of the screen it says press F2 go to Setup Utility or F12 to go to...
There is something wrong with your hard drive.. It is not being recognized by your bios. Could be a bad logic board. Get appropriate software and perform diagnostics on it to confirm
Sep 08, 2017 | Toshiba Satellite Laptop with Intel Core...
Re: Well you know if you ever really want it fixed you can do it. Problem: Original Laptop has hinges broke right off taking many plastic parts with it, including part of the bottom case.
it sound like you have a stuck pixel,but need to know what color it is.is it a color streak across the screen or white or what?if it a color mark like red green blue yellow so on those are pixel if it's and you can download a program called dead pixel buddy and run program as instructed.how that help
Mar 21, 2012 | Dell Inspiron 1525 Notebook
Toshiba Satellite A55-S1063. The problem I am have is when I start it up it show the very first start up screen it says Intel something or other in the corner. But anyhow, it shuts down right after I press...
Hi
Try to remove the battery and charger, hold on power button for about 50-60seconds, then plug-in the charger and turn the laptop ON, see what happens.
If it started, unplug the charger, plug-in the battery, and start the laptop again.
For the recovery discs, if the original windows wasn't formatted, you can get recovery discs from windows, using Toshiba recovery media backup.
Please tell us your results
Good Luck
May 15, 2011 | Toshiba Computers & Internet
So I have a Toshiba satellite M505-S4940 laptop and my laptop wont power up. the lights come on but no display. I was told that the graphics card was damaged just by telling someone what I had told you via...
Your laptop uses an Intel chip for the video, with the option of an NVidia chip. If you took the option then the diagnostic is correct - the NVidia chips of that generation were notorious for overheating and failing. If you have the standard unit (no options) then it's wrong.
You need to find out if the laptop actually starts: listen to the hard disk, if you hear it spinning while the boot takes place then the defect is somewhere in the video section. In that case connect an external monitor (a tv) and see if you get something - if you don't then the defect is in the graphics chip and the repair (if possible) would be about what he said. If you see then it's in the screen and it will cost you less than $100 to fix (unless you broke the screen). And no, you can't fix it yourself, the graphics chip is soldered on the motherboard.
If you don't hear the disk then the motherboard has failed and to replace it will cost you about $250.
May 10, 2011 | Toshiba Computers & Internet
Toshiba Satellite L455-S5000 turns on but screen is black
Try external monitor, if it works then more likley the backlight inverter or the lamp is bad.
see www.insidemylaptop.com for example.
http://www.sparepartswarehouse.com/Toshiba,Satellite,L455-S5000,PSLY0U-03F02F,Laptop,Inverters.aspx
Please leave rating if it helps.
Jan 20, 2011 | Toshiba Satellite L455S5000 Notebook
My laptop monitor gets distorted
First must make sure that the problem in the screen and not in the card Alclcp by connecting the device to screen Hargip if the image is good to be change the screen
Apr 16, 2010 | Toshiba Satellite A135-S4727 Notebook
Screen goes black
I think your battery might not be shorting out the lcd.
Leave the battery out and see if the lcd stays lit without going black, if it does it probably is the battery thats bad.
Try a known good working battery and see if the lcd stays lit. If the lcd stays lit then you know the battery was bad. if you get the same symptoms from another battery then you know its something with the motherboard at that point.
Jun 20, 2009 | Toshiba Satellite A45-S151 Notebook
Screen problem
boot up laptop...after bios screen ....press F8 (to get safe mode options)...choose safe mode.....when windows has booted ....go to control panel....display options...settings.....change the display to 800 by 600 and save and reboot into normal mode
Dec 30, 2008 | Toshiba (225EXTR5)
No sound on Toshiba Satellite A100
Hey buddy,
There is something called audio bus driver for the laptops especially. So need to install that to get this issue resolved. Try to get it installed and let me know.
Cheers!!!
Dec 07, 2007 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
David Payne
David Payne
