Hotpoint Aquarius WMA58 lights flashing in line after programme selected...
All the lights on my Hotpoint Aquarius WMA58 start flashing in line as soon as a washing programme is started and the cycle then stops. I am able to drain it, any ideas?
SOURCE: Hotpoint WD129 Wash programme stuck
The solution was correct it was the heating element, after it was replaced the machine now works fine !!!!
Thanks for the help !!
Posted on Dec 22, 2007
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius WMA58 spinning but
Suggest you check pump filter.
you will find it located at the rear right side of the m/c.
Remove lower rear panel, there you will see a large black hose, remove securing clip, and detach hose, the filter is located inside, remove and clean, make sure you put everything back in the same order you took it off.
This should solve your prob. Make sure the drain hose is not clogged and the outlet is clear also.
Plz rate my solution.
Thanks.
Posted on Dec 21, 2008
  • 86 Answers
SOURCE: hotpoint aquarius washing machine water
Hi, Ok first things first where is your machines waste pipe connected? If it connected to the sink trap check there first by undoing it and check that there is nothing inside stopping it from letting the water out..?
If this is clear then have you lost anything? Sock? ETC....? Can you hear the pump? And is the water draining but not spinning?
If you cannot hear the pump running then it will more that likely be the pump as they are a magnetic pump which fail quite alot. If the pump is running then it is going to be something you have lost which will be located in the sump hose underneath the machine whic comes from the tub to the pump. Take it off and check and clean as nesscerary. Or last but not least it could be the fact it is doing everything but not spinning ( no drum action )? Check the motor carbon brushes if they are low then this will cause the problem or the motor has failed!....
Good luck and let me know ho you get on??
Posted on Dec 30, 2008
  • 6 Answers
SOURCE: Test mode
press start once
then press start again now hold on/off and cancel together for a few secs should no say d/off or something should work now
Posted on Oct 17, 2009
barkencoa
  • 3463 Answers
SOURCE: Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Posted on Feb 09, 2010
Hi we have a Hotpoint Aquarius FDAL28 dishwasher. Machine turns on, drains and fills but then 3 lights keep flashing and washer stops programme. Any ideas what problem could be?
Depending on which lights are flashing, there is either a problem with the electronic control module, or the pump is stuck or has a motor failure. You can see which by comparing which lights are flashing with the pattern on this page of error codes:
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3293-hotpoint-fdl-series-dishwasher-fault-codes
Jul 15, 2017 | Hotpoint Washing Machines
Hotpoint wma58 stopped spinning
unplug it for a hour plug back in see if it resets it self
Apr 05, 2014 | Hotpoint WMA58 Front Load Washer
Hotpoint aquarius wt540 - it has started to malfunction
Most likely a control board failure, you need a service tech to come out.
Oct 27, 2017 | Hotpoint Aquarius WT540 Front
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
I have a Hotpoint Aquarius WML540 washing machine and after the wash and the rinses, all the lights start flashing and the programme will not go any further. I would like to know what is causing this and...
I would like to know what is causing this and how to solve it.
Sep 22, 2009 | Washing Machines
Is it possible to change bearing on a Hotpoint Aquarius WMA58? and if yes, can i do it my self? thx
You can do it your self, but it is a very involved repair, and I would not recommend that you attemt it, unless you are conversent with washing machines, it involves a complete strip down.
Thanks.
Aug 05, 2009 | Hotpoint WMA58 Front Load Washer
Hotpoint aquarius
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Oct 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius fdw60
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Sep 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Washing Machines Logo
267 people viewed this question
Top Washing Machines Experts
