Question about ViewSonic VX910 19" LCD Monitor
Monitor Generated Image
I frequently get this image of a screen on my monitor that fades from redish, greenish, blueish to gray. It fills the lower two-third of the screen. I know it is generated by the monitor because it happens on three different computers and if I change computers when it is hapenning it still shows up with the other computer. Also I have used a laptop and the laptop image is fine but the monitor image has the distortion. Is this software fixable or must I replace the monitor. I have a picture of the problem.
  • bobingram Sep 17, 2007
    Picture of the problem attached.
  • bobingram Sep 18, 2007
    Can you please explain the cause of the problem?
  • 65 Answers
Great picture! Big problem! i suggest is time to do a monitor change.
Posted on Sep 17, 2007
SOURCE:
This is the strangest thing I've ever seen. I have a Gateway FPD1975W TFT Monitor and its always worked great. The other day it went into a sleep mode via windows, and now it wont boot up the input...
Your monitor problem is causes by the power supply. What is happening is the power supply voltages are not stable, just enough to power the unit up. When you connect it to a video signal the power demands slightly increase and the power supply can't handle it. This is a very common problem with LCD after a few years of use. The issue with the power supply is the capacitors have started to fail. These parts are used to filter the output voltage and when they start to fail the outputs start rippling hence the problem you are having. Here is a link to a repair article that shows how to repair the Gateway FPD1975W monitor.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps you get back going.
BuddyMc
Sep 20, 2011 | Gateway FPD1975W 19" LCD Monitor
The color of the display is a bluish
Color casting (Blueish, Greenish, Redish) problem is usually caused by bad video cable or bent pins on the video cable or the video plugs are not seated properly, it can also be bad vidoe card, very rarely caused by failed monitor.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 19, 2011 | Acer AL1917 LCD Monitor
Picture fades to near solid blue
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Apr 05, 2011 | Sony KP-51HW40 51" Rear Projection...
Double image
Mar 04, 2011 | Philips Televison & Video
There is no full-screen image when the set is on with a right side white vertical border appearing. We have to make do with a smaller window for a clear reception with another small frame with distorted...
Feb 28, 2011 | Sony KP-FX532M91 TV
I opened the set and the blue projecter does not show image like the red and the green. does the blue projecter need to be replaced?
Feb 28, 2011 | JVC AV-56WP74 56" Rear Projection...
Too much green, fades in and out. Just changed convergence chips
Feb 26, 2011 | Philips Magnavox 51MP392H Rear Projection...
Screen jumps back to prior screen
If you mean to say that the computer-generated displayed image on your screen changes, it's a function of the computer, not the monitor. If you mean to say that some monitor-generated displayed image is appearing (such as a setup/configuration menu or a splash screen), please tell us more so we can diagnose further.
Sep 12, 2009 | ViewSonic VP201b 20.1" LCD Monitor
My acer monitor image is faded and washed out
Adjust contract and luminosity: decrease contrast, see how it goes.
ACER monitors tend to have control settings that are out of the range for proper viewing.
Jul 15, 2009 | Acer X191WSD Monitor
Acer lcd monitorX221W : 18 months old, no prior problems. Today, image suddenly went out. Upon restarting, the name ACER comes on , fades after a few seconds, then the prompt to fill in Password. The...
Sounds a lot like the backlight for it is just about dead. Nothing you've done can cause this to happen, and it certainly isn't a setting on the monitor or PC.
The backlight can be bought as a part, and replaced by a technician (or yourself if you have a rough idea what you're doing). By the time you find one, buy it, ship it, fit it... it might not be worth your time for the cost of a new 21" widescreen monitor.
You'd probably recoup some loss by selling it as faulty for parts too.
Still, be 100% sure before you do it... borrow a monitor and plug it in. I bet the borrowed monitor won't behave the same way. =-]
Aug 20, 2008 | Computers & Internet
ViewSonic VX910 19" LCD Monitor Logo
87 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
