Well I had the same problem until my husband fixed it and he had noticed on the right side knocking when pedaling only when is going back, so what he did is took the panel out from the back when the wheels rolls back there and that stopped it. He put the panel back to see if it still did it and it didn't because maybe it wasn't put on properly.
please go to the section in octane and download the assembly instruction and proceed how to change the rails in according with your model supplied God bless you
put your memory card in your computer and copy the pictures.
I had a voyager and I noticed the voyager folder for pictures and the LG Octane pictures folder had a different name so I copied the pictures to the other picture folder and then I was able to see the pictures on my octane.
its pinking which means the timing is too far advanced ,try 98 octane petrol .what year is vehicle as older engines were designed to run on higher octane petrol.like a MK2 jag or austin westminster need 101 octane.whats happening is the petrol has a lower anti knock additive than higher octane ,although the petrol is the same flame rate of burn its the amount of anti knock additive which gives it its octane value.just check timing and if a distributor is fitted ****** it a bit i would suggest 8 btdc but if still pinks on low grade then 6btdc
