Question about Propellerhead Reason 3.0
Unlock published song
I published my beat by accident and now it is "locked" up and i cannot make any changes to it or update it - is there any way i can "unlock" my published beat????
I want to unlock my i phone 4s
Do you want unlock your iphone4s mobile network lock? Yes means you can visit this site Mobileunlocksolutions.com here you can get the remote unlocking service and unlock your iphone4s mobile network lock permanently easily.
Apr 17, 2014 | Apple iTunes
I have accidently locked my ipod and have no idea what the password is
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.If you want to change the primary computer that your iPod is associated with, do this:
1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
May 22, 2011 | Apple iPod nano
My son accidently locked his ipod nano and doesn't recall the code to unlock it. How do I help him to unlock it?
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
For this FREE answer, Please rate me
Dec 28, 2010 | Apple iPod nano MP3 Player
What is the unlock code of naruto ninja wars?
Alternate Costumes:
On the character select screen, highlight a character and press Y.
Unlock Sound Test:
Beat the game with every default character.
Unlock Hinata:
Clear story mode using Sakura. Find this fighter by highlighting Rock Lee and pressing X.
Unlock Extra Characters:
Rock Lee
Beat Zaibuzan in story mode without using continues, and then beat Rock Lee when he appears.
Kyuubi Naruto:
Unlock Rock Lee, and then beat the game with all characters. Now highlight Nartuto on the character select screen and press X or Z.
Sharingen Kakashi:
Beat the game with Kyuubi Naruto, and then beat the game with Kakashi. Now highlight Kakashi on the character select screen and press X or Z.
Hope this helps.
Nov 29, 2010 | D3 Publisher Naruto: Ninja Clash for...
Ok, dont have a computer and i have a ipod nano
IPod synced with), and open iTunes. When you disconnect iPod from the
to your iPod.
with, do this:
computer.
Good Luck, I hope this helps
Please Rate me...Thank You
May 11, 2010 | Apple iPod nano
How to unlock your ipod nano from it be locked to listen to music
In the Apple Support Site, Apple notes that the "Screen Lock" function:
Allows you to set a 4-digit combination to prevent someone else from using your iPod while it is not attached to a computer. When an iPod is locked, you must enter the combination to unlock the screen. This feature is different from the Hold switch in that the Hold switch only prevents iPod from turning on accidentally -- not keeping snoops out. Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with itunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod). This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
Nov 05, 2009 | Apple iPod nano
OPTIARC DVD RW AD-7560A ATA DEVICE REGION LOCKED
u can find the firmware what u need to update here - http://support.vaio.eu/downloads/info/info.asp?site=voe_de_DE_cons&url=VAIO/Updates/EP0000145203.exe&ip=EP0000145203.htm
After that install to your computer anydvd so u dont need to change the regions
Dec 10, 2008 | Lenovo IdeaPad Y510 Notebook
Apple Ipod nano 4gb
You can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.
iPod Updater:
http://www.download.com/iPod-Updater/3000-2182_4-10303489.html
Sep 21, 2008 | Apple iPod nano
Locked ipod
plug it into your comp and iTunes will unlock it for you
or
Dec 12, 2007 | Apple iPod MA446LL/A MP3 Player
Computers & Internet Logo
524 people viewed this question
Top Propellerhead Computers & Internet Experts
solver2010
Tom Chichester
imnengineer
imnengineer
Level 1 Expert
Are you a Propellerhead Computer and Internet Expert? Answer questions, earn points and help others
