Question about Toshiba Satellite M35X-S161 Notebook
Nothing happens on ''power on''.. black screen..
Toshiba Satellite m35x-s161, when I power on the laptop, screen stays black, it doesn't even load BIOS, i hear fans run for about 3 seconds then they shut off but power light on power button stays on.
Need help please.
  • Anonymous Mar 16, 2014
    Toshiba Laptop M35X-S161 will not boot. When power button is pressed laptop hums for a few seconds and stops. Even though lights just below laptop key board stays (two yellow and one green lights) the computer will not boot. Tried several times, still will not boot only hums for a few seconds and lights below keyboard stays on. Please help.
My old laptop toshiba m35x-s161 won't turn on the light on the power botton turns on and it makes some noise but nothing more happens
Sounds like there is a faulty connection between the power switch and the computer. Probably why its making a little noise.
Take in for repair and replace power button.
Jul 24, 2010 | Toshiba Satellite M35X-S161 Notebook
My toshiba m35x-s161laptop has issues
may be the procesor unit(cpu) is too bot because a dust.....
Mar 06, 2010 | Toshiba Satellite M35X-S161 Notebook
While im using my laptop the screen turns black and only the power buton stays lit
The plug is loose in the back where the power cord is
Bend the power cord up or down until it comes on and stays on!
Oct 17, 2009 | Toshiba Satellite M35X-S161 Notebook
Battery problem
all laptops are capable of running strictly on ac power. if your battery is not charging it sounds like time to get a new one.
you can get one here:
http://www.atbatt.com/laptop-batteries/b/toshiba/m/satellite-m35x-s161.asp
Sep 14, 2009 | Toshiba Satellite M35X-S161 Notebook
Black Screen ALL MOST, some time it is ok, some time not.!!!!!!!
can you try to Attach an external monitor and check if it has the same problem on the external monitor?
Sep 12, 2009 | Toshiba Satellite M35X-S161 Notebook
Screen Issue
I would check to see if the RAM has become loose, if you can reseat the RAM. Do you hear any beeps when nothing is displayed?
Aug 18, 2009 | Toshiba Satellite M35X-S161 Notebook
I have a Toshiba Satellite M35X-S161 that will not stay turned on for longer than 15 minutes.
Check power management - clean dust from fan - full system virus/spyware/registry scan. Place external fan to help internal fan.
Apr 04, 2009 | Toshiba Satellite M35X-S161 Notebook
Toshiba M35X-S161 motherboard replacement issues
How to remove back cove rof my Toshiba M35X-S161 to get the charging input jack to repair it?
Mar 28, 2009 | Toshiba Satellite M35X-S161 Notebook
Tashiba Satellite M35X S161 AC Intermittent Power Problem.
Your model of laptop is typical for the issue of the power plug. The plug can be soldered back on. As far as compatible memory you can call toshiba customer support and they probably could answer that question. there # is 1-800-457-7777
Mar 07, 2009 | Toshiba Satellite M35X-S161 Notebook
Computers & Internet Logo
312 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
