Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Will wash and rinse but not spin
The washer will go through the wash and the rinse cycle but when it should spin the washer beeps and has given me the code indicating it is the clutch or water pressure tube. I removed the agitator and another gear type object with a plastic piece attached by 3 screws as per directions found on line. It statee by doing this I would be able to separate the inside wash drum to see if it was the clutch etc but my washer's drum will not lift out and off the drive motor shaft.
  • bisou Sep 19, 2007
    that didn't make a difference. It only occurs during the final spin. It will spin after washing just not as fast. that also requires the lid to be aligned. the code says clutch or pressure tube which must be between the tub and barrel.
  • bisou Sep 21, 2007
    my fisher paykel washer will not complete the wash cycle. When it is on the final spin it will not spin and gives the code indicating the clutch or pressure tube. I have taken the agitator out in an attempt to lift the tub out of the barrel to see what is up but even with all the parts removed the tub only lifts up 1/2 or so and not off the drive gear. How can I determine what is wrong and what and where is the pressure tube?
Try a different power outlet. Run a good quality extension cord (not a cheap one) over to the washer from an outlet on a different circuit in the house. NOTE: this is for testing purposes only, do NOT continue to use the expension cord. If this fixes the issue, call an electrician.
Posted on Nov 07, 2008
OH MY GOODNESS! I WAS READING A LOT OF PEOPLE'S QUESTIONS ABOUT THEIR WASHING MACHINE PROBLEMS BECAUSE I AM HAVING A PROBLEM WITH MINE. MINE WAS FILLING AND WASHING, BUT WHEN IT GOT TO THE SPIN, IT WOULD NOT DO A THING. "dstfas" GAVE THE SUGGESTION OF IT BEING OUT OF ALIGNMENT AND TO "push in the switch with a small stick or something." I DID SO BY STICKING A SCREWDRIVER IN AND RUNNING A WHOLE CYCLE. IT RAN COMPLETELY FINE AND HAD NO PROBLEM WHATSOEVER. SO - THANK YOU, THANK YOU, THANK YOU...kstfas!!!! YOU ARE A MONEY SAVER AND A LIFE SAVER. YOU HAVE JUST MADE MY WEEK. NOW - MY ONLY QUESTION IS...HOW DO I REALIGN OR READJUST MY WASHER TO FIX THAT PROBLEM?
Posted on Jan 08, 2008
  • DeDee14 Jan 08, 2008
    Novelist:
  • 75 Answers
Hi, I would check the washer door switch to make sure it has continuity when the door closes. If its just out of adjustment you may be able to tell that by pushing in the switch with a small stick or something. I believe your washer would act the same way if you left the door open. Hope I have helped. kstfas
Posted on Sep 18, 2007
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
My washer will not complete a full cycle.. when on rinse does not finish beeps as though it done but is still on rinse..also fabric softner does not drain into machine. machine will spin if I manually set...
my washer does not finish a full cycle ;but is still on rinse and its a bosch and i was wondering
were is the fuses kept in the machine,
sandra read
sandrarread@yahoo .co uk
Jan 22, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Kennmore 110.22422. 100 hummms when reaching the spin cycle
your timmer button has given up replace the timmer and it will be fine
Jun 19, 2010 | Kenmore 22422 Top Load Washer
Stops half way through rinse cycle and beeps
Best off to call a certified repair company such as Sears.
Mar 20, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel Ecosmart will Wash but not Rinse/Spin
You have too many clothes in the washer. Take some out and try again
Sep 09, 2009 | Fisher Paykel EcoSmart GWL15
Stopped during rinse/spin cycle
try removing the bottom front panel and see if there is something blocking the drain.
Oct 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
No Spin
Hey, I know it's probably late, but I'm having a similar problem in that it's not spinning and I'm getting an error message of F 02. Did you have this problem? How did you fix yours? Please let me know, I need to wash clothes for my son's prom tonight. Thanks.
Oct 20, 2006 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
170 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
