Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Poulan te 450 cxl fuel lines need routed correctly two line both in tank one to fuel filter other line?
Other line is just left open like to send gas back from the carb.
Posted on Jul 15, 2009
Tip
Fuel line routing for ryobi,poulan and sears trimmers
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up against tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulb goes to top port of carburetor. that is the way they go on.it is important to make sure you have the same fuel line I.D. and O.D. are very important! also if old line dissolved it will get in carburetor and clog ports & small screen inside.clean inside of carburetor with carburetor cleaner & air pressure. to get your parts and numbers ,go to mtd parts.arinet.com, parts,791-683398,fuel line assembly.hope this helps
.hello sir,routing fuel line for craftsman,homelite, trimmers,fuel tank over engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carburetor fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carburetor fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carburetor fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carburetor when replacing fuel line it is very important to use the same ID and OD line,when the lines dissolve small pieces will get in the carburetor clogging small passages and screen,it is advisable that you clean out carburetor and use a new filter.hope this helps, DON'T FORGET THE 4 THUMBS UP,,,,any comments welcome,thank you.
on Feb 27, 2010 | Garden
I have a 2250 Poulan. The fuel lines have been removed. Is this the correct routing for the fuel line? Starting at the filter in the tank,will the line go to the bottom of the carb.? Then the line goes out...
Is there a fix for bar oil running out of the saw all the time until the tank is empty?
there is bad oil line repalce it.
Is this the correct routing for the fuel line? Starting at the filter in the tank,will the line go to the bottom of the carb.? Then the line goes out at the top of the carb. to the primer\'s suction side? Then out of the primer to the fuel tank? This route the primer pulls gas through the carb. Does it make any difference which hole in the tank the lines go to?
YES that correct
Dec 29, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Routings of fuel line to Poulan 14 inch chainsaw Model 2025
No drawings or pix, but will try for description--the line from the tank that has the fuel filter is the main fuel source which goes to the upper connection on the carburetor. The lower carburetor connection goes to the intake side of the primer bulb, and the outlet side of the primer goes back into the tank, which has no filter inside the tank. The main problem is determining the correct primer port to connect back to the carburetor. When everything is connected, try priming the carburetor. If fuel fills the bulb, you have everything connected correctly. If nothing happens, try switching the two primer port connections and try to pump fuel again. If still nothing, hook the main supply line from the carburetor over to one of the primer ports and try for fuel again--if still nothing, switch the main supply line to the other primer port and pump again. If still nothing, check for a plugged fuel filter in the tank. If the filter was plugged, then go through the previous procedure again. Make sure to replace the fuel lines with original rubber lines, not plastic. Hope this helps!
Jul 13, 2010 | Poulan 14" Chainsaw
Fuel line routing
A typical fuel system and a couple of suggestions follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
If not your saw, yours can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
I am reasonably sure the upper most carburetor connection (it bleeds any air in the carburetor, air rises) goes to the primer. Leave the hoses long enough to swap them and try it. They can be shortened once you verify the correct routing. Good Luck. HTH
Lou
Feb 24, 2010 | Poulan Pro Chain Saw 46cc 20"
Both lines came off of the posts on a te 450 trimmer. which line goes where?
I presume you mean fuel lines. The return (without fiilter) line goes nearest the primer bulb. The supply (which has the filter attached inside the tank) goes on the further nozzle from the primer bulb.
Nov 28, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
I replaced both broked fuel lines and it still doesn't start.
Make sure the line is connected to the fuel cap if it has a pump ball.
Apr 24, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I may have lines on Backwards??
filtered line from tank goes into top inlet at carb. bottom inlet receives line that goes to carb side of primer {draw side} 3rd line goes from push side of bulb bach to fuel tank.
Mar 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Need instructions on how to put line in Poulan Twist N Edge TE 450 CXL weed eater.
Dear FixYa Fan, Friday 2-20-2009 10:37pm EST (USA)
RE: Poulan Lawn Trimmers
Poulan Lawn Trimmer FAQ @
http://www.ordertree.com/cms/Poulan+Trimmer%2c+Blower+%26+Edger+FAQ/241.html
Dear jebkillion: You will find instructions for putting line on your trimmer at this link http://www.ordertree.com/cms/Poulan+Trimmer%2c+Blower+%26+Edger+FAQ/241.html#changeline click on the http line preceding but please rate me 1st or come back and rate me before you close this or the Poulan Site!
Thank You,
jackiaria
Feb 21, 2009 | Garden
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
2,026 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
