SOURCE: No water coming through on rinse cycle
try to make a cup of water (tea), if you not get any water that way i think you have to replace the flow meter in the machine.
Best regards
/Mirran
SOURCE: My brew unit is stuck,
Try this.
You can enter a sort of diagnostic menu by pressing I believe the bypass doser and the medium coffee button together while you turn the machine on.
I forget which now, but one of the buttons will spin the brew unit one way, and another button will spin the brew unit the other way. The third button will activate the doser which makes a very LOUD clack noise.
You should be able to "wind" the brew unit manually this way in order to release it.
Good Luck.
SOURCE: machine is stuck in rinse cycle and brewunit
Take the brew unit out again, and try to twist the rotational mechanism so that the little arrows in the front of the axis align. This should allow you to insert the unit.
On insertion, you might also need to push the little handle on the front of the brew unit to allow the coffee trough to fit.
SOURCE: No water from the brewing head.
Check the screen on the brew unit it is below the red o-ring and that might be clogged, and the grind might be too fine.
SOURCE: Stuck in rinse cycle and the brew unit wont come
Allow the unit to complete the rinse cycle.
It may take several jugs of water to complete.
