Question about Yamaha DVX-S120P System
Won't stay on - Check SP! ( error message then it powers off.
Cd drive got stuck and Cd was lost in unit. took off the cover and removed cd. Was working fine then the next day won't play at all. When I power on it goes on for a second first displaying Check SP!
    Novelist:
    Scholar:
  • 149 Answers
It sounds like you might have triggered something internally. I used to have just a plane CD player that had issues with this. It was the sensor for the CD. There was a little wheel that makes it come up and down. for some reason it was off track some times, and sometimes not. That might be an issue with this. Listen to hear if there is any grinding or hesitation sounds on the cd start up. Otherwise, it might be something to do with the power supply. Does it work with anything else? DVD, etc?
Posted on Sep 17, 2007
SOURCE:
2010 Jetta My daughter had a cd in and loaded another one. It is a single cd player. I don't know how it took it? It won't eject. How do I get them out??
If possible remove the unit from the dash, remove the top plate and push the cd out. If not I have removed stuck cd's with small flat nosed needle nose pliers.
Nov 01, 2012 | Volkswagen Cars & Trucks
Cd will not eject. Keeps giving message "Now OPC" but will not do anything and will not eject cd either.
To remove a stuck CD from Tascam CC222 MKII
This solved the "Now OPC" problem
1. Unplug unit
2. Remove the top cover, (3 screws on each side and 3 on the back, lift cover).
3. Plug in unit.
4. Power on the unit to observe the drive spindle spinning clockwise, (1" disc on top of drive).
5. Turn off unit, do not unplug at this time.
6. Use a small screwdriver to prevent the drive spindle from spinning.
7. Power on the unit preventing the spin.
8. In approximately 10 seconds the display will read "Disc Error" and the CD tray will open.
9. Remove the screwdriver and the disc.
10. Turn off the unit and unplug.
11. Replace the cover.
12. Use a better quality disc.
Sep 23, 2010 | Tascam CC-222mkIII CD Player / Recorder
My ford ka has a cd stuck in it with error code e11 showing. Help?
According to the Ford Audio Guide error E11 is "SPI BUS FAILURE" and Ford recommend "Check and repair the wiring harness "
I suspect that the error message will be because of the jammed CD.
You can possibly tease the CD out through the slot  using another (old) CD.
Failing that , remove the player from the dashboard, take off the cover and release the jammed CD
Make sure you have the Security Code before pulling it out of the dashboard
Sep 03, 2009 | Car Audio & Video
CD stuck in player.
there are four screws on the front of the cd deck. take them off and remove the cd deck from the main unit. there is a total of for screws u need to remove to get the cd out from the top. two are near teh front holding the silver cover. remove them and slightly slight the cover forward and up to removethe next are towards the back. after all screws are removed gently lift the top cover making sure not to crack the load arms. remove disc and seal case again. hope this helps... cuz thats how i did it with no problems and btw mine is shot too
Dec 21, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Not sure what the problem is
Check the changer and see if cds are inserted correctly or if 2 cds are in one slot.
Dec 13, 2008 | Alpine CHAS-634 6-Disc CD Changer
Harman kardon CDR2 error and stuck trays
I finally solved the problem. I unscrewed the cover, and found NO apparent malfunctioning parts. After a couple weeks, I took the unit to an electronics recycling event in my neighborhood, after I first cut off the power cord. I kept the screws to the cover, and will use them for a decorative craft project. I am now saving up for a REAL LP to CD unit, from a REAL manufacturer.
Sep 21, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
Clarion arx9270 error
Typically means the CD is stuck, has a reading error, or the magazine is stuck. If jammed, you'll have to clear the stuck CD which may require disassembly. Try removing power and rebooting.
If all else fails, I recommend contacting a local car audio professional, or you may contact Clarion customer support directly by clicking here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information has proven beneficial.
Jun 18, 2017 | Clarion ARX9270
Error message
I had this happen to me as ell. you've probably got a cd stuck under the revolving tray. I took the top cover off and then opened the drawer and removed the offending disk. If you're not technically minded it's probably better to take it in to a repair shop. Mike
Dec 24, 2007 | Marantz CC-4300 5-Disc CD Changer
Jeep 10 disc changer; now only error message on dash.
I had this same problem on my 2000 Jeep GC Limited. Today I decided to open it up after looking all over the net and found no help, but spend $500.00 on a new unit. I removed the unit and used canned air inside all the areas I could. I hooked it back up and was finally able to make the CD cleaner disc work. Once that was done I loaded it with 10 cd's and it is working again. I'm so happy! I saved my hubby 500 big ones.
Oct 26, 2007 | Cherokee Jeep Grand CD Changers - 10-Disc
Message 'no CD' always appears, but I can see the CD in proper position, but not spinning.
if you shut cd draw with no cd in, does the laser lens move up or down at all. if it does suspect dead laser pickup. it is very common for lasers to fail
Jan 11, 2007 | Teac AD-600 3-Disc CD Changer
Yamaha DVX-S120P System Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
