Question about RAMSET Ram 100 Slide Gate Operator 1/2HP 120VAC Instant Reversing Motor
Gate does not open or close - RAMSET Ram 100 Slide Gate Operator 1/2HP 120VAC Instant Reversing Motor
What kind of gate?
Posted on Apr 19, 2009
New FM502 Dual gate opener pressed remote which starts the second gate opening then the master moves a few inches stops. Hear 3 beeps 2 seconds 3-. .Conections are good to circuit board! What up!
reprogram the opening sequence in the control box
it should that the first gate opens then the second gate opens a few seconds behind it
closing is the reverse
you can program that only one gate opens
you can also program that one gate is a entrance gate where it opens until you stop it , then when you have passed through , press it again and it closes
read the operating instructions and follow the programming procedures closely
Oct 24, 2016 | Miscellaneous
Sliding gate pauses and shakes when it first starts, both opening and closing. Does this for a while, going very slow, then smooths out and closes and opens ok.
most sliding gates suffer form dirt, grass , rocks in the gate track so constant cleaning of that track is essential
small twigs , rocks will slide along with the wheels on opening but are an obstruction for the wheels on closing
most closing gates run a cog and rack system at the bottom ot the gate so check that the mesh of the rack and cog is correct at either end
Jul 26, 2016 | Cars & Trucks
Lift gate will not power down to closed when button on gate or remote is pushed. Lights do flash though.
There are switches on both ends of the course of the motor, if one fails it will only work on the side that´s ok. That´s why it opens but do not close.Check it out.
Oct 24, 2015 | Cars & Trucks
Gemini gate motor
Check if it has stops anywhere in the system, usually there are micro switches that are activated by arms, etc that tell it how far to open and close. You may need to adjust them.
Aug 20, 2014 | Cars & Trucks
Myhouse gate
There is a switch in the housing that tells the controller if the gate is open or closed. The switch is bad or out of adjustment.
Aug 21, 2013 | Home Security
Gate light on even when gate is closed
Open gate and find where the wiring enters the gate (bottom of door) pull back the rubber insulator and check for broken wires or wires touching each other.
Mar 05, 2013 | 2010 Jeep Liberty
You can hear my gate motor working, but the gate does not open or close. you can open and close the gate by hand. it is as if the gear does not engage
Your manual override is active. This disengages the gearbox from running the gate. You will need to release the manual override. What make and model gate motor is it?
Apr 03, 2012 | Cars & Trucks
My gate is equipped with a D3 Centurion gate motor. When I push the button to open the gate, the motor turns in the opposite direction (close) and tends to close further. Then if I deactivate the gear box...
if you push the open button and it closes indicates that you have the wrong polarity connected to the motor
gate motors are DC so where the positive and negative wires are connected are critical for rotation direction of the motor
Jul 29, 2017 | Garden
Gate stays open and does not close unless timer switch is turned off
I have a brand new Ramset 300 electric gate opener. My problem is in the early morning when the loop opens the gate it will not close unless deactivated manually. It does not happen later in the day with my GMC truck but happens early in the am with my husbands Toyota Prius. Please help. What can be the problem?
Jun 19, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
Strike open light flashes and gate opens
it was a loose connection on the circuit board in the romote keypad
Sep 30, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
RAMSET Ram 100 Slide Gate Operator 1/2HP 120VAC Instant Reversing Motor Logo
361 people viewed this question
Top Ramset Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Ramset Tool and Hardware - Other Expert? Answer questions, earn points and help others
