Question about Broan-NuTone N-8663RP Combination Light Fan Exhaust Fan
How to remove cover in shower fan/light combination. Need to replace light bulb.
I tried turning my light fixture counter clockwise but that didn't work. I tried the screw driver technique as well, but that didn't work either. However, I applied pulled down the whole fixture with steady, even pressue on both sides and that did the trick. The fixture comes down a few inches while sliding on two wire guides on either side.
Posted on Jul 09, 2009
  • 4 Answers
Just had the same issue - on this nautilus light you want to take a small flat-head screwdriver and pry down (lightly). The whole glass piece and metal ring will drop about 3 inches and should grab again so that it won't fall. Then push the two metal "hooks" in a little farther to take it off completely. Not a bad design, but it'd be nice to know how to remove it if you didn't install it.
Posted on May 17, 2009
Ok people I tryed everything .... There is a small groove around the glass cover and that's we're you pull down ( I did it with a kitchen knife ) and then the glass cover will extend down at that point you will see the screws to remove the whole fan ... If you would like to do so... It's a mess up there .... If ... Like me .... It has been ten plus years without the bulb fixed !!! So freaking happy !!!
Posted on May 19, 2012
    Sniper:
  • 75 Answers
I think this one is removed by rotating the cover counter-clock wise. If that does not work then it will be held in place by about 4 tabs that snap into grooves of the frame. By gently pulling down around the perimeter of the cover should pop them out. Try the first method first.
Good luck. :)
Posted on Apr 26, 2009
I spent over an hour trying to get the glass cover off and had just about given up. I came here for help and while the advice put me on the right path, I still could not get to the bulb. My problem was that I kept feeling like the fixture was going to pull out of the ceiling. What I finally wound up doing was pulling down on one side of the plastic fixture and then sliding the glass out the side. I was then able to change the bulb. Maybe this will help you if you don't feel like you can pull hard enough the way others have described.
Posted on Aug 20, 2011
The light in my microwave went out. how do i replace the light bulb?
Some have a plate on the interior of the oven that can be removed for easy bulb replacement but if yours does not you will have to remove the entire outer covering to access the bulb. If you have a combination microwave/Range vent you will have to remove the entire unit from the cabinet, then remove the outer cover, replace the bulb and re-install the combination unit.
Dec 13, 2011 | Microwave Ovens
Can't get the cover off to change the light bulb
The whole cover/grill/globe pulls straight down to expose the bulbs. There are two heavy "V" springs, one opposite the other, that hold the grill to the fan box. You need to overcome the holding power of these two springs to pull the grill down. If necessary, you may want to run around the edge with a sharp knife in the event it was painted in place.
May 20, 2010 | Broan-NuTone N-8663RP Combination Light...
How do I remove the cover
May 10, 2010 | Broan-NuTone N-8663RP Combination Light...
How do I change the light bulb and/or night light for my NuTone bathroom Fan-Light Model 8663RP?
Mar 30, 2010 | Broan-NuTone N-8663RP Combination Light...
Replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
Replacing headlight assembly --or cover--for Kia Optima-2004
1. Open hood. Disconnect negative battery cable.
2. Remove five bolts attaching headlight and combination light assembly to vehicle. deb10ad.jpg 3. Pull headlight and combination light assembly forward clear of vehicle. 4. Rotate back cover counterclockwise to disengage from light assembly. 5. Pull socket with bulb straight out of headlight and combination light assembly. Regards, Jeep Brainy
Jun 22, 2009 | 2004 Kia Optima
Replace shower fan motor in a Broan model 678
I need to get the cover off of a BROAN fan and light kit. The two solutions listed did not provide me with sufficient information. Thanks!
Jun 19, 2009 | Broan-NuTone N-8663RP Combination Light...
How do I replace a taillight lens on a 1991 Geo Storm?
Rear Turn Signal, Brake and Parking Lights
STORM COUPE
  1. Disconnect the negative battery cable.
  2. Lift the luggage compartment floor carpet toward the front of the vehicle and remove the spare tire cover panel.
  3. Remove the ten plastic retaining clips from the rear end trim panel.
  4. Disconnect the luggage compartment lamp electrical connector.
  5. Remove the luggage compartment trim panel and the rear end trim panel.
  6. Disconnect the rear combination lamp assembly electrical connector. Fig. 1: Rear Turn Signal, Brake and Parking Lights — Storm
  1. Remove the seven nuts and the rear combination lamp assembly from the vehicle.
  2. Disconnect the rear combination lamp electrical connector.
  3. Remove the four bulb sockets from the rear combination lamp assembly and remove the four bulbs from the sockets. To install:
  4. Install the four bulbs to the sockets and install the four bulb sockets to the rear combination lamp assembly.
  5. Connect the rear combination lamp electrical connector.
  6. Install the rear combination lamp assembly to the vehicle and the seven nuts.
  7. Connect the rear combination lamp assembly electrical connector.
  8. Install the rear end trim panel and the luggage compartment trim panel.
  9. Connect the luggage compartment lamp electrical connector.
  10. Install the ten plastic retaining clips to the rear end trim panel.
  11. Install the spare tire cover panel and the luggage compartment floor carpet.
  12. Connect the negative battery cable.
Mar 21, 2009 | 1991 Geo Storm
Broan-NuTone N-8663RP Combination Light Fan Exhaust Fan Logo
8,205 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
