Question about Panasonic DP-8020E Black and White Copier
How to recharge some users of the ricoh af 3228C in the office?
We have an aficio 3228C in the office. Some people use it who are from a different company. How can I monitor their usage to recharge them please?
  • Anonymous Mar 19, 2014
    driver for mac
  • 469 Answers
Most Modern copiers have an access code system built in, this works in two ways, first it elimnates unauthorized copying as the machine is essentially locked if you do not have a code.
Second, It allows you to track the copies made by each code. By assigning each dept or individual with an acess code you can now track the number of copies each has made.
You will likely have to have the service tech come in to set up the feature and adminitrator functions. Once this is done you will have better control of your machine.
I have seen in larger operations a 20-25% reduction in copies once the codes are in place.
If the built in controller does not have enough access codes or features there are aftermarker products available.
Hope this is of some help
Ed
Posted on Apr 17, 2009
Ricoh Aficio 3228c misfed paper j001. paper jam
This means the machine has been turned on with a jam inside the machine someplace. If you have opened everything in the machine and found nothing then it is time to call a service technician.
Aug 03, 2017 | Ricoh Office Equipment & Supplies
We connected 2 computers to our Ricoh 3228c nd now it prints everything in code, how do we fix this?
make sure you are using the right print driver and if using a mac need postscript to print
Jan 03, 2014 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Faulty gradation print on RICOH AFICIO 3235C
check your driver, postscript? Or quality settings of the printer from the start menu
May 26, 2013 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
My ricoh aficio 3228c will not print in color
check your printer preference setting in computer driver you will see default set to black and white. select doc then select printer goto printer preference and select color
Feb 21, 2013 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
My Ricoh Aficio 3235c overlaps clolours when printng
With out seeing copy here is my thought either bad drum if it is streaks down copy or laser unit for yellow is out of alignment . In user tools there is a maintance tab go into it and do color alignment if it fails then could be transfer unit or laser unit for yellow will need to have a copier tech come out to fix it.
Oct 30, 2012 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Ghost image ricoh 3245c
No can do, if you are referring Norton Ghost. Ghost it only for OS on computers. Printers have chips with instructions.
Here are the drivers in case you need them.
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/c35_45/c35_45en.htm
Oct 25, 2012 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
How to connect a Ricoh Aficio 3228c to my computer as a printer
There should be different input and out put plugs on the printer somehwere. Like a fire wire plug or ehternet plug. Once you find the plug and cable, youll need to download the driver for the printer. You could just search your printer name and then driver on google.com.
Apr 19, 2012 | Ricoh Aficio Office Equipment & Supplies
Ricoh Aficio 3228C asks for user name and password
What is the user name and password refering to?
if it is the administrator user name and password try
user name - admin
password -
blank password.
good luck
Jun 30, 2009 | Ricoh Office Equipment & Supplies
Panasonic DP-8020E Black and White Copier Logo
77 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
