Question about LG WM-2277HW Front Load Washer
LG TROM 6.5 Kgs Washing machine model WD 15265TP was not in use for few months on starting after a long gap got error message LE advice how to resolve this problem
  • Adiel Cruz Dec 06, 2012
    Hi, I was just told that by the LG Service Center in my home country that my LG Tromm WN-15265TP washing machine has already been phased out. I purchased this in 2006 in another country and I was told that they can no longer find a replacement part for the machine. Per initial checking of an LG technician, the bearing is the possible defect. Because it is already a phased out product, no parts are available. Need help as to what to do or to who i should get in touch with. Thank you.
  • Anonymous Mar 12, 2014
    The machine is one year old, what care should be taken. How to use the button next to 'power' button, which is in the sign of 'clock'
  • 4 Answers
U need a hall sensor for your motor. call for service
Posted on Apr 23, 2009
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
Jan 17, 2014 | Washing Machines
Lg wd-3245rhd LE error message
This seems to be a fault in the motor wiring harness, check all the connectors to and from the motor, check the male and female connectors. Also check the sensors to the motor which can cause this motor to show up as overload.
Jan 14, 2013 | LG WD-3243RHD Front Load Washer / Dryer
Washer starts then after few minutes stops and beeps with LE flashing. What does this mean?
LE = Load Error. If you do not have an unusually heavy or unbalanced load, replace the HALL sensor on the motor. Remove back access panel, remove bolt from center of motor. Remove rotor. Remove bolts holding motor coils to machine. Unplug wires. Un-clip sensor, replace with new sensor, and re-assemble. This is a rather easy repair.
Feb 13, 2011 | LG WD-1045FH Front Load Washer
Drum will not spin
You will need to change the rotor and stator,
Jul 21, 2010 | LG WM1814CW Front Load Washer
LE error message on the panel
Depending on the serial # of the dishwasher it may need a new wire harness and inner door liner.
LE is a motor circuit error.
Contact LG @ 1 800 243-0000 they may help you out.
Jan 15, 2010 | LG Washing Machines
WASHING MACHINE DOES NOT GO ON
Check your display panel again- there is no such error code for the LG WD-3245RHD. You can have: "dE", "tE", "FE", "PE", "CE", "LE", or "dHE" but there is no "D5" error code.
Aug 24, 2009 | LG WD-3245 Front Load Washer / Dryer
Lg wd-3243rhd front load washer and dryer combo "le" error message
LE error code means the motor sensor has failed.  The motor sensor is located in the back of unit inside the motor.  You will need to order a replacement motor sensor from LG.  You will need a 17 mm and 10 mm socket tools to do this job.
Mar 17, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
LG WM-2277HW Front Load Washer Logo
378 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
