I need a recommendation for a video card that will work in a Gateway Performance 733 that originally came with integrated graphics.
  • 854 Answers
You can try;
1. Nvidia TNT2 series video card 32mb AGP interface
2. MSI nvidia TNT2 M64 32mb Graphic card agp4x MS-8808
Posted on Apr 17, 2009
USB 3.0 upgrade
You might need to upgrade you graphics card.
USB 3.0 is the newest connection port upgrade, arriving on the market in 2010.
The cable port connection is far superior to the USB 2.0 port, as it is able to transport up to 5 gbps (gigabits per second), instead of the previous version's max speed of 480 mbps (megabits per second).
However, most computers do not yet have this connection port installed, in which case you are left to upgrade your own computer system to the newer, faster connection method.
Turn off your computer, then disconnect all of the cables running into the computer.
Remove the Phillips screws from the back side of the computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
This unlocks the case, allowing you access to the interior of the system.
Slide open the computer case.
Inside the middle is a longer circuit board.
This is the motherboard of the computer.
On the back side of the motherboard, facing the rear of the computer, are PCI card slots.
These allow you to install additional hardware onto the computer.
Slide the USB 3.0 connection port into one of the open PCI card slots, then push down the plastic levers along each side of the slot to lock the card into place.
Close the computer cover, then tighten the Phillips screws and reattach the cables.
Power on the computer, then insert the driver installation CD into the disc drive of the computer.
Once the installation wizard loads, follow the prompts of the wizard to install the drivers.
Restart the computer once finished and the USB 3.0 connection ports are ready for use.
http://www.pcworld.com/article/186566/usb_30_finally_arrives.html
Compatible graphics cards for Gateway Computers
Just as a processor handles data and a sound card outputs sound, your computer's video card is responsible for processing graphics and displaying them on your monitor.
The video cards manufacturers build into computers typically have enough power for the average user, but it may be necessary to upgrade your video card for better performance in games or graphics heavy applications.
Understand which types of video cards are compatible with your Gateway computer and learn about all your options.
PCI Express Graphics Cards
Many newer Gateway computers have a Peripheral Component Interconnect (PCI) Express slot in which you can add any PCI Express compatible video card.
These devices range from budget cards suitable for everyday tasks to high end models for gaming that cost hundreds of dollars.
AGP Graphics Cards
Older Gateway computers likely have an Accelerated Graphics Port (AGP) slot for AGP compatible cards.
The AGP bus provides sufficient bandwidth for high performance graphics cards, but the technology is no longer in use and AGP cards are difficult to find.
PCI Video Cards
Nearly all Gateway computers should have at least one PCI (Peripheral Component Interconnect) slot regardless of age.
This slot has enough bandwidth to support a wide range of peripherals like sound cards and modems, but is not suitable for high end video cards.
You can find a number of low and mid-range cards for PCI slot computers, however.
USB Video Cards
USB video cards are also compatible with Gateway computers sporting USB 2.0 or USB 3.0 ports.
These external cards sit outside the computer and allow you to connect additional monitors to your system.
They are a good option for people who feel uncomfortable working inside computers.
http://www.pcmag.com/article2/0,2817,2371083,00.asp
How to buy a video card
http://support.gateway.com/us/en/support/default.aspx
Gateway Support
Upgrade My Video Card on My Gateway Desktop
Gateway desktops are affordable computers, but they often do not come with top-of-the-line video cards.
Computer games may run slowly or not at all on your Gateway desktop.
One way to solve this problem is to upgrade the video card.
Video cards come in PCI, PCI-E and AGP interfaces, so you should be able to find a video card upgrade no matter what Gateway desktop model you have.
Click "Start" and right-click "My Computer."
Select "Properties" from the menu that appears.
Go to the "Hardware" tab.
Choose "Device Manager."
Click the plus sign next to the Device Manager entry listed "Display Adapters."
Find your graphics card in this list.
Double-click it.
Go to the "Drivers" tab and click "Uninstall Drivers."
Click "OK" to confirm the uninstallation process.
Shut your Gateway desktop down.
Pull the power cable out of the back.
Look at the back of the Gateway computer tower for screws on the right side panel or on top of the case for a cover release handle.
Nov 29, 2013 | Gateway DX4200-09 PC Desktop
What is visual graphic acdactor ,and the freze
A video card (also called a video adapter, display card, graphics card, graphics board, display adapter or graphics adapter) is an expansion card which generates a feed of output images to a display. Most video cards offer various functions such as accelerated rendering of 3D scenes and 2D graphics, MPEG-2/MPEG-4 decoding, TV output, or the ability to connect multiple monitors (multi-monitor).
Video hardware can be integrated into the motherboard or (as with more recent designs) the CPU, but all modern motherboards (and some from the 1990s) provide expansion ports to which a video card can be attached. In this configuration it is sometimes referred to as a video controller or graphics controller. Modern low-end to mid-range motherboards often include a graphics chipset manufactured by the developer of the northbridge (e.g. an AMD chipset with Radeon graphics or an Intel chipset with Intel graphics) on the motherboard. This graphics chip usually has a small quantity of embedded memory and takes some of the system's main RAM, reducing the total RAM available. This is usually called integrated graphics or on-board graphics, and is usually low in performance and undesirable for those wishing to run 3D applications. A dedicated graphics card on the other hand has its own Random Access Memory or RAM and Processor specifically for processing video images, and thus offloads this work from the CPU and system RAM. Almost all of these motherboards allow the disabling of the integrated graphics chip in BIOS, and have an AGP, PCI, or PCI Express slot for adding a higher-performance graphics card in place of the integrated graphics.
Aug 31, 2012 | Computers & Internet
Hi i run the game desperados 2 n while i playing i see all the characters in black shadows how to fix it? i use windows 7
I had the same issue with NVidia GForce GT 540 M, this graphic card can work in 2 modes: high performance grsphic processor and integrated video... so game was run using integrated video by default,
and when I changed graphic card settings to use high performance processor always, problem was fixed. So try to change graphic card settings.
Oct 10, 2011 | Atari Desperados 2: Cooper's Revenge for...
Do i need to by a graphic card for my asus m4a78lt-m lx?
No, you do not need a video card because that motherboard has graphics integrated on the motherboard. The motherboard has the following video processor built-in:
Integrated ATI Radeon™ HD 3000 GPU
Feel free to let us know if you have further questions.
Thanks!
EJ Kudelka
Sep 07, 2011 | ASUS M4A78LTM LE Motherboard
Can I upgrade the video card on a Gateway E4300 to work with Shader 3 graphics (Eve Online)? Or do I have to buy a new computer?
You only really need to upgrade the video card and the PSU (most video cards need more power than what most companies like dell and gateway provide.). So no need to buy a new computer.
Mar 22, 2011 | Computers & Internet
I installed pinnacle 14 hd studio in my son's computer. It worked just fine. It came with a video converter called dazzle. I installed a Radeon HD 5670 graphics card in the computer and now studio 14...
I had the exact same problem when I installed my Radeon 5670. I fixed it by going to device manager, video adapters, update driver (let it search the web and install). Worked fine after that. Good luck!
Jan 26, 2011 | Gateway Computers & Internet
"Call of Duty" runs in slow motion on my PC.
Hi thomas,
Upgrading video cards will definitely increase in performance. You asked whether you should upgrade your entire PC or just the card and that really depends on the hardware you are running. If all of your hardware just barely meets the requirements than upgrading the videocard WILL give you a noticeable improvement but obviously it will not be as good as getting a better CPU and more RAM as well as a new card.
A good measure of a cards performance is based on the series of cards it is from. Your Geforce is from the 6000 series of Nvidia cards, they have 7000, 8000, and even 9000 series cards atm.
I would recommend something like an XFX Geforce 9800 GTX+ series card with 512MB of onboard memory, or any other competing card in the 200$ price range. This will definitely give you an increase in performance, and is a very popular card.
Hope this helps and please take a second to rate!
Mar 20, 2009 | HP Pavilion a1610n PC Desktop
Need drivers for a GP7-733 Gateway Desktop
you can download all drivers for gateway laptops at the following site for free http://support.gateway.com/support/drivers/dlcenter.asp
my friend has a gateway and she had the same problem.
more help needed then email me on milliprowd21@yahoo.co.uk
thanks
matt
Aug 21, 2008 | Computers & Internet
Monitor won't come on after unplugging for an electrical storm
Is it plugged into an integrated soundcard on the motherboard or is it plugged into a Graphics card either a PCI or AGP? If it is integrated, you may want to look into a different video card for both better video quality and system performance. Let me know if this doesn't work.
Mar 15, 2008 | Gateway FPD2275W LCD Monitor
Support for wide screen monitor
1600 × 1200 32-bit color is the maximum resolutions of u're video card. And the native resolution of the monitors is the highest resolution supported by them, so there is no worry, u can use the video card u have ... !
http://support.gateway.com/s/VIDCARD/VisionTEk/6002239/6002239sp3.shtml
Jan 20, 2008 | Gateway GeForce4 Ti 4600G, (128 MB)...
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
