Question about Refrigerators
Need info for taylor slurpee maker
I recently was lucky enough to aquire a taylor slurpee machine from a 7-eleven we renovated, I have cleaned the whole unit and checked the soundness of everyhting on it that my limited knowledge understands. i have been looking online for information on these machines and to locate some kind o manual for cleaning and operating, I really wanna make sure its all tickety boo before I plug it in and hit soem switches and fry something, can anyone help me locate the information online?
  • Brett Duxbury
    Brett Duxbury Jun 01, 2017
    Hi beezel403, we want to help you with your question, but we need more information from you. Can you please add details in the comment box
    Does it have a specific model number ?
  • 14,398 Answers
Posted on Jun 01, 2017
Master_Tech
  • 770 Answers
SOURCE: Miele leak when switched on for wash, from filter unit front LHS bottom of machince
You can replace the Bellows as it is called but to fix it before you replace it clean it with Bleach to kill the mold and then dry it ALSO after any load you do leave the door open a bit this allows the mach to air dry out and prevents the build up of mold ..Good Luck plz rate this post for me
Posted on Feb 17, 2008
  • 172 Answers
SOURCE: kenmore coldspot - How do you remove the ice maker box to clean
Hi Cincygrl,
Well lets see, I believe you have a whirlpool made kenmore, Your model numer should start with 106.
The problem you are having is from our drain. When you freezer defrosts the water should drain down a tube and under the refrigerator into a pan. If the tube gets clogged it will leak water into the freshfood section. To clear the drain you will need to remove everything from the freezer and remove the inside back panel in the freezer. in the center bottom under the coils and the heater you will see a tiny hole. That is your drain. If it is frozen over you will need to defrost the ice or you may need to run a smaller tube into it to clear it of an obstruction. I use a small rubber hose and I just insert it into the hole and blow on the other end. If you have something in it, it should blow out. If it does not then it may have ice in it and you can pour hot water into the drain and defrost it. Once clear you should not have any further problems. But they do make a drain heater probe to keep ice from forming inside the drain. You can get one for about $6.00. Good luck and I hope this helped you. mca0824@aol.com
Posted on Apr 30, 2008
Master_Tech
  • 770 Answers
SOURCE: freezer won't freeze
is the fan running ion the freezer is the compersser runing and the cond fan >??
Posted on May 10, 2008
SOURCE: 690 SubZero Side-by-Side Fridge
One more thing to look at. There is a water drain tube that takes condensation from the inside of the refrigerator and transports it to a collection pan under the until. Subzero used a "covered coil" type tube for this. If any food particals become hung up on one of the coils in the tube water will back up and cause ice to form on the evaporator. The system is dumb and will tell you to vacuum the condensor under this condition as well. I replaced the Subzero OEM tubing with a hunk of rubber fuel line and never had ths problem again.
Posted on Sep 27, 2008
peyton32034
  • 410 Answers
SOURCE: My GE Monogram Ice Maker keeping turning its self
the rate the light flashes is a code for trouble shooting the electronics on the unit ( such as bad coil sensor, bad bin sensor or shorted grid cutter) if you will look behind the front grille you should find a tech sheet that will tell you what the flasing means and tell you what components to replace. BTW the most common failure is the cutter grid and bin sensor. the sensor is the white rod on the right hand wall inside the unit. besure it is plugged in. Let me know if I can help you futher. thanks Peyton
Posted on Mar 21, 2009
Taylor ice cream machine model C713-33 no yogurt comes out when the draw handle it pressed. It seems to be flowing backwards. The agitators are turning in the same direction as the working machines
IF your Taylor C713 is pushing the mix back up through the feed tube, the rotation is reversed. That would only happen on a 3 phase machine like yours.
If you've recently unplugged the machine to move it or something, you probably switched the plugs. Try switching them back.
If you need to reverse the rotation:
1. Unplug the machine.
2. Flip the black and white wires on the plug end.
3. Reassemble the plug and plug in the machine. Make sure everything is tight.
Soft Serve Parts C713
Jun 10, 2017 | Taylor Ice Cream Makers
Any maintenance issues on a taylor 430 frozen drink machine
The Taylor 430 is a solid machine. The only maintenance you need to worry about are:
1. Cleaning - Follow the instructions. Supplies are here.
2. Replace wear parts - Scraper Blades and Tune-up kit
The next most purchased part for that machine is the freezer door, but the good news is the new replacement is much stronger than the old ones.
Soft Serve Parts 430
May 12, 2017 | Taylor Ice Cream Makers
Taylor 8756 bottom cooler too warm
have you cleaned the coils in the top of the unit, the fridge one is the little one on the side.
Jul 07, 2010 | Taylor 632-33 Ice Cream Maker
I need beater with its blade and a pipe for taylor machine
you can call Rick at Restaurant Parts and More, 1-888-814-1110. Have you model and serial numbers. He can most likely help you.
Apr 14, 2010 | Taylor 632-33 Ice Cream Maker
Taylor ice cream maker single serve
You can't. Taylor won't send you one unless you are a foactory trained technician. Sorry
Oct 19, 2008 | Taylor 632-33 Ice Cream Maker
what model machine and what do you need to know.
Oct 17, 2007 | Ice Cream Makers
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
