We are having a big problem with interferance when driving by low lying electrical wires and/or other semis. SWR's are fine. We have tried moving the antenna's. Still the problem exists. Any ideas?
Comments:
Sep 19, 2007
- The antennas are fiberglass. The radio is connected directly to the battery. When I plug in my GPS or my phone charger into the power source (cigarette lighter) the noise comes back through the radio. I have to turn the squelch up on the CB to get the noise down.
What type of antennae are you using? If you are using an aluminum or stainless steel ant, I would suggest switching ti a fiberglass ant. It sounds like the metal ant is picking up the ambient voltage from the lines.
If you are using a fiberglass already let me know, as you may have a more serious problem.
Good Luck and I hope this helpsd L8R
Comments:
Sep 22, 2007
- Sounds like you need a noise filter on there. I have a 10" sub in my truck and needed to put one in for my CB as I was having the same problem, the noise filter I used got rid of most of the interfernce.
Check this link, it gives you several other possibility's you can try.
there should be a switch on the radio labeled ANL/NB make sure that the switch is in the on position for both of these. those are the automatic noise limiter and the noise blanker always leave them in the on position, this should stop your problem.
turns on receves, no transmit power. talkback works, pa works. when keyed up neddle dosent move and...
(More)
turns on receves, no transmit power. talkback works, pa works. when keyed up neddle dosent move and External swr/power meter shows no power at all switched mics no difference
my radio on my peugeot 307 keeps changing station on its own. and always to 103.10fm why is this?...
(More)
my radio on my peugeot 307 keeps changing station on its own. and always to 103.10fm why is this? what can i do? if i change it back it stays for a while then changes again
