Question about RCA 24F512T 24" TV
Won't turn on at ALL!
I have an RCA TruFlat 20F512T 20", and I've had it for over 2 years. Suddenly, while it was on, it said "ECP Lock" or something close to that, and then turned itself off. The red standby light is on, and the TV is plugged in. I have tried unplugging it for various lengths of time hoping it will reset itself, I've tried holding down the on button, and opening up the menu, but nothing has worked so far and it just will not turn on at all. And I have no remote control for it. Someone please help me!
  • gineko Sep 22, 2007
    I took it to a shop in the area, but they were trying to charge me more than my TV is worth to fix it. so right now I'm trying to find someone who knows what they are doing but won't make me give them my left arm.
    Thank you so much for the solution though, I really think that's what it is, but have no idea how to fix it myself.
  • dynoman Nov 15, 2008
    I have the same problem, will not turn on via the switch or with the remote and the red standy light is on. It's less than 2 years old.
    Genius:
  • 1,139 Answers
You may have had a power supply issue occur. The overcurrent circuit may have turned you TV set off to protect components from damage. If you have a background in electronics you might be able to fix this problem if not take the set to an authorized shop. Get a schematic open up the set and look for the Horizontal output transsistor and read the voltages on it leads and compare them to the schematic voltages. Then check the Integrated High Voltage Transformer for shorted turns, if you know how to ring test a transformer plese do so at this point. Also check the voltages on the main power supply and compare them to the schematic. Please contact me with an update.
Posted on Sep 17, 2007
SOURCE:
RCA truflat model#20F512T remote control codes
The code would be in a compatible remote.
Jan 29, 2017 | RCA Televison & Video
Rca 20f512 tv won't stay on
Here is a troubleshooting guide for you:
Flyback Transformer
must have supervision of a qualified service technician
Sep 23, 2012 | RCA 20F512T 20" TV
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Mar 11, 2012 | RCA TruFlat 27F520T 27" TV
Dog ate remote where can i find one?
Hello
If you want to get its original model remote control; you have to contact the nearest RCA authorised service center at your town. You can't buy its orignal from nowhere else. A universal RCA remote control will work with it, but sometimes some buttons of it may not synchronised. So try to get its original model. Moreover, if by anyway this set happened to be in FPA lock, you cannot open the lock without the orignal remote control. A universal remote control, whatever it may be, won't work then. OK.
Sep 24, 2011 | RCA 20F512T 20" TV
RCA 20F512T, unable to get sound on tv. It worked
check in menu, enter in the audio setup and check if tv speaker is in on.
Apr 21, 2010 | RCA 20F512T 20" TV
I turn it on. It shuts itself off after 1 or 2 seconds.
Ok, well to me It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 21, 2010 | RCA TruFlat 27F520T 27" TV
RCA Truflat 20F512T turns itself off and on
If it is an intermittent problem, changing the tact switches on the main board solves a lot of these problems. Tact switches are on front of main chassis where customer controls activate them.
Oct 24, 2009 | RCA Televison & Video
Green picture only
The projection TV has 3 guns RED GREEN BLUE. In your case the red and the blue guns are gone. So you are getting the green color screen. You got to replace the picture tube.
Jul 25, 2009 | RCA TruFlat 27F520T 27" TV
I have an RCA model 20F512T and the screen is tinted green
maybe you should check your picture settings from the menu button, it should be a "slider" from red to green, and your preference somewhere near the middle.
Jan 26, 2009 | RCA TruFlat 27F520T 27" TV
RCA 24F512T 24" TV Logo
184 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
