Question about Water Heaters
I need to know how to fix my boiler as i have not had this one before its worcester 24i junior and some how the mains got turned off so obviously the boiler went off but now it wont work theres a red flashing light which lights every 2 seconds theres no pilot light the pressure is at 1/2 a bar and i do not have a clue where i will find the pressure tap the reset button or the ignition switch. arrrrrggggghhhh i have 5 kids and we have now had no hot water or heating for 2 days
  • 297 Answers
Manual here
http://www.worcester-bosch.co.uk/homeowner/literature/discontinued-boiler-literature/discontinued-gas-boiler-literature/24i-junior-rsf-discontinued-aug-2007-literature
All these machines need 0,8 bar minimum pressure for one.
When significant drop of pressure call qualified repair man.
If this is not your regular work you are at mortal risk.
Posted on Apr 17, 2009
How can I get a user guide for SALUS ST621RF(TX).Thank you
Here is your manual , click this link .
https://www.google.jo/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0CCAQFjAB&url=http%3A%2F%2Fwww.salus-tech.com%2Fcache%2Ffilelibrary%2F2159%2Flibrary%2FfileLibrary%2F2013%2F9%2FST620RF-Manual-Version-009.pdf&ei=aqpcVaeKDInhywO-wYG4CQ&usg=AFQjCNG3X7bL7ssC4wjnbJlKP047s85Rrg&bvm=bv.93756505,d.bGQ
Apr 07, 2013 | Water Heaters
How do i refill ny worcester junior 24i combi boiler? as i cannot get the pilot light to light
Two types dependent on age
Early - in the mains water inlet pipe there should be a service valve/tap which when turned on will refill [it is close to or part of the fill loop - a metal braided flexible pipe
Later - underneath there is a hole for a plastic tap [supplied with boiler] to be inserted [usually just right of center] Insert and turn 90 degrees then close to it another small knob or 2nd tap which when turned [same action as a basin tap] will refill. If the first tap is not inserted properly water will drip out past its seals
For both Refill to about 1.5 - 2 bar and turn off
For the later as above but also remove the 1st tap
Mar 14, 2010 | Water Heaters
My boiler is not working, not heat, no hot water, red alert light flashing? I dont know how to reset the boiler or het it going again. Its a Worcester 24i junior. Help! Im very cold!
your condensation pipe may be frozen get a hairdryer on it or a hot kettle that should sort it thats the whit pipe on the left usualy plastic
Nov 13, 2009 | Water Heaters
Flashing red light on Worcester 24i junior combi boiler
Pressure is ok? at 1 bar or above
I think on this one there should be a reset button [red] on the left hand top of the casing - or lower the control panel [ phillips screw on each side] and the button is on the left of the base plate. Press this and try the heating.or hot tap
P.S. if you're on a prepayment meter check you have gas.
Nov 08, 2009 | Water Heaters
Flashing red light under ! on my worcester 24i junior combi boiler and pressure under 1
you don't have enough pressure in the tank you are using, needs to be a 2lb system to work properly it is starving the gas valve for gas
Apr 19, 2009 | Water Heaters
Hi where can i find a manual for a worchester greenstar 24i junior boiler please
if you go on the worcester bosch web site and contact the service dept they should send one out to you or you may be able to download one from there.
Mar 27, 2009 | Water Heaters
Wiring diagram worcester 24i junior
http://www.worcesterbosch.com/ gothere and see iu get help for what you want.
Mar 17, 2009 | Water Heaters
Water Heaters Logo
1,570 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
