Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung dlp when set powers up.....a whining noise starts....I have a picture.....operates fine except for the noise
Re: samsung dlp - Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Projection Televisions
I have the same problem. Any solution.
Posted on Jan 13, 2008
Re: samsung dlp
HLS4266W 43" dlp. In less than 1 yr whining grew worse, but did know what it was. Year passed with warranty and lamp went out. Replaced lamp. Worked for 3.5 hrs. Turned on next day and did not work. Got another lamp, but did not work. Figured out might be color wheel. Replaced it too. TV started up. Watched that night. Turned on next day, heard loud pop. Lamp never came on. Withdrew and reinstalled lamp a couple times to see if that worked. Did not. Currently, with new lamp and color wheel installed, lamp light blinks, but no lamp comes on. What now?
Posted on Dec 24, 2007
0 characters
3 Points
Samsung DLP fan noise, TV won't power up
Sorry, not a solution. I am here with same question. It has happened just as you said 4 times in the last two years.
Dec 06, 2013 | Projection Televisions
I have a humming noise coming from my 5 year old samsung 50 inch dlp tv , I have replaced the lamp 6 months ago so what else couyld the noise be coming from? I have a great picture and color.
If it is a high pitched whine it is most likely the color wheel; the bearings in the wheel go bad and if you google the model number with color wheel you will find it.
The whine is the early stages of the wheel failing; when it goes out you will either have shutdown or a grinding sound.
Let me know if you have questions as I am here to help.
Aug 09, 2010 | Samsung Projection Televisions
I have a Samsung HLR5067WAX/XAA 56 inch, rear projection. Replaced lamp on it two years ago, was working fine. This morning a sudden thunderstorm blew in. When the power came back on, the cable picture...
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Here's the instructions to replace it and your part # is BP96-01103A Have a bless one!
Apr 26, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Whining noise
Color wheel is going or gone out. New colorwheels are air bearing and not mechanical.
Jun 27, 2009 | Samsung HLN467W 46" Rear Projection HDTV
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Projection tv has really loud buzz or hum
You may not see any deterioration in the picture when the color wheel begins to go bad. The noise will get louder and eventually, it will shut down or the wheel will shatter while the motor continues to spin. If that happens, you'll have a black and white picture.
If its a Samsung DLP that is mercury vapor lamp driven, its a safe bet the color wheel is going bad.
Feb 11, 2009 | Samsung HL-R6167W 61" HDTV
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Whining Noise - hardrive or fan?
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Jan 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
352 people viewed this question
Top Samsung Projection Televisions Experts
Steven Wander
Steven Wander
The Wyzzyrd
Donald Griswold
Donald Griswold
Level 1 Expert
Are you a Samsung Projection Television Expert? Answer questions, earn points and help others
