Question about ASUS A8Jm Notebook
Boot up, lines on black screen
Problem first arose with ASUS A8Jm laptop failing to turn on. Then after resolving this issue by removing the battery for 15 minutes, the laptop would boot up and then hang with multi-coloured lines on a black screen. Thanks in advance for any insight, tips into this incredibly frustrating problem!
  • 89 Answers
It appears that you have a video card or inverter problem. I would probably place my bet on a bad inverter. You may want to visit the Acer forums aor talk to their tech support about parts.
Posted on Sep 18, 2007
SOURCE:
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
My asus inbuilt laptop screen goes blank. what is the solution ?
For a start try to remove the battery, wait for some time, then insert the battery. Turn on the notebook. Maybe, it will be useful for you. Meanwhile, maybe you need to reinstall drivers for your notebook which you can try to find here ASUS Notebook Laptop driver download
Mar 26, 2014 | ASUS A8Jm Notebook
When turning on the netbook, it load then the screen turns black for about 5-10 minutes before reaching the login screen. After logging in, the screen is just grey and stays like that. What's the
Try a system restore/recovery to a date before this issue. Have you done any hardware or software changes or updates? Graphics updates. Shut down, unplug, remove battery, plug in boot and follow this procedure: Please restart your computer, and hold down the F8 key before the Windows logo appears. On theAdvanced Boot Options select Repair your computer, and then press Enter. Select a user name, type the password, and then click OK. On the System Recovery Options menu, click System Image Recovery, and then follow the instructions. Take a look at this procedure from Asus suppot: http://support.asus.com/Search/KSearch.aspx?SLanguage=en&keyword=restore&ps=10&pn=1&st=knowledge
Dec 16, 2012 | ASUS Eee PC 1005HAPU17BU Netbook
I was testing my laptop settings and pushed a turbo button in the in built asus power management software. It warned me about overclocking before restarting my computer. After shutting down, the laptop...
If its still in warranty, try calling the Technical support of your laptop's manufacturer.They will help you over the phone or if possible take a remote access of your computer and resolve the issue for you.
Jun 21, 2017 | Asus UL80Vt A1 Core Duo SU7300 13 GHz 14in...
Anyone know where I can find a working driver for an Nvidia Geforce Go 7600 graphics card in an ASUS A8JM laptop for Windows 7 (x86)? I've tried the drivers offered by Nvidia and ASUS websites as well as...
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Dec 06, 2010 | ASUS A8Jm Notebook
I have an Asus G1 laptop and I was just on it when the screen froze and an error message appeared saying the display adapters were not working and then the screen went distorted and froze so i reset it ...
Press F8 when you turn on the computer and from the list of options select safe mode and boot into safe mode when you are on the desktop screen go to the device manager ( you can use this path : start-run-devmgmt.msc) in the device manager go to display adaptors right click it and uninstall it.
after that restart the computer.
if this doesnot work again boot to safe mode and try to do a system restore (start-all programs-accesories-accesibility-system tools-system restore)
select a date when your system was working fine, that should fix it.
Mar 10, 2010 | ASUS A8Jm Notebook
Laptop IBM ThinkPad. Black screen. Short beeps: 1+3+3+1
You can try the following steps:
1. Unplug the power from the laptop and remove the battery then press the power button of the laptop for 15 seconds
2. Put the battery back in, turn on the laptop without plugging the power to the laptop (If this didn't resolve the issue)
3. Remove the battery and press the power button of the laptop for 15 seconds, after that, plug the power cord and turn on the laptop (if this didn't resolve the issue)
4. Remove the power cord and press the power button of the laptop for 15 seconds, disconnect the Hard drive and turn on the laptop (If this didn't resolve the issue) reconnec the hard drive
5. Remove the Optical Drive and turn on the laptop (If this didn't resolve the issue) reconnect the optical drive
6. Remove the memory chip, if you have 2 memory chips installed in the 2 memory slots (remove both of them) now test each one of the memory to each slots turning on the laptop. (If this didn't resolve the issue) Put the memory chip back in. (Clean the slots if there are large amounts of dust)
7. Reseat the CPU and try to make sure that it's installed properly. Turn on the laptop and test if it's gonna work (If this didn't resolve the issue)
8. Reseat the power cords coming from the power supply of the laptop and test the laptop. (If this didn't resolve the issue)
9. Disconnect everything and just leave the CPU installed and turn on the laptop.
10. If all else fails, there's a big possibility that the problem may be with the power supply or the motherboard of the laptop.
Jan 24, 2010 | IBM ThinkPad T23 2647 Notebook
My Asus eee PC fails to boot
Reboot the system
Press F8 at boot startup. In the boot menu
Choose Last Known Good Configuration. If this doesn't work
Try Safe Mode
Go to Device Manager
Roll Back any new driver you've installed
and/or
Go to Add/Remove programs
Unistall any new software you've installed
Mar 31, 2009 | ASUS Eee PC 701 Notebook
Asus laptop - screen went blank and will not turn back on
I'm assuming your screen shows nothing at all, even the bios or boot screen as it turns on.
If you can hook it up to an external monitor then your video adapter is working. Try using the vga output on the laptop. If it doesn't show anything use you display select feature. I'm not sure what button it is on your laptop but on mine it is Fn+F8 (look for a button that shows a laptop and/or a rectangle).
If you can see it with an external monitor, you should try to uninstall and reinstall the video adapter. After you reboot the computer hopefully it will work.
However, if it still does not work, you will probably need to reseat the monitor cable. Do this by opening the screen panel. on the back is a flat cable tat plugs in to the LCD. This is usually covered by tape. Carefully remove the tape, unplug the cable and plug the cable back in. Don't forget to replace the tape!
I have fixed two computers in the last two weeks by reseating this cable.
Hope this helps and good luck!
Jan 10, 2009 | ASUS A8Jm Notebook
ASUS A8Jm Notebook Logo
223 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
