Washer over flows and when you adjust the wash size on the small size the washer keeps running.
  • 121 Answers
The hose that connects to the water level came off
or switch is no good
Posted on Apr 17, 2009
Pad keeps ripping in center when i wash it
most likely its the size of washing machine making it rip , something this large should be washed in a large commercial washer ,its too small a diameter in the drum to bend a large sheet around without pulling it (ripping ) on a home size washer
Feb 10, 2016 | Perfect Fit White Magic Loft Mattress Pad...
When my Maytag Bravos top load washer drains it overflows the washer drain. Can the pump be adjusted to reduce the flow and not overfill my drain?
I think you need to address the (partially clogged) drain. Assuming it is a standard sized drain pipe - with no restrictions of size down the line - it is probably clogged with lint, soap, softener, etc. Otherwise, the clog will only get worse and slow the drain more and more over time. I'd treat it like any other clogged drain. A liquid drain opener could be your first line of attack. Pour water as needed into it - do not let the washer provide the water or you run the risk of splashing the chemicals all over.
Oct 01, 2015 | Maytag Washing Machines
Washer just keeps filling and never advances on large and medium loads only
Your drain hose is pushed too far down into the drain so when you select the larger load sizes the water is being siphoned out as it goes in due to the pressure differential.
Jun 01, 2012 | Electrolux Washing Machines
Water keeps running and over flows
Failed load size/water level switch(pressure switch), needs to be replaced.
Good Luck !
Apr 09, 2010 | Kenmore 24032\24036 Top Load Washer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
When you turn it on keeps filling water and it over flows , second problem some times when it runs it keeps running to all the cycles never stops tell you manually stop it
Find the tube from the tub to the water level switch. Remove the tube from the switch and blow the sand and stuff out the line. Pump out any water in the washer and restart. 6b0c2cb.jpg
May 16, 2009 | GE WBSR3140DW Top Load Washer
Maytag performa pav2300
Just rehook the clear tube back onto the air dome (back right side of drum), drain any water from the drum, the refill, pressure switch will reset itself. Start to fill on small load size first, then move up when washer starts to be sure it reset all the sizes.
Aug 06, 2008 | Maytag Performa PAV2200
Whirlpool washer
the Pressure switch is bad (also called Water level switch) there is a small hose from the tub that runs up to it ..The tub will need top be empty when this part is changed
Mar 02, 2008 | Washing Machines
Water flowing back into washer after wash
There is a back flow valve attached to the outlet port of the drain pump. It is just a small rubber flap. This sometimes comes loose or remains open due to debris and allows the water in the drain hose to flow back into the machine after the drain pump shuts off. It can be checked by removing the drain hose from the pump inside of the machine. You will lose all of the water in your machine (about 1/2 gallon)when you do this so be prepared with a bunch of towels.
Feb 14, 2007 | Whirlpool GHW9100L Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
