Question about Vtech Cordless 6041 Phone
The battery is all charged up but the charging light always stay on. I have a LS6125-3 Model
May be what I look as a problem is normal. In any case I cannot talk to anyone at Vtech. All I get is the run around. I only bought this phone system 3 days ago. What warranty if you cannot speak to them wothout a credit card.
Posted on Apr 18, 2009
The batteries will not hold a charge. The green charge light only stays yellow
check to make sure the batteries are dud try to charge them one at a time with a car charger, if the same prob then replace batteries, if not and they charge fine replace the charger. always best to check first as batteries are not cheap,
Aug 17, 2013 | Electric Mobility Shoprider Electric Power...
Razor Bistro scooter won't take charge - light stays red
i had the same problem with mine and it ended up being that one of the batteries was bad, there are two 12v batteries wired in series under the seat, usually you can tell which one is bad by looking at them, one of the batteries will be swelled up
May 09, 2012 | Razor Pocket Mod-bistro Retro Scooter
The S107 helicopter charged up successfullyfirst time using an Apple USB mains adaptor. I then tried charging it up from a computer USB and it would only partially charge with the machine turned on and the...
Is helicopter off when charging? Will not charge when powered on.
Light on charger should go off when plugged into helicopter.
Also, are you running battery dead? This will destroy a Li/Po battery. Never fully drain battery. Run only until you cannot maintain altitude. Land and power off. Cool for 10 minutes. Charge. Cool for 10 minutes. Skipping either "cool-downs" will also destroy your battery, albeit slower than the full discharge which can sometimes kill a Li/Po battery in only 1 or 2 cycles especially when they are new. Have any friends with a cell phone or laptop (Li/Po batteries also) that they hate because "it's always dying" or "the battery only lasts like 4 hours" whether or not they know why, it is ALWAYS because they rarely charge them fully, especially for the first few charges which are crucial, and the often run the things dead until they won't even turn on.
Back on topic, I use and recommend the usb power adapter. When plugged in using the USB wall adapter, does the charging light still stay on? Certainly if "yes", and still likely if "no" sadly, this to me sounds like a fried battery, which, if it, as I suspect, was caused by frequent or early full discharges and/or hot charging/flying... then you're screwed. The batteries are cheap but quite tricky to replace. Need a steady hand and a needle tipped soldering iron and solder barely thicker than hair.
Hope I've helped,
PvT
Jan 04, 2011 | SYMA Toys industrial New Syma S107 Mini...
The red light is always on, and it doesn't seem to be charging. Its almost brand new.
Same thing started happening to me. The red charging light was initially going out but then after a few days use started staying on. I assumed that the battery was damaged and bought 3 new batteries but the red light is still staying on when I charge the new batteries.
I suspect that the mains charger I was using (same voltage but not the recommended charger) has perhaps damaged a component inside the EFLC1003 unit which is now not letting the power through to charge the battery.
Dec 30, 2010 | E-Flite 1s 3.7v Li-po Battery Charger Mcx...
Should the red light on the battery charger stay on, even when the battery is charged? Or does the continuous red light mean the battery will not charge?
I am not familiar with this model, but most chargers have a flashing light as the battery charges, and a solid light when it is charged. Do you have the manual? It should tell you what the lights mean.
Jul 17, 2010 | Powerglide Power Glide Cordless Drill
May battery light always on
This may indicate a problem with the battery or in the charging system. Take the car to an autoparts store and have them check the battery and alternator output. Most parts stores offer this service at no charge. Hope this helped and best wishes.
Aug 19, 2009 | Ford Focus Cars & Trucks
Battery
You may have a light staying on somewhere in the car, that is almost always the cause, lighted vanity mirrors, glove box light, truck lights, You also need to fully charge and test the battery.
Aug 29, 2008 | 1995 Honda Accord
The battery wont charge
i had the same problem.
if your battery light is blinking a red light then you should call up casio's technical support and they'll send you a new one within 2-5 business days:)
call 1-800-435-7732 for technical support! :)
Apr 01, 2008 | Casio Exilim EX-Z77 Digital Camera
Charge/in use light
Typically the charge light will stay on as long as the phone is on the charger. After 16hrs, the battery should be fully charged. Leaving it on the charger constantly can actually overcharge the battery, shorening it's life. The best thing to do is use it until it tells you the battery is getting low, then charge it uninterrupted for about 8-12 hrs. Of course, that's ideal and can't always be done, but the more you can do that, the better.
Hope that helps, and please rate my answer, good OR bad.
Feb 03, 2008 | Vtech 5.8GHz Analog Cordless Phone
Vtech Cordless 6041 Phone Logo
166 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
