Unlock scanner message and ink cartriges slam left
I KEEP GETTING UNLOCK SCANNER MWSSAGE AND THE INK CARTRIGES ARE SLAMMING HARD TO THE LEFT OF MY LEXMARK X83.
  • 526 Answers
If the cartridges are slamming, it means either the encoder strip is dirty or damaged, or the sensor reading it is damaged.
average repair on something like that will be at least $95.00
thanks
Posted on Apr 17, 2009
My hp 8500 officejet printer won't pump ink up tp the printer cartrigers
I'm not sure I understand your problem. Are you getting any error codes or error messages? How did you diagnose your problem, specifically?
Jul 25, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
How do I change the ink cartriges in my printer
1.Turn on your printer.
2.Lift the scanner base unit.(The ink cartridge carrier moves and stops at the loading position unless the printer is busy.)
3.Press down on the ink cartridge lever to raise each ink cartridge lid.
4.Remove the old ink cartridges.
5.Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.(Make sure to take off the sticker and the transparent tape from the back and bottom of the new cartridge.)
6.Snap each lid closed.
7.Lower the scanner base unit until it is completely closed.
Enjoy printing...
Sep 14, 2010 | Dell V305w All-In-One R840635AU InkJet...
Receiving the message "Ink Catridge problem: ink cartridge appears to be missing or damaged". I've tried everything from cleaning cartridge holders to replacin cartridges. Nothing works and the printer...
The message you are getting may be due to the following reasons :
1) Cause : One or more ink cartridges missing.
Solution : Remove and reinsert the ink cartriges and verify that they are fully inserted and locked in place.
2) Cause : One or more of the ink cartriges are not installed or are installed incorrectly.
Solution : Remove and reinsert the ink cartriges and verify that they are fully inserted and locked in place. If the problem persists, clean the copper-colored contacts of the ink cartriges.
Nov 24, 2009 | HP Photosmart D7260 Printer
How do you change the ink cartriges
open the scanner and scanner tray..while the poweer is on..the cartriges will go to the left..then with a llittle pressure push down on the cartridge it will pop out
Nov 15, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Blank pages
tried re-installing the sortware or going into printer diagnostics in the start,control panel.
and it will run a diagnostic & try to print a test page, & clean the cartriges.
If not the printer's broke
Hope this help's
Sep 22, 2009 | Epson Stylus Multifunction Inkjet Printer/...
All cartriges have ink, still an error msg
have you tried not connecting to pc and running built in tests
Jul 30, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Refilled ink cartridge wont work. Getting message saying ink is l
Many 'refilled' cartridges aren't refilled. Try a new c artridge and see what happens. If it still doesn't work, you need a new print head.
May 23, 2009 | Canon PIXMA MP470 All-in-One Printer
Cant get re-filled ink cartrige to work
It sounds like whoever refilled the ink cartridges did not reset the counter in the cartridge, so it thinks that it is still empty.
May 23, 2009 | Enlight Intel Xeon 470 WATT EN-470 MP...
Ink moving very fast
Take a peak inside the printer where the ink Cartridge is and see if you notice anything out of place usually it has thin long plastic strip found behind the ink carriage unit make sure its there if its not there then u need to put it back into position you gonna need to take the printer two side cover off to do this
May 10, 2008 | Canon PIXMA MP160 All-In-One Printer
Lexmark x5150 scanner locked
Unlock Scanner message
The scanner is locked. to unlock it
1. Press Power to turn the All-in-one off.
2. lift the scanner unit until the scanner support holds it. To the left and beside the scanner support is the scanner lock
3.pull the scanner lock toward you to unlock the scanner.
4. close the scanner lid.
5. power on.
Feb 19, 2008 | Lexmark X5150 All-In-One InkJet Printer
124 people viewed this question
jasbo
jasbo
