Question about Janome Memory Craft 9000 Computerized Sewing Machine
My MC9000 is jamming when I go to sew (normal sewing/default sett
Ings - it makes a loud noise like the needle is hitting something and it jams. i have cleaned it, removed and replace the needle, the bobbin and still the problem continues
You may have to replace the bobbin race. It is the round compartment (Black) that the bobbin sits in. If the needle has hit the race because of misthreading, it may have displaced it and put a hole in the race. Not very expensive to fix... want to say somewhere around $30
Posted on Apr 17, 2009
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
Babylock Esante stopped. Just makes loud noise but won't move even manually.
You probably have a jam. Start digging under the bobbin area.
If you get it all cleaned up under there... and it still won't move. Time for service by a pro. Could be something horrid like a bent shaft.
Good luck
Nov 03, 2012 | Baby Lock Sewing Machines
Brother 700e
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Aug 16, 2012 | Brother SE-270D Computerized Sewing...
Huskylock viking serger machine is very noisy / squealling; oiled / cleaned machine, changed needles... It gets quieter if I sew fast.
some machine make more noise than others, but to be on the safe side I suggest having the machine check to see if there is something else wrong, it could be something is loose or worn in the machine.
Feb 07, 2012 | Husqvarna Sewing Machines
Singer Confidence Model 7470 bobbin jammed, needles breaking, now won't sew
Sewing machines will get out of time, often as a result of broken needle. Search for sewing machine timing or take it for service, otherwise it will simply continue to break needles and possibly damage the machine.
Nov 11, 2017 | Brother Sewing Machines
The needle keeps hitting the bobbin holder, it has actually nicked it. I cannot sew, the bobbin thread just jams up in a bundle and the machine jams
Check to make sure the needle is up all the way into the clamp. If the bobbin case now has sharp edges from the impact. polish away the sharpness with an emery board or simular. Once a needle is hit it canot be used again so always use a fresh needle.
Dec 12, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Just started to tangle up and jam up not letting needle to go down making a metal noise followed by jaming noise
Sounds very like a bent needle or jammed bobbin case. have you cleared any broken threads or replaced needle? Lift the needle plate and check under that too.
Nov 26, 2010 | Brother CE5000 Computerized Sewing Machine
Model 6408. machine jams with a loud noise (belts slipping !!) and bend's needle, as if fabric is beeing pushed to the rear before needle clears fabric.
Go to Singer at singerco.com and you can buy a hard cover instruction manual for $15.. Your needle shaft may be bent so that it is hitting the presser foot.
Sep 12, 2010 | Singer Sewing Machines
Janome Memory Craft 9000 Computerized Sewing Machine Logo
200 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
