Question about Whirlpool Duet GHW9150P Front Load Washer
Control locked I load my clothes was fine, after the full washed, some how the light on the control locked was on and nothing worked. How to solve this problem please. Thank you
    Scholar:
  • 136 Answers
Hold the "end of cycle signal" button down till its unlocked. Let me know :-)
Posted on Sep 17, 2007
How do I turn off the control lock on a whirlpool duet washer?
To unlock the controls select and hold END OF CYCLE SIGNAL for 3 seconds untill Control Locked status light turns off
Sep 12, 2014 | Whirlpool Washing Machines
Magtag Centennial Washer Mod MVWC450XWO When I load, close lid, press start, green sensor light does not come on but red lid lock light starts blinking & lid locks & unlocks repeatedly while
Most likely it's the shift actuator but this washer design has had many problems. I would first unplug/replug all the wiring connectors. Tilt machine back for access to connectors for motor, capacitor, shift actuator and pump. You might want to pull the pump and make sure nothing is caught in there. Also do the connectors at the control board. Check for error codes as per tech manual and reset them. Perform the calibrate function. If nothing works, replace the shift actuator. It is a very high failure item on this washer design. If you buy it from here and it doesn't solve the problem, you can return it.
Aug 07, 2014 | Washing Machines
No lights on control board, door locked, MAH9700
Unfortunately the control board is dead and will need to be replaced. Here is the board to order if you decide to order it.
The E2 error code was for a stuck button and it would require the control board to be replaced also.
Dec 08, 2012 | Maytag MAH9700AWM Neptune Front Load...
Control lock light
Press and hold the DRAIN & SPIN button until the Control Locked light goes out. You will likely have to hold this button at least 3 deliberate seconds, maybe as long as 10 seconds to disable the control lock.
May 28, 2010 | Kenmore Elite 45986 Front Load Washer
Control Lock is on my front loader.
You should be able to unlock the control lock by holding the "end of cycle" signal for 3 seconds or until the "control locked" status light turns off.
If that doesn't work, please post your model number.
Mar 07, 2009 | Whirlpool GHW9400 Front Load Washer
The control lock light is on
there is a button on the far rt of the face of the machine...you hold that button down. the button is called end of cycle signal.
ann
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Old whirlpool washing machine won't run.
if no lights suspect main control bd remove rear screws in top panle remove top by sliding towar back control is along rear
Jun 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control lock on front load whirlpool washing maching
find button with lock emblem under it ..hold button down for 3-5 secs
Jun 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Panel
check your owners manuel should tell you how to un lock controls wont be an obvious button as its a safety feature
Dec 31, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
56 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
