Question about Maytag SkyBox MBV1976A Beverage Dispenser
Skybox parts # 4387535 installation issues
Posted by roba300 on Apr 17, 2009 I bought the 4387535 kit and it has no wires or instructions with it. It looks different that the white piece that I took off. It came with a flatter piece as well. I am not sure how to hook this up. Do I take the black wire off of the original round piece and hook it up to the flat piece. IOr do I leave the round piece on and hook the other end to the new flat part. If I take it off, do I cut the black wire off becasue the piece connected to the round piece is not budging.
Also, do I hook the green wire up to the prong connected on the flat piece.
Any detailed help on this would be appreciated. My email is klangaroo@aol.com.
You don't need to keep the round metal piece or the black wire that you take. The replacement part (flat one) is installed in its place. Put it in first, attach the green wire to it, and then put the two prong piece and install the wires (blue, white and brown) as you took them off the original part.
Posted on Apr 20, 2009
  • georgebenko Oct 21, 2010
    roba300 is 100 percent correct. Simply take off the old Overload and Relay. Don't be afraid of breaking anything by taking off the old overload, it is held in place by 3 prongs that extend out from the back of the compressor. Simply pull the overload directly towards you and it comes right off. After you have that off, you will see how how the 4387535 kit goes on. THANKS for the post roba300!
    One last thing, The green wire referenced going into the relay on mine was actually a grey wire.
I do not have a skybox problem ... I was looking at Starter relay information and skybox guy posted starter relay info ... I decided to pay for help ... Frigidaire Gallery side by side DFRS26ZSHB2 ... no...
If it's not cooling and the internal lights and fan are working, then the problem is either the start relay or the overload relay. I checked the model number you posted and I didn't get any information for the number. Please double check the number that is posted inside the unit. In the mean time, take a look at this relay kit. It is a combination start relay, run capacitor and overload relay all in one. Usually the start relay will run you around $25.00 alone so this is what I use to repair this type of problem at a fraction of the cost. Again, please check that model number again and I will get you the pricing for the individual parts. It is best to replace all the relays if one goes out.Here is a link to the ERP410 relay kit.
Regards,Richard
Dec 09, 2011 | Maytag SkyBox MBV1976A Beverage Dispenser
Need overload relay wiring help
I looked for a wiring shematic and i'm not having any luck but i'm sure the two loose wire do go to a capacitor let me know how it works out for you thx Peyton
Mar 04, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox has stopped cooling
the whirlpool part is the oem part and is the best part for your repair it should replace wire for wire and require very little instruction. the 3-n-1 will cause premature failure of the compressor and is not recommended. As far as I know there really isnt a service manual available for the skybox. It was a very limited production product that didnt stay available for very long. thnaks Peyton
Mar 02, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Removing compressor from skybox
Maytag never offered a replacement compressor for the SkyBox units. It was not a cost effective repar to make. If you are sure the thermostat is supplying 120VAC to the compressor, you can install a Supco URCO410 relay/capacitor/overload kit. This part should only be installed by a qualified service technician.
Feb 22, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Installing overload relay kit 4387535
go to appliancezone.com
part # 4387835
it goes on the same way it comes off
if you hafe the MBV1976AA -- they use the same part
item is marked 307071
but is listed by maytag # 4387835
Oct 31, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Replacement starter relay for skybox MBV1976A...
i lost track of the way the wires go on starter relay. can someone please let me know or send diagram, for the 3 wires. Any help would be appreciated.
Jul 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
MBV1976AAP
Maytag did not offer any parts for the compressor on the SkyBox. Purchase a SUPCO URCO410 relay/overload/capacitor kit and install it per the instructions on the package.
May 02, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox stopped cooling
I just replaced my in-pieces starter relay and thermal swich with a Whirlpool 4387535 kit. My Skybox has been working fine ever since.
Note I had the same symptoms as other posts of the compressor turning on/off continuously (but no cooling)...I believe what was happening is that the starter relay would allow current to flow to initially start the compressor, but would never stop providing current to it after it had already started (as it should) thus in a few seconds the thermal switch would sense this and trip / remove power to the compressor...then this cycle would start all over once the thermal switch cooled down again and let power back to the compressor...
This kit is evidently the newer style of what is on the original Skybox compressors (functionally speaking)...the new starter relay looks and installs like the old one, but the thermal switch is different and you need to remove the old one (follow the black wire on the top post of the compressor back a little to a small black round thing with a flexible metal piece inside). The good news is that once you remove it, it already has the correct spade lug on the wire to plug directly into the new thermal switch which sits right on the top lug of the compressor above the starter relay.
Note I'm not a service tech, just a Skybox owner who was/is tired of Maytag disowning this product and calling it a "throwaway" when any part of it stops working (and all local authorized service centers laughing when asked to repair one).
Continuing on with my rant a little, I also see other posts on the internet which also state "throwaway" when you actually have a bad compressor because you can't get direct replacements anymore - my friend who does AC work on the side said he most certainly could put another compressor in there from probably just about any other mini-fridge...he just noted that it is a small place to do it so the replacement compressor form factor will have to be considered. He stated you may get a little more or less cooling efficieny but who cares if you really want to keep your machine working that you can't buy anymore (nor get a close alternative).
Mar 13, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
685 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
