Question about Toshiba 56HM195 56" Projection HDTV
Light engine adjustment?
I have a 56HM195 DLP TV. Recently, the projected image on the screen is slanted upward, and smaller print is less sharp that usual. Is there any way to adjust this? Is this the light engine or the mirror? I have run diagnostics, and everything seems to be working normally.
  • 77 Answers
SOURCE: 56HM195 Light Engine Troubleshooting
you should make sure that the onscreen menus are effected by the problem if they look OK and just the video bihind them is distorted the problem is in the digital video or what Toshiba calls the seine module. Probably not though it sounds like an engine. PTS electronics rebuilds some engines however most Toshiba engines are relatively reasonable.
Posted on Jun 08, 2007
  • 203 Answers
Most light engines have a internal screen generator that bypasses any video processing circuits to troubleshoot just such an issue. See if you can locate a service manual for this model and initiate such a test. If I can locate a manual I'll post the instructions.
  • 8617 Answers
SOURCE: Blue Convergence
Blue convergence IC is bad, but change both as red wont be far behind they are cheap about 10.00 ea at the following link.
Posted on Jan 14, 2008
  • 1030 Answers
SOURCE: Toshiba 42 inch rear projection T.V.
this sounds like a convergence loss... the most likely cause of this is what is known as stk's or convergenc ic(chips) have gone bad.. also it cound be the output resistors. most likely need replaced
Posted on May 12, 2008
SOURCE: Toshiba TN50X81 Power Issue
We had this problem too. If finally got to where it wouldnt turn on at all. A service man came out and replaced the power switch. That took care of the problem.
Posted on Aug 27, 2008
  • 5 Answers
SOURCE: I need to clean mirror
Most rear projection sets the screen will pop off the front. Usually a couple of hidden catches. Get another person for this.
Once off you can clean the mirror but not the inside of the screen.
Unplug tv first
Posted on Mar 13, 2009
0 characters
1 Points
57in Toshiba projection tv flicker all the time,what the problem?
Toshiba 56HM195 DLP Flickering Problem - YouTube
? 0:08
Nov 21, 2009 - Uploaded by Brian Baute
Flickering & green boxes appearing all over my Toshiba56HM195 screen. This behavior is consistent all the time, with multiple lamps, and across multiple inp... ... Up next. Stay Away From Toshiba DLP Projection Television!
Oct 29, 2015 | Toshiba Projection Televisions
Light bulb
White dot for DLP Projector TV is not because of the light buy. It is caused by aging DLP chip ( DMD Chip.) Your TV DLP Part should be the following image:
Check the post how to place it diy
May 04, 2012 | Projection Televisions
Toshiba 56hm ic repair
The model listed here 56hm195 is a dlp and has no ic's for this issue.
Double check the model number on the rear of the set and let me know--if convergence the set will have a way in the menu to attempt to adjust--if it has that the model indicated is wrong.
Apr 01, 2012 | Toshiba 56HM195 56" Projection HDTV
Why the white spots on my tv screen. started with one, then two and now up to 9
the reason this is happening and the problem is getting worst is because the DMD board is starting to go bad some of the micro mirrors are getting stuck on the on or off position and the problem is only going to get worst if you want to fix this problem you need to replace the light engine here is a link that will teach you about this projection works
Jun 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
It sounds like your light engine needs replaced, should be around $400.-600. depending on who does it. I have seen the lamp cause similar symptoms but not that likely.
Feb 29, 2008 | Projection Televisions
Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
Jan 27, 2008 | Toshiba 56HM195 56" Projection HDTV
Blue/green spots on dlp
If your bulb light came on, Replace it before the bulb goes out. if not It could damage the bulb housing when the bulb pops. I have the same problem and dont have a solution for the spot.
Oct 14, 2007 | Toshiba 56HM195 56" Projection HDTV
Toshiba 56HM195 56" Projection HDTV Logo
107 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
