Question about Toshiba Satellite A105-S4244 Notebook
Unable to restore laptop using recovery disk.
How can I take out the optical drive to replace it with a new one?
  • 57 Answers
Remove the single screw that holds the dvd bay. It is the closest to the centre of the base and is not marked 9B. The bay can then be slid out.
Posted on Sep 18, 2007
SOURCE:
ACER REINSTALL STUCK ON INSTALLING CLEANUP 28/29
Sounds like the recovery disk when BURNT contains errors, you need the factory discs for your system
Jan 26, 2013 | Acer Upper Case Palmrest for Aspire 5336,...
Replaced the MK5065GSX hard drive used the recovery disks but 'no bootable drive' message displayed.
no PC stated
no OS stated
no source of recovery disks stated (HP, MS or crack.org)
or home made?DVD-R or CD-R?
the answer is all you said and more.
lots more.
bad disks wrong disks
bad CD drive
bad HDD drive.
or if laptop then main battery is bad (bigone) and overloads it.
why not boot to live linux disk (optical media)
UBUNTU, 16, FREE, BOOT IT AND HIT TRY ME.
See if PC runs ok.
then if that works run DISKtest during the above demo try me.
if that passes we we are at
bad media install disk you have (no os stated or class of media)
bad cd/dvd drive.
Jan 05, 2018 | HP Computers & Internet
Im having trouble restoreing my Toshiba Ssatellite laptop to the oringal factory image .I cant pull up the hard drive disk utillity menu can you please help me out ?
If you are unable to get into the recovery partition then most likely the hard drive is failing and needs to be replaced. You can buy new hard drives for as little as $45 online or best buy. Once you have the new drive in you would need a recovery disc set to re install the OS + software. If you do not have the recovery disc set you will need to order that from toshiba.
Aug 08, 2011 | Toshiba Computers & Internet
Unable to restore back to factory image read error
Are you using Factory CD/DVD or Made from utlity Disks or from hard drive utility option.
This seems to be a CD read error.
I found the same error code need help for posted for HP, Compaq, Gateway, ETC.
ALL new setups with the MAKE RECOVERY DISK UTILITY and NO factory disks.
Factory recovery disks are available for $60 and up from manufacturers.
Other option is Install Retail OS - get drivers from manufacturer - Install software you want to use.
Other option is expensive but reliable.
Factory option would be for your system only.
Apr 05, 2010 | Computers & Internet
I couldn't restore my mini hp. How to restore factory my mini hp? As i couldn't find ways to restore it from my mini hp. By the way, my mini laptop doesn't have any CD rom drive.
Roxio BackOn Track is a suite of backup and recovery tools which includes the following: · Disaster Recovery? · File Backup? · Instant Restore? Accessing Roxio BackOn Track There are two ways to access Roxio BackOn Track?through the boot menu or through the Windows Start menu. Use the boot menu option if you cannot access Windows. You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored. You must be able to access Windows to use the other options, such as Disaster Recovery. To access Roxio BackOn Track using the boot menu, follow the steps below. 1. Press the power button to turn on the HP Mini. 2. Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.To access Roxio BackOn Track using the Windows Start menu, click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track.Backing up your hard drive using Disaster Recovery 1. In the left pane, click Disaster Recovery to expand the options, and then in the right pane, click Backup Drive . 2. Select the hard disk drive from the drop-down list in step 1, click inside the text box in step 2 and add any comments that you want to add, select a destination drive from the drop-down list under Destination Selection , and then click the large circle button at the bottom-right of the screen to continue. 3. Wait while Backup Drive creates an image of your hard drive. Restoring your hard drive Prior to restoring your hard drive, you must have created a disaster recovery set. To restore your hard drive using Disaster Recovery, follow the steps below. 1. Shut down and power off your HP Mini if it is not already powered off. 2. Connect an external USB optical drive to the HP Mini. 3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc. 4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer. 5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.For more information, please see the Help within the Roxio BackOn Track software.
Mar 20, 2010 | HP Computers & Internet
Missing recovery disk for Composer 5100
The recovery disk is usually stored as a separate partition on the hard disk itself (Mostly in cases of laptop disks), so when ever you purchase laptops with pre-installed Operating System, The very first thing you do is create a CD/DVD recovery disk ie burn the recovery partition on the CD/DVD.
so that you can use the same DVD in case the OS crashes.
In your case as your hard disk was crashed and replaced ask the people from where you purchased the laptop/pc to restore it to the new hard disk, or purchase the Operating System.
hope this clears the doubt
regards
Jun 22, 2009 | Computers & Internet
Optical drive cant recognise by the system
Your problem is that your system does not see the optical drive, simply because it was not programmed by the recovery manager to do so. When the plug was pulled, the loss of continuity caused that you have lost the driver for the cd/dvd drive. Now you need to erase everything and begin by installing the system and then the drivers. Don't feel bad because I have done the same mistake with my HP nx9420 laptop. The way I fixed it is that I called HP Tech. Support and asked for a System disk and a Drivers disk. If they ask you what happened to the ones that came from the seller, tell them that you never received any (which is most likely the truth). You are not cheating anyone. They have these disks by the million and they give them away free. You install the System disk first and you will have everything working. If I am not mistaken you will also have your optical drive working, if not it will work after all the drivers are installed. Please, keep in touch with me and when you have the disks, I can walk you through the process. For that I give you my e-mail <[email protected]> 7862340692. The whole procedure is totally free. We thank you very much for considering our service...
My name is Constantin (arzconst)
May 31, 2009 | HP (D7580-60003) Motherboard
Recovery error 320 on sony vaio laptop
Ketanvasu your an idiot....If he's trying to recover the laptop obviously the thing isn't working...so how the hell is he supposed to burn cd's genius?
May 09, 2009 | Sony VAIO VGN-NR498E/S Notebook PC
Delete everything off
See the instructions below from the support website - you need the discs that came with your laptop. If you do not have them, find an OEM copy of your systems operating system and install. Be sure to download and install all driver software from the Fujitsu Website.
http://support.fujitsu-siemens.com/
Restoring operating system
Using the ”Windows Recovery CD" and the ”Drivers & Utilities CD", you can restore the operating
system of your notebook.
All hard disk contents are deleted during operating system restoration. After this, operating system,
drivers and software utilities will be reinstalled. For this reason you should try to save important data
to a backup medium before you restore the hard disk contents.
► Insert the "Windows Recovery CD" into the optical drive.
► Switch the notebook on.
► Follow the instructions on the screen.
i
Detailed PC knowledge is required for manual partitioning.
You must then reinstall all the drivers. Use the "Drivers & Utilities" CD provided.
Jun 12, 2008 | Fujitsu Siemens AMILO Pro V1000 Notebook
Toshiba Satellite A105-S4244 Notebook Logo
99 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
