Question about Epson Stylus CX3200 All-In-One InkJet Printer
Don't print error scaner
Error scaner
Have just managed to repair my Epson CX3200 thanks to the site! It took 24 hours of messing about but now it works perfectly again. It had the error light on and the display said certain items inside printer are beyond user life contact distributor. It has been a great machine for 3 years exactly and as it had been performing perfectly I was loathe to bin it. I followed the advice and hey presto! I have few tips to anyone attempting same.
1. Download from the site as recommended SSC Service Utility http://inkjetprinterhelp.us/
2. When taking off the scanner unit there is a smallish cover on the left hand side of the printer at the back; remove this and disconnect two ribbon cables, two cables with push pin conectors and a spade connector, 5 altogether.
3. Two screws hold down the hinges of the scanner unit remove and store carefully. Lift off scanner unit.
4. Take out four screws holing printer body on, long magnetic philips screwdriver needed. store screws lift off cover.
5. At back of printer are the three waste ink pads; use a spade end screw driver to lift out one at a time. They are about 5cm x 9cm and the bottom one is slightly different shape to other two.
6. Rinse them thoroughly with water and then squeeze out and dry. I used kitchen roll and then hair dryer.
7. Replace one at a time tucking in corner bits with screwdriver.
8. Replace body, scanner unit, wires and cover.
9. Connect up printer and switch on. Error light will come on again; don't dispair, this is what fooled me. Open SSC utility on desktop and then close; icon appears in lower right screen on application bar like printer icon. Right click and pop up menu appears; left click on "Protection Counter" and then "Reset Protection Counter".
10. Turn off printer and then switch back on again. Error light should go out and you can carry on.
Posted on Apr 25, 2009
System error e225 in my canon imageRUNNER 6000 machine please help me shut out this problem
the error E225 means that the SCANER UNIT is faulty.
You can call for tech for replacement or, if you have the expetise, you can do it your self with a brand new SCANER UNIT from CANON.
OR
Try this With the Printer On:press and hold the Stop/Reset button for a full 6 seconds.
Release the button. Restart the Printer and try to print again.
Sep 16, 2013 | Canon imageCLASS MF4150 All-In-One Laser...
How can I work with fax and scaner when I get u051 error printer I don't need the printer
U051 indicates an ink cartridge that cannot be recognised by the printer. Sadly you cannot use your printer while this error remains.
I would advise the following:
-Remove the problem cartridge from the printer
-Wipe the gold contacts on the front of the cartridge with a piece of non fibrous tissue (like kitchen tissue).
-Re-install the cartridge.
If the error remains it is likely that there is a genuine problem with the cartridge. So I would advise re-installing whichever cartridge you had in the printer before the error began to show or purchasing a new ink cartridge.
Sep 12, 2012 | Canon MX300 Office All-In-One Printer
Hello!I have a printer HP laserjet m1120 mfp and it give me a error "Scaner error 6",how I can fix it?Please help me!Thank you!
First see the scaner moving or not just power on the printer & see the movement if it stucks then problem with scaner this printer should be under warrenty pl call the service engr from hp /change the flatbed scaner.ur problem may be resolved.
Aug 10, 2010 | HP LaserJet M1120 MFP All-In-One Printer
When I click TO PRINT Document the following
First thing you need to do is remove the device from the device manager. Uninstall the printer, then reboot the computer and you use that first CD that you listed.
Aug 05, 2017 | HP OfficeJet 4255 All-In-One InkJet...
Don"t work scaner
if an error message of bulb error or something like this, you have to change the scanner assembly.
contact me if you want a new one with a good price
walid_sayed@hotmail.com
or send me the error message EXACTLY
Mar 18, 2010 | HP LaserJet 3330 All-In-One Printer
Canon cp94o display error E0
Exactly when did the E0 come up? that is the error for the fuser not heating up and shouldn't have anything to do with black copies. What is the status now and please add more information.
Mar 15, 2008 | Canon ImageRunner 2016 Copier
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
124 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
